Hodakaguy's Ural Gear Up...Mods, Pics & Adventures!
Discussion in 'Hacks' started by Hodakaguy, Nov 1, 2020.
  1. TurTal
    TurTal Long timer
    Jul 30, 2015
    4,616
    This is the stuff I'm talkin bout
    The 210 denotes 2 tablespoons and 10 seconds to get to the shitter
    It works great for what it was originally designed for
  2. windmill
    windmill Long timer
    Feb 18, 2008
    6,578
    Kent, Washington State
    There's more than one kind of Ural too.
    phughes, rg sw wa. and Bobmws like this.
  3. Strong Bad
    Strong Bad Former World's Foremost Authority Supporter
    Oct 29, 2007
    12,416
    Omicron Persei 8
    Yes but, is there anything for the Uralista Butt Rash "Foilheads" get when people say bad things about their bikes?
    Hey new term!! UBR!!
    phughes, TurTal and rg sw wa. like this.
  4. windmill
    windmill Long timer
    Feb 18, 2008
    6,578
    Available at any BMW dealer......
    :amazon
    DaFoole, phughes, rg sw wa. and 3 others like this.
  5. Bobmws
    Bobmws Curmudgeon At Large
    Jun 6, 2005
    4,487
    Same trailer, different park, FL
    Another 'end' user who disregarded the instructions............
  6. jphii
    jphii OK, now what?
    Oct 29, 2008
    5,349
    Greenville, NC
    501 diesel additive and 313 two stroke oil....
  7. Hodakaguy
    Hodakaguy NorthWest Adventure Rider Supporter
    Jul 30, 2007
    3,093
    Eastern WA State
    Time for a decent shifter!......
    I'm one of the few it seams that hates the Urals heal shifter, I find the heal shifter to be awkward at best and very un-ergonomic, it's located way to high and causes one to lift your foot off the peg and twist it a bit to engage the shifter with your heal. I can consistently get smoother/better up shifts by using my toe and timing shifts than when using my heal. The stock shifter has a sharp metal edge under the rubber pad and will tear up your riding boots over time if it's used to toe shift.....time for a change.
    Here's the stock shifter unit, minus the rubber pad on the front portion that decided to part ways with the bike on the last ride lol.
    I ordered up a 2-1/8" x 1" universal rubber shift tip from amazon....this should work nicely. Now on to modification.
    With the shifter assembly off the bike the modifications can begin
    Clamped in the vice, the Portaband makes quick work of removing the OEM tip.
    Next up I needed to change the angle of the remaining tab on the stock shifter...The vice and a giant crescent wrench made easy work of this task.
    Rounding the front edge a bit
    Now to mark and drill the the hole for the new shift peg.
    Metal painted and now Installing the new shift tip onto the shifter. I'll swap this nut out soon to a lock nut.
    Adding a bit of grease to the shift splines.
    And back on the bike. Now I have a comfortable toe shifter that won't tear up my boots :-)
    Hodakaguy
    DaFoole, zundappuk, Tourist64 and 9 others like this.
  8. JimVonBaden
    Feb 11, 2005
    93,743
    Alexandria, VA
    Just curious why you retained the heal part of the shifter?
    Hodakaguy likes this.
  9. Strong Bad
    Oct 29, 2007
    12,416
    Omicron Persei 8
    I bet even a Hodaka shift lever would have fit on the Ooral’s shift shaft.
  10. trumpet
    trumpet Group W Bench
    Aug 2, 2008
    4,452
    Connecticut
    @Hodakaguy , personal question; but what size boot you wear? My size 13 feet don't even fit in there to shift or brake.
    zundappuk likes this.
  11. Hookalatch
    Hookalatch Born Under Bad Sign
    Feb 8, 2006
    1,258
    Cottonwood, CA
    Love that vice stand. What is that piston out of?
  12. Tmaximusv
    Tmaximusv Separated at birth
    Jun 19, 2012
    4,310
    Gateway to the Sandhills
    Boat. Big boat.
    DRONE likes this.
  13. TripleDaddy
    TripleDaddy Hoping my skills exceed my horsepower
    Aug 31, 2010
    2,148
    Westfield, IN by US 32 and Shady Nook
    Good mod. I figured it's cheaper to do this than screw up the toe on a good pair of boots. I installed one of the "old" Ural shifters on mine.
    https://advrider.com/f/threads/help-me-make-my-sidecar-better-a-2013-ural-tourist.1260309/page-4
    Bar None, Hodakaguy and DRONE like this.
  14. Hodakaguy
    Jul 30, 2007
    3,093
    Eastern WA State
    Just options in case I ever wanted to use it....although I doubt I ever will again lol :-).
    Hodakaguy
    Bar None and JimVonBaden like this.
  15. Hodakaguy
    Jul 30, 2007
    3,093
    Eastern WA State
    Not to likely in this application....but it would be cool to sneak a Hodaka part onto the Ural :-)
    Hodakaguy
    Tmaximusv and Strong Bad like this.
  16. Hodakaguy
    Jul 30, 2007
    3,093
    Eastern WA State
    Size 10 here. The shifter Mod I did could be made with the shift tip further out to compensate for larger boots. I'm going to offer up a Ural shifter modification service for others that want the mod and don't want to do the work themselves.
    Hodakaguy
  17. Hodakaguy
    Jul 30, 2007
    3,093
    Eastern WA State
    Out of an industrial engine that powers natural gas compressors. See below for more info and pics :-)
    Hodakaguy
  18. Hodakaguy
    Jul 30, 2007
    3,093
    Eastern WA State
    Nope....but I always wanted to work on a large marine engine. See below for details on this one.
    Hodakaguy
  19. Hodakaguy
    Jul 30, 2007
    3,093
    Eastern WA State
  20. Hodakaguy
    Jul 30, 2007
    3,093
    Eastern WA State
    Big Bore Piston Upgrade!!
    If I can just get it to fit think of the low end torque......although yes fuel mileage may suffer a tad :D
    The power piston is out of a 1955 Ingersol Rand KVS Engine/Compressor. The engine is a single turbo natural gas fired V-6 unit that develops 1000hp at 330 rpm and drives two double acting integral compressors that are used to pump natural gas. This piston was changed out due to exceeding out of round specifications. Bare piston weights 400 lbs and the valves have a 1" stem.
    The piston has two threaded holes in the dome of the piston used to remove the piston from the liner, I fabricated an adapter plate that bolts onto the piston using these holes and allows me to bolt the vice onto the plate.....Bam vice stand. The piston works great as it's heavy enough to hold the vice in place but easy to twist and "Walk" the assembly around the shop as needed.
    Just your standard Chevy 350 :-). The lifters are hydraulic and a single head weights about 700 lbs.
    A quick video showing the rocker arms in action
    Hodakaguy
