Hodakaguy's Overland Tacoma Builds - on to new adventures.
Discussion in 'Shiny Things' started by Hodakaguy, Dec 31, 2017.
  1. HardWorkingDog
    HardWorkingDog Super Ordinary
    Aug 20, 2009
    4,239
    Walnut Crick, Cal.
    Why are there double bushings on the rear end of the OME leaf spring? Guessing for a lift? But not on the front?
    #81
  2. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    17,318
    Orange County, CA
    It’s the leaf spring shackle
    #82
  3. HardWorkingDog
    Aug 20, 2009
    4,239
    Walnut Crick, Cal.
    ahh, got it.
    #83
  4. Camarodude
    Camarodude Been here awhile
    Sep 13, 2013
    690
    Oregon
    If the wheel cylinder and caliper piston sizes are not roughly the same size, wouldn't something have to be done with the proportioning valve?
    #84
  5. eatpasta
    eatpasta Lawnmower Target Supporter
    Jul 5, 2006
    16,517
    Santa Barbara, Ca
    :lurk
    #85
  6. Hodakaguy
    Hodakaguy NorthWest Adventure Rider Supporter
    Jul 30, 2007
    3,115
    Eastern WA State
    Today's Progress.
    Started back on the drivers side rear. Here I'm installing the new bracket for the lower shock mount. A new hole is required here as part of the mount.
    Shock installed, I love the integrated rock shields for the shaft on the shock....all shocks should come with this feature! I put a dab with a yellow paint pen on each bolt that has been torqued to final specs. Some bolts will need to wait until the truck is setting on the tires again before receiving final torque.
    Rear shock installed...minus the res mount.
    The upper assembly for the Firestone air bags. The instructions show the big silver through bolt turned around the other way but it extends to far that way and will interfere with the reservoir mount, if your running both airbags and OME shocks the bolt needs to be oriented in this direction.
    Reservoir mount installed
    Getting ready to have the tires mounted on the new wheels, we removed my fathers front wheel to verify clearance on the calipers before diving in and having the tires installed. Calipers cleared so mounting is a go!
    Tires mounted up. The wheels are AX201 16"x8" Zero Off Set, Tires are BFG KO2 285/75-R16. Here the tire is just leaned up against the hub to get a sneak peak on how it's going to look, the tires won't stick out this much once mounted properly. I really like the look against the Quicksand.
    RCI Sliders showed up today, these babies are very solid and quality looks very good as well. Can't wait to get them painted and on the truck.
    Got the passenger side rear spring installed and the upper portion of the air bags loose fit. That's enough for today.
    Hodakaguy
    #86
  7. swimmer
    swimmer armchair asshole
    Oct 9, 2007
    19,986
    Tucson, AZ
    The truck should have rear discs but in reality there would be little to no performance benefits. If I recall correctly the Tacoma has a shorter stopping distance than it's nearest competition, the GM twins. Maybe if the rear was heavily weighted??
    I'd cautious as far as the disc conversion goes. With crawl control, the "LSD", MTS, etc.. modes all interacting with brake line pressure I'd want to be sure changing the braking mechanism didn't knock that shit out of its normal operation parameters. I'd just make sure someone with the exact same truck package had vetted that out fully before committing.
    #87
    Tallbastid, Te Hopo and jersey jim like this.
  8. Hodakaguy
    Jul 30, 2007
    3,115
    Eastern WA State
    There are people working on it....I don't have any desire at this point to install rear disk though.
    Hodakaguy
    #88
    Tallbastid and scot_douglas like this.
  9. jersey jim
    jersey jim Long timer
    Oct 6, 2008
    2,380
    ...somewhere in the swamps of Jersey...
    I love my 2nd gen '15 Tacoma TRD Sport, but if I was to buy a 3rd gen it would be just like these, quicksand TRD Off Road. And the black wheels will set it off just right. I'd probably go with the 4Runner TRD Pro wheels personally, I love those wheels. The good suspension parts and gearing upgrade are icing on the cake. Looks like an awesome project. Looking forward to seeing these things in the wild when they're done.
    #89
    Hodakaguy likes this.
  10. swimmer
    Oct 9, 2007
    19,986
    Tucson, AZ
    I have the TRD Pro wheels on my 16' Tacoma TRD OR, but the truck is silver and the wheels are the grey ones.
