Hodakaguy's Ural Gear Up...Mods, Pics & Adventures!
Discussion in 'Hacks' started by Hodakaguy, Nov 1, 2020.
  1. windmill
    windmill Long timer
    Feb 18, 2008
    6,578
    Kent, Washington State
    Back in the early days CSMI, the pre factory importer, specified adding Hyperlube to the engine, transmission, and FD. Not because it provided any extra protection, but because it subdued all the mechanical noise that was alarming to western ears. :lol3
    Tmaximusv and Hodakaguy like this.
  2. Hodakaguy
    Hodakaguy NorthWest Adventure Rider Supporter
    Jul 30, 2007
    3,093
    Eastern WA State
  3. Hodakaguy
    Jul 30, 2007
    3,093
    Eastern WA State
    Yep both good products, I ran Swepco in my VW Syncro.
    Hodakaguy
    Strong Bad likes this.
  4. windmill
    windmill Long timer
    Feb 18, 2008
    6,578
    I've tried countless oils over the years, and finally settled for Valvoline VR-1 20w-50, Valvoline 75w-90, and a qt of Hyperlub divided between the engine, transmission, and FD at a ratio of 560ml, 400ml, 40ml respectively. I can usually find them on sale locally in the $6 per qt range.
    I figured since the extra .6l of oil in the new oil system calls for buying another qt of something, why not the Hyperlub, its cheap.
    Hodakaguy likes this.
  5. Strong Bad
    Strong Bad Former World's Foremost Authority Supporter
    Oct 29, 2007
    12,416
    Omicron Persei 8
    AAAAHHHH!!! Not another Oil Thread!!!!!
    My apologies, I’m certainly not bashing any particular gear oil someone else uses. I just wanted to add a couple of other oils I have experience with and use in addition to the Red Line mentioned.
  6. windmill
    windmill Long timer
    Feb 18, 2008
    6,578
    Good info. I don't think anybody took it as bashing.
    Hyperlub is definitely snake oil, and I question most of its claims, but use it because it really does reduce mechanical noise, and smooth shifting like much more expensive oils.
  7. TurTal
    TurTal Long timer
    Jul 30, 2015
    4,616
    The Ural could give 2 shits about what oil it uses
    It's a fuel injected Tractor
    It doesn't make less noise or shift any smoother or go any faster or run any cooler whether you're running high dollar synthetics or dead dinosaurs...that's perception
    What it does care about is frequency
    Click off 2k and then change all the fluids and filter religiously and the Ural will be just fine for a long long time
    DaFoole, rg sw wa., Rakthi and 2 others like this.
  8. windmill
    windmill Long timer
    Feb 18, 2008
    6,578
    A few oils like Redline heavy, and Hyperlub do subdue gear whine at speed, and do smooth out shifting.......especially clumsy shifting, and some of us are more clumsy than others. :augie
    Running cooler? Reduced wear? Meh, I doubt it and don't worry about it. I agree, doing scheduled maintenance as required is the real key to long term reliability
    rg sw wa., Hodakaguy and brstar like this.
  9. Hodakaguy
    Jul 30, 2007
    3,093
    Eastern WA State
    We will have to agree to disagree here. I've tried 20w-50 back to back with the Heavy Shockproof and there is a noticeable improvement in shifting. I'm happy with it and will continue to run it, your results may vary.
    Agreed proper interval changes are important, but lubrication can make a difference.
    People call Unimogs old road going tractors as well but lubrication can drastically help shifting in those as well. Most run Redline MT-90 in the Unimog trans with excellent results, again it made a noticeable difference in my U1300L Mog as well. Just because something is "old" technology doesn't mean modern lubes can't improve them.
    Hodakaguy
    rg sw wa. likes this.
  10. Hodakaguy
    Jul 30, 2007
    3,093
    Eastern WA State
    Lol...it's all good. Any time you post about ANY oil your going to get 500 different opinions :-). Thanks for the post
    Hodakaguy
  11. Strong Bad
    Oct 29, 2007
    12,416
    Omicron Persei 8
    I must admit you are the only other guy on this site that has eve heard of SWEPCO, let alone used it! :beer
    brstar likes this.
  12. Hodakaguy
    Jul 30, 2007
    3,093
    Eastern WA State
    Quite a few VW guys use it :beer
    Hodakaguy
  13. TurTal
    TurTal Long timer
    Jul 30, 2015
    4,616
    You have my permission to do what ya want
    I'm a professional so I'll continue using the best oil on the market for my High performance desert Gear Ups
    I saved enough money on fancy oil to buy another Ural
    DaFoole, brstar and Hodakaguy like this.
  14. Hodakaguy
    Jul 30, 2007
    3,093
    Eastern WA State
    Sweet, you can have a whole fleet :D
    Hodakaguy
    TurTal likes this.
  15. TurTal
    TurTal Long timer
    Jul 30, 2015
    4,616
    I will admit the only issue I really have is when I get back from a long ride my GUP always smells like Kentucky fried chicken
    Came out one morning to find a kitty cat goin to town on my drain plug
    Guess a little bit weeped out
    Next time I'm gonna put out some mash taters and gravy to go with it
    Geno89074 and phughes like this.
  16. Bar None
    Bar None OLD DUDE Supporter
    Mar 2, 2007
    14,322
    SWFL WNC
    Hey TT, I resemble that remark. I have three fuel injected tractors and soon will have four when my cT gets here.
    DaFoole, TurTal and Hodakaguy like this.
  17. Bobmws
    Bobmws Curmudgeon At Large
    Jun 6, 2005
    4,487
    Same trailer, different park, FL
    We used Swepco in our watsewater & sludge pumps. Seemed to lengthen rebuild intervals in a high abrasive & caustic environment.. Why yes, I do know Jack Shit! ;)
    Damn SB, 2 days in a row you've kicked up old memories for me!
    Hodakaguy, Strong Bad and rg sw wa. like this.
  18. Strong Bad
    Oct 29, 2007
    12,416
    Omicron Persei 8
    Haha! Sorry, I didn't know you too were familiar with Swepco! OK, anyone else? :lol3
    Bobmws and Hodakaguy like this.
  19. TurTal
    TurTal Long timer
    Jul 30, 2015
    4,616
    Fun Fact
    Originally Swepco was developed as a laxative
    It "Swep" the "Colon"....hence the name Swepco
    You'll notice if it gets burnt or has been used a long time it starts to smell like poo
    That's why I don't use it in my machines
    Makes em run like shit
    DaFoole and phughes like this.
  20. Strong Bad
    Oct 29, 2007
    12,416
    Omicron Persei 8
    Apparently you are using a different SWEPCO than the rest of us! :rofl:rofl
    Try the products made by the Southwestern Petroleum Company.
    https://www.swepcolube.com/about-sw...arkets,Fluids and Industrial Spray Lubricants.
    But then, any gear lube that gets way too hot (burnt) has a very distinctive odor that wll never wash out of your clothes. Get that stuff on your clothes and throw them away when you are done.
