Hodakaguy's Overland Tacoma Builds - on to new adventures.
Discussion in 'Shiny Things' started by Hodakaguy, Dec 31, 2017.
  1. Mr. Fisherman
    Mr. Fisherman Back in Black!
    Oct 8, 2006
    13,070
    Trying to tame the Snake!
    Some drive lines, like the ones on my Titan are balanced. Indexing them maintains the balance.
    #61
    TooFast likes this.
  2. farleywilbur
    farleywilbur Been here awhile
    Dec 14, 2005
    189
    The Great White North, eh?
    Love those wheels...
    #62
    Hodakaguy likes this.
  3. swimmer
    swimmer armchair asshole
    Oct 9, 2007
    19,986
    Tucson, AZ
    May want to do the ECGS bushing install while you've got the front drive apart....
    #63
  4. Hodakaguy
    Hodakaguy NorthWest Adventure Rider Supporter
    Jul 30, 2007
    3,115
    Eastern WA State
    Yep I have the bushings waiting on the counter :-)
    Hodakaguy
    #64
  5. SRG
    SRG Long timer
    Nov 18, 2004
    3,462
    Central Va.
    Cool wheels. They look very strong. Are they heavy? - they kinda look it.
    I "dub" them the "manhole covers".
    #65
    Hodakaguy and Weekend_warrior like this.
  6. Laconic
    Laconic Tired of Your Propaganda
    Sep 28, 2007
    29,766
    The Gaslight District
    I hate your threads. They make me want to spend money. :D
    #66
  7. keepshoveling
    keepshoveling DNF
    Oct 9, 2014
    5,206
    NYC
    Yeah, just need to buy a huge shop, some land out west and a metric ton of fabrication lessons.
    #67
  8. Hodakaguy
    Jul 30, 2007
    3,115
    Eastern WA State
    They are actually pretty light :-)
    Hodakaguy
    #68
    keepshoveling likes this.
  9. Hodakaguy
    Jul 30, 2007
    3,115
    Eastern WA State
    Was able to get a little done on the truck after work tonight, not a lot of progress...but progress non the less.
    Time to get the remote reservoir mounted up. The brackets that support the Res also acts as a sway bar drop bracket, everything is very well made and thought out.
    This mud cover needs to be removed to install the bracket for the reservoir.
    The bracket will go between the sway bar mount and the frame.
    Res brackets.
    LOCTITE 243 Used on the threads, I like 243 vs 242 since the 243 is oil resistant and isn't as picky on having ultra clean threads like the 242.
    Bracket in Place.
    Reservoir mounted in place
    I re-installed the mud shields over the reservoir to help keep the engine bay clean.
    Next up remove the passenger side UCA. The bolt on this side interferes with the sheet metal as well.
    A little slight bending and the bolt slides right out. There is a lot more clearance on this side for the bolt to pass through, this side went a lot quicker.
    UCA geased up and installed.
    And the passenger side reservoir bracket installed and torqued.
    That's all for tonight, more to come soon.....
    Hodakaguy
    #69
    Dukehunt, Te Hopo and keepshoveling like this.
  10. Adam E
    Adam E returns shopping carts Supporter
    Nov 20, 2007
    8,459
    Live Free or Die
    ... You've probably done more tonight by accident than I've done on purpose. :D
    #70
  11. yankeeone
    yankeeone Been here awhile
    Mar 3, 2011
    362
    Hodakaguy.
    Nice work, I just bought a 2007 4runner, the suspension and frame look very similar to your truck. I see that many of the large holes in the frame are plugged , do you know when toyota started doing that?
    I think I will try and get some for my frame.
    #71
  12. Hodakaguy
    Jul 30, 2007
    3,115
    Eastern WA State
    Not sure when Toyota started doing that, I would imagine that aftermarket or factory plugs could be had fairly cheap though.
    Hodakaguy
    #72
  13. eatpasta
    eatpasta Lawnmower Target Supporter
    Jul 5, 2006
    16,517
    Santa Barbara, Ca
    Is it bad that I think this is sexy....?
    :shog
    #73
  14. yankeeone
    Mar 3, 2011
    362
    Thanks , I tried the Toyota parts department today , they didn't have a part number for the plugs , I see numbers on the plugs in your frame , could you zoom in on the two rectangular ones ?
    I think the plugs will really help the frame here in Mass. salted roads.
    #74
  15. Hodakaguy
    Jul 30, 2007
    3,115
    Eastern WA State
    Here's a picture, they both have a dot and a "4" on them.
    Hodakaguy
    #75
  16. Hodakaguy
    Jul 30, 2007
    3,115
    Eastern WA State
    Tonight's after work Update..........
    Passenger side front shock assembly removed.
    OME Shock and Res installed, Mud cover re-installed.
    Moving to the back. Drivers side rear leaf spring removed.
    OEM and OME Dakar springs side by side. Have to do some touch up painting on the new springs since shipping wasn't kind to the paint. New OME bushings installed in the springs.
    Aligning the holes to re-install the bolts into the springs. Giant crescent wrench makes the task easy :-)
    Dakar springs installed.
    Next up....Firestone Air Bags and Daystar Cradles.
    More to come soon....
    Hodakaguy
    #76
  17. yankeeone
    Mar 3, 2011
    362
    Thanks for the closeup, I really like the whole front end engineering on these trucks.
    #77
  18. jkam
    jkam Nomadic Man
    Jul 8, 2001
    10,634
    Somewhere out there
    #78
  19. Hodakaguy
    Jul 30, 2007
    3,115
    Eastern WA State
    Nope...they all come with drum in the rear. I know....weird.
    Hodakaguy
    #79
  20. jkam
    jkam Nomadic Man
    Jul 8, 2001
    10,634
    Somewhere out there
    Conversion kits using 4Runner parts are available.
    Sounds like something you would want to have.
    #80