    #90
    Hodakaguy and jersey jim like this.
  11. villageidiot
    Apr 29, 2010
    17,318
    Orange County, CA
    With regard to your yellow paint dots..... when i paint mark a torqued bolt, i make sure to dab it in the bolt threads as well. How else will you know if something is coming loose.
    thats just my version of OCD
    BTW, truck looks great!!
    #91
    Night_Wolf, Hodakaguy and manstache like this.
  12. manstache
    manstache Flounder of ADV
    Apr 3, 2010
    1,861
    Around
    #92
    crk and villageidiot like this.
  13. FishHunt
    FishHunt slow poking...
    Jun 6, 2009
    3,047
    Randolph N.C.
    Nice trucks and great choice going with OME. I had a Wrangler with one of their lifts and the quality of there springs and parts was outstanding.
    <>< Fish
    #93
    Tallbastid likes this.
  14. beemerkid
    beemerkid Do you ADV
    Feb 14, 2009
    1,808
    Seward, AK
    I just picked up a set of their skid plates at the factory for my f150, and they are nice stuff. I wish they made the sliders in my cab length so I could have gotten them too.
    #94
  15. Hatch
    Hatch Perpetually lost
    Sep 23, 2007
    5,374
    719
    Question: what are you guys using for bolt marking? Paint pens?
    #95
  16. villageidiot
    Apr 29, 2010
    17,318
    Orange County, CA
    at work, i take a little "safety yellow" and shoot it into the cap of a spray paint can, and dab it on with a skewer, its pretty much how mercedes did it back in the day (50's and 60's)
    i also use the paint pens on things i build on the bench. but they don't "flow" very well.
    #96
    Hatch, crk and Hodakaguy like this.
  17. Hodakaguy
    Jul 30, 2007
    3,115
    Eastern WA State
    I've done that in the past as well, it's a good practice. I used to have some tubes of Torque mark, it's thicker and very easy to spot when cracked...Link: CLICK HERE.
    Hodakaguy
    #97
    Hatch and villageidiot like this.
  18. Hodakaguy
    Jul 30, 2007
    3,115
    Eastern WA State
    It looks like quality stuff, very HD and well built. I built sliders for our VW Syncro but didn't want to have to make two sets this time around. Not sure what I'm going to do for skid plates yet.
    Hodakaguy
    #98
  19. Hodakaguy
    Jul 30, 2007
    3,115
    Eastern WA State
    Not a lot of time to work on the truck today, I did manage to finish up the passenger side rear suspension early this morning.
    Passenger side all buttoned up except for the lower air bag mounts/cradles.
    The lower air bag mount is suppose to rest on the axle on the outer edge but with the thicker Dakar spring pack it hangs in the air 3/4" off the axle (bracket is sitting on backwards for picture). I will modify the lower brackets to get proper contact back before mounting.
    Going to place the sliders up onto the truck for a sneak peak....
    Well at this point my super squirrel powers took over and I jumped off the slider project and used the rest of my limited time to whip up a power brake bleeder. I'll use this bleeder when I install the new brake lines and re-install the calipers. These bleeders work really slick, way better than a vacuum bleeder and lets you easily bleed the system by yourself. The tank adds a bit of air pressure to the reservoir and when you open the bleeder it pushes the fluid out without having to pump the brakes, just need to check the fluid level in the reservoir often so you don't run low and push air into the system again. You can buy purpose built units but they are around $50 for the cheapest ones, I already had an extra small weed sprayer so I just needed a spare brake reservoir cap. My spare cap came in today so it's time to get it ready for the upcoming brake work.
    New brake reservoir cap and brass fitting that will connect the cap to the weed sprayer.
    Hole drilled in the new cap.
    The brass fitting was threaded into the plastic cap with two part epoxy to ensure a tight seal. Cap is now ready to use.
    Ready to bleed some brakes! (I'll add a small pressure gauge on the tank body to monitor air pressure)
    More to come....
    Hodakaguy
    #99
    wee-twin, Te Hopo and crk like this.
  20. Brainflex
    Brainflex Been here awhile
    Jul 17, 2009
    194
    Whakatane, Bay of Plenty
    Put brake fluid in the weed sprayer and it will automatically top up the master cylinder.
