High Beam Signal Wire on 1290 SAR
Discussion in 'Hard. Core. (1090/1190/1290)' started by Kevlar49, Oct 4, 2017.
  1. Kevlar49
    Kevlar49 Adventurer
    Jul 15, 2011
    47
    Millbrae, CA
    Hey all. I'm looking for a way to wire in a high-beam signal (+12V when high beam is on, off otherwise) to my Skene light controller on my 1290 SAR. Since it's CANbus controlled, it's not as simple as tapping into a wire on the back of the headlight. The "Hi beam" wire is at +12V with the high beam off, and pulls to ground (through the handlebar switch) with it on.
    I've pored over the wiring diagrams in the service manual, and don't see any obvious signal sources. Has anyone here been able to locate one, or come up with another way to get a +12V hi-beam source?
    gianmarco dambrosi likes this.
  2. 3rdgeargrndrr
    3rdgeargrndrr Long timer
    Jan 19, 2017
    1,171
    Sacramento
    I'm no electrician but can you tap into the negative headlamp wire? when the high beam is on, does this effectively close the circuit and provide power to the negative lead?
  3. Warrior102
    Warrior102 Been here awhile
    Jun 19, 2016
    204
    Mashpee, MA
    1190R here and the only way is a three way switch due to CANBUS.
  4. Sean p
    Sean p Adventurer
    Sep 25, 2016
    76
    Sunny south ,well the uk
    Did it a year ago on my 1190 and wired in skene controller to the high beam feed following the instructions,works fine
  5. 1coolbanana
    1coolbanana Long timer
    Aug 25, 2009
    6,658
    NW Sydney, Australia
    Headlight has nothing to do with CANBUS.
    brianbrannon likes this.
  6. Kevlar49
    Kevlar49 Adventurer
    Jul 15, 2011
    47
    Millbrae, CA
    No? Then why does the headlight have CANBUS signal going to it?
    CANBUS monitors the state of the lights, and throws an error if it detects incorrect resistance. If that wasn't the case, I'd just use a relay to covert the pull-down signal on the high-beam wire to a pull-up and pass that to the Skene controller. Confirmed by another inmate that this throws an error (on the 1290 SAT at least).
  7. 3rdgeargrndrr
    Jan 19, 2017
    1,171
    Sacramento
    I believe CB was using sarcasm, he has a yearlong thread rant :flip trying to get his headlights to work
  8. gianmarco dambrosi
    gianmarco dambrosi Been here awhile
    Oct 29, 2015
    286
    italy
    this mornin was trying the same thing!!!
    instll skene iq275
    in 1290 adventure t
    same issue
    is all ok but the high beam signal
    i dont understand what is the switch here suggested
    high beam signal for white wire[​IMG]
    Inviato dal mio iPhone utilizzando Tapatalk
    #8
  9. Mad_Max
    Mad_Max Adventurer
    Aug 21, 2015
    59
    Sudbury, ON
    I did it on the 1190 R with no issues too, but the 1290 SAR is different. I’m watching this thread as I too am interested in a solution.
    Cheers
    #9
    Martyred likes this.
  10. gianmarco dambrosi
    Oct 29, 2015
    286
    italy
    #10
    Mad_Max and Kevlar49 like this.
  11. Kevlar49
    Kevlar49 Adventurer
    Jul 15, 2011
    47
    Millbrae, CA
    Bingo! Thank you! That’s exactly what I need. Inputs are switched 12v and ground (right behind the headlight) and the CAN HI and LO (easy to tap into on the headlight connector), and it outputs +12v with the high beam on.
    Looking for the cheapest retailer that will ship to the US. I’ll post up here when I’ve found that, and hopefully share my results in a few weeks.
    #11
    Mad_Max likes this.
  12. KTM 1190advR
    KTM 1190advR Enema of the state Supporter
    Aug 2, 2015
    3,343
    Somewhere in Norway
    Best price and global delivery:
    http://www.ncs-systems.com/car-elec.../miscellaneous-interfaces/canm8-highbeam.html
    #12
    Kevlar49 likes this.
  13. gianmarco dambrosi
    Oct 29, 2015
    286
    italy
    wich are the canbus wire of 1290 adventure t headlight?
    #13
  14. Kevlar49
    Kevlar49 Adventurer
    Jul 15, 2011
    47
    Millbrae, CA
    #14
    KTM 1190advR likes this.
  15. Martyred
    Martyred Been here awhile Supporter
    Jul 13, 2013
    554
    Germany
    All non-LED headlights on 1050/1090/1190/1290 Adventure beside the 1290 SA S/R have the same:
    #15
  16. gianmarco dambrosi
    Oct 29, 2015
    286
    italy
    so
    this is the wiring of my
    1290 super adventure T ?
    #16
  17. Martyred
    Jul 13, 2013
    554
    Germany
    Yes! Behind your headlight!
    Gesendet von meinem SM-G930F mit Tapatalk
    #17
  18. gianmarco dambrosi
    Oct 29, 2015
    286
    italy
    so i think have done a mistake
    i used the low beam wire
    green
    i’ll try the blue one
    is very strange , i choose the wrong wire,but the high beam trigger work also if the dash panel has signal error.....
    #18
  19. gianmarco dambrosi
    Oct 29, 2015
    286
    italy
    i tryied with
    blue wire
    definitely here in europe must be used different wiring
    it is not of high beam
    also verified in workshop manual,
    different scheme for US and EU
    #19
  20. Kevlar49
    Kevlar49 Adventurer
    Jul 15, 2011
    47
    Millbrae, CA
    Welp, back to the drawing board...
    #20
