Highway Dirtbike (HDB) 15% coupon - May 2011
Discussion in 'Vendors' started by Chadx, Apr 18, 2011.
  1. DougZ73
    DougZ73 Fading off.........
    Oct 10, 2009
    7,544
    NJ
    It is the one that is threaded and goes on the top clamp, in place of one of the switches. It did not come with a nut, so I got one at the local hardware store....3/8-16. I just went a little too far trying to snug it tight. This one here:
    By the way, for those that are curious about part numbers, the RAM ball that fits in the switch mounts of the HDB top clamp is RAM part number RAM-B-236U CLLICK HERE which is a 3/8"-16 with 1" ball available at many online retailers.
  2. jlpred
    jlpred Been here awhile
    Dec 22, 2005
    127
    Knoxville, TN
    No mirrors for me either! Item was circled with "BO". I also assume backorder. I shot an e-mail over to get an ETA. Kinda sucks as the mirror setup was a BIG selling point for me (I ride a lot of tight OHV trails).
  3. hockeylife
    hockeylife Adventurer
    Jan 27, 2008
    46
    Scottsdale, AZ
    Please count me in. Thanks
  4. ten_fiver
    ten_fiver Long timer
    May 4, 2008
    5,587
    SW Wyoming
    Nah, just the way the light is reflecting. All stock bezels.
  5. ten_fiver
    May 4, 2008
    5,587
    SW Wyoming
    Sounds like what my receipt looked like. I wouldn't worry about it though. From the Paul's response it sounds like he is pretty swamped from all of us cleaning him out. :lol3 He seems like a good dude, and I've heard nothing but the best about him. So I wouldn't stress, we'll get our mirrors soon enough.
  6. jlpred
    Dec 22, 2005
    127
    Knoxville, TN
    Not worried about getting shafted, just wanted to get install done. I guess mirrors should start going out soon. If Paul or Chad would like, I can copy/paste what I received via e-mail.
  7. Chadx
    Chadx my toot toot
    Oct 29, 2007
    2,177
    Bozeman, Montana
    Paul sent me an email saying mirrors were on backorder. He knows he currently owes 7 of you mirrors. He said he has glass coming in today so he can complete some and get them outbound. Such is the way it goes on some of these massive group buys with orders hitting all at once. Sorry for any delays, gents!
  8. Chadx
    Chadx my toot toot
    Oct 29, 2007
    2,177
    Bozeman, Montana
    DougZ73,
    No reason to go crazy tight on these. Just a dab of blue locktite and snug it up good.
    Good of you to post part of my RAM ball mount post. I'll go ahead and post a copy of my entire post so folks can see the other, and the recommended, RAM ball mounting option (the one that replaces any one of the top clamp bolts).
    There has been one incident, on an older, out of production top clamp, where the above method of mounting broke out the top clamp switch area after a crash. I know of no other issues and have run my GPS on this type of mount, without incident, for around 6,000 miles. Still, the below mount option is even stronger and, therefore, recommended.
    The following is RAM part number RAM-B-367U CLICK HERE that replaces one of the top clamp bolts.
    Mounted up, one of those looks like this (you can use it in any one of the four corners). Picture courtesy of ADVrider's K7MDL:
  9. 6USMC6
    6USMC6 -U-
    Jan 5, 2009
    4,891
    Chad -
    I was out in the shop measuring the 950 (stock pattern is 90 x 38/40) and thought it might be a good idea to go ahead and install the Rox risers I had first and re-measure.
    Sure enough, it came out 103 x 38/40 and I don't see a clamp in that size.
    I can Order a 106x38/40 and move the Rox risers out 1.5mm each side or, mill 1.5mm off of the KTM handlebar mounts and move the risers in 1.5 for a 100x 38/40. Which should then fit a Scotts Steering Damper when I order it this fall.
    Make sense?
  10. BlueMountain
    BlueMountain Adventurer
    Feb 28, 2011
    25
    Denver
    Count me in, please. Besides post here, do I need to do anything else to get my coupon? Thanks!
  11. Chadx
    Chadx my toot toot
    Oct 29, 2007
    2,177
    Bozeman, Montana
    You must have the ROX anti-vibration risers. The plain Rox Risers tend to retain the stock bolt spread. Yes, a slight adjustment in or out of the ROX risers allows them to accommodate various top clamp patterns. For the benefit of those not familiar with ROX risers, this is possible because the ROX risers are two independent risers and are not connected to one another. Usually one can move the ROX risers out a small amount but not it.
    If you measured and have a bit of inward leeway and can get them to work with the 100mm wide top clamp and you also plan to do a Scotts submount in the future, then that would be the best route. If you can't get them to slide in tight enough for a 100mm wide topclamp, then going wider would likely be your only solution...that or order your Scotts submount sooner rather than later. Poke. Poke. :amazon Ha.
  12. Chadx
    Chadx my toot toot
    Oct 29, 2007
    2,177
    Bozeman, Montana
    Nothing more to do. I'll add you to the list. I'm nearly done sending out the Phase II coupons (staggering the coupon releases to not overload Paul) so you should get your coupon PM within a day or two.
  13. ten_fiver
    May 4, 2008
    5,587
    SW Wyoming
    Paul's going to need a vacation after all of this. My hat's off to him. :freaky
    And, HDB decals would be pretty cool as well.
  14. JWarner
    JWarner Adventurer
    Sep 15, 2008
    23
    HLYWD
    Been reading this entire thread and now I'm sold. I'd love these guards and top clamp. Looks like I'm going to have a 990 at the end of June. But I was also wondering if there's a chance the top clamp and guards would work on a new Multidtrada. May I be added to the end of the list for the coupon?
    Thank you,
    JW
  15. 6USMC6
    6USMC6 -U-
    Jan 5, 2009
    4,891
    No, they are the standard Rox Risers. The 950 KTM's have a lip on the outside of the handlebar mount that makes them wider than others. I.e., the holes in mounts are not equally spaced.
    However, based on that, if the Rox are 16 nn wider than the stock KTM mounts then using the ROX on the Scotts sub should be 16mm wider.
    Since I have a few more days (the 15th, right?), I'll see if I can dind someone locally with a Scotts that I can measure and see what works. I could change risers too, but I'm short and need the pull back that the Rox have.
    Now I am beginning to wonder what will happen if I try to use the Rox on the Scotts sub mount. If it utilizes a 100mm HDB mount the Rox will make the spacing wider.
  16. Delta88
    Delta88 Knurly Adventurer
    Sep 29, 2006
    392
    The Holy City of Kent, WA
    +1 on the decals and +1,000 on the vacation.
  17. Chadx
    Chadx my toot toot
    Oct 29, 2007
    2,177
    Bozeman, Montana
    Hi guys,
    As far as I know, a coupon PM has been sent to everyone on the list. Check your PMs and if you have NOT received your coupon PM, please PM me. (that's a lot of PMing). :lol3
  18. johnwesley
    johnwesley wanta be
    May 11, 2006
    3,219
    mena, Ar
    thanks for the code. I have mine on order should help me bullet proof the adv machine
  19. FYYFF
    FYYFF Forever young...
    Jun 9, 2009
    2,244
    SoCal
    I got my top clamp and hand guards along with mirrors last month and very happy with them.
    But now I need bar raisers and need help to choose one. Any suggestions, recommendations for one that will work with HDB top clamp?
    Am I gonna have problems with control cables if I go with HDB Tall raisers? What is the hight of those two kind of raisers?
    Thanks.
  20. ten_fiver
    May 4, 2008
    5,587
    SW Wyoming
    Why not try the hdb's?
