Hodakaguy's Vagabond Camper/Truck Build....Yes Again!
Discussion in 'Camping Toys' started by Hodakaguy, Dec 21, 2018.
  1. bobfab
    bobfab Long timer Supporter
    May 11, 2009
    2,308
    Limerick, PA
    X2 dont know how I missed this, didn't you get a Sprinter somewhere along the way?
    In for another great build!
    #81
  2. drbeemer73
    drbeemer73 Adventurer
    Mar 30, 2015
    13
    Glenmoore, PA
    #82
    local1 likes this.
  3. ericm
    ericm Long timer
    Sep 12, 2002
    1,901
    Santa Cruz Mountains, California
    That would deserve it's own thread once there are pics.
    #83
  4. mbabc
    mbabc Curmudgeon trainee
    May 28, 2007
    3,391
    Louisville, KY
    Love my Propex in my InTech camper. Works fantastic. Did have a Mr. Buddy but like you hated the water vapor and smell.
    #84
    katbeanz and Bultaco206 like this.
  5. Monroe
    Monroe Long timer
    Nov 11, 2007
    2,151
    under my rock
    I believe this thread will cause some damage to my checking account. Been eyeballing a Propex for my FWC.
    Great thread....................
    #85
    katbeanz, Hodakaguy and mbabc like this.
  6. Hodakaguy
    Hodakaguy NorthWest Adventure Rider Supporter
    Jul 30, 2007
    3,004
    Eastern WA State
    Yeah I'm SLOWLY building out a sprinter, the Tacoma/Vagabond is my fathers rig. Here's a link to the Sprinter build: CLICK HERE
    Hodakaguy
    #86
    katbeanz likes this.
  7. Hodakaguy
    Jul 30, 2007
    3,004
    Eastern WA State
    Looks great! You'll love the Propex!
    Hodakaguy
    #87
  8. Hodakaguy
    Jul 30, 2007
    3,004
    Eastern WA State
    The Propex would be a great fit for the FWC! Post up some pics when you get it installed.
    Hodakaguy
    #88
  9. Hodakaguy
    Jul 30, 2007
    3,004
    Eastern WA State
    Time to get some Solar installed on the Vagabond! Solar is great peace of mind when running an electric fridge, heater etc as your batteries are always topped up and ready to go. I prefer roof mounted solar since it's always working plus you don't have to mess with storing the panels when not in use and taking up valuable interior space.
    After looking at panel sizes we selected a Renogy 160W Mono panel, this panel fit perfectly between the factory L-Track rails and won't overhang the camper. Here we're trying the panel on for size, that should work nicely!
    The panel will be bolted down to the L-Track using 4 adapters and custom mounts. The adapters lock into the L-track.
    With the panel fit tested we popped the top up to locate the location of the solar wiring. When we ordered the camper I requested that solar wiring be placed in the front passenger corner but left un-terminated, the other end of the wiring is down below in the walls. Lots of room to play with here for wiring.
    Next up it's time to install the cable gland pass through fitting for the solar wiring. I'll be using a Seaview Cable Gland, I've used these several times in the past and have never had one leak. These are available in different sizes and colors, we went with the Stainless Steel housing.
    Here's the location where the cable gland will be installed. The gland will be placed towards the rear of the solar panel so there will be enough slack to slide the panel back on the L-track if we ever want to add a front Yakima rack etc, Always good to have options :)
    Here are the parts of the cable gland. The bottom gasket and white body assembly get bolted down to the roof of the camper. The wires will pass through the tapered rubber seal and the stainless top will screw down to the white body and compress the rubber seal, forming a water proof seal around the wires.
    Holes drilled and screws installed. The roof is 1/8" thick aluminum so even with a pilot hole you need to work the screws in slowly to prevent them from breaking off.
    You need to apply some sealant on the base screws to ensure a water proof connection. Here I'm using Sikaflex 221 to seal the screws.
    Next up we need to drill holes in the rubber seal for the wires to pass through. You need to make sure your brill bit is slightly smaller than the wire that will pass through the hole so there will be compression on the wire when you tighten the assembly up, compression is what creates the waterproof seal.
    The cut will allow the wiring to be inserted easily even if there is a plug on the end of the wiring (Won't be in this case)
    At this point you drill the hole through the roof for the wires to pass through, I put the rubber seal in the pass through fitting and use a drill bit to mark the hole locations. Once the holes are drilled you assemble the cable clam and tighten everything down using more Sikaflex on the upper 4 screws.
    It's really not necessary but I added a bit of Sikaflex to the top of the assembly as an extra measure.
    Wiring placed in a small piece of loom and ready for assembly. You can see how far we will be able to slide the panel rearwards if needed in the future, for now we will keep the panel fully forward to ease in opening and closing the top.
    Next up is to fabricate some brackets to attach the solar panel to the L-track. We will be using some scrap stainless steel angle iron that we had on hand.
    Cutting out the strips.
    The solar panel is slightly narrower than the L-track so the brackets will have to overhand the panel a bit, I'll taper them in at the top to give them a bit more pleasing appearance.
    And mounted up.
    The roof of the Vagabond has an X rolled in it for added strength but this makes the roof get higher as you approach the center. The solar panel just clears the roof when mounted directly on top of the L-Track adapters, if the panel is slid rearwards washers will need to be added to raise the panel and clear the roof.
    With the panel mounted it's time to pop the top and finish up the wiring. Here you can see the solar wiring passing through the roof.
    Wiring extended and attached to the factory Vagabond wiring.
    Wiring in Loom and attached to the ceiling, there is enough slack in the corner to allow flex when opening/lowering the roof.
    The other end of the factory solar wiring was located behind the aluminum corner panel.
    I'll be installing a BlueSky 3000I MPPT solar controller to manage the power produced by the solar panel. I've used this controller a couple times in the past and it worked great.
    The controller will be mounted on the side of the heater box to prevent damage to the unit from stuff getting slid in and out of the truck. The interior of the heater box is vented and stays cool even when the heater is in operation so this should be a good environment for the controller.
    Laying out the cut lines.
    And hole cut, edges haven't been cleaned up yet in this pic.
    Controller mounted.
    You can't tell but it's about 110 deg inside the camper while I'm doing the install! I forgot to take pictures while routing and wiring the controller.
    Mattress re-installed and another shot of the panel wiring. I didn't have a small bolt on fairing to clean up the penetration point on hand so I'll be adding that at a later date.
    Wiring finished just before the sun went down, unit up and running. I took the below picture showing 1amp of charge with the roof flat, when the top was opened and the panel was pointed towards the sun the charge went up to 4amps, even though the sun was very low on the horizon. Depending on how you park the truck you can maximize your solar input. The ML-ACR under the hood will auto combine the batteries when the solar starts charging the aux battery keeping both the aux and starting batteries fully topped up.
    Now to just blow all the aluminum shavings off the top of the truck and call it a night.
    Hodakaguy
    #89
    wilfred, tjzondrz, wee-twin and 7 others like this.
  10. BigEasy
    BigEasy Fish Eyed Heathen
    Jun 23, 2007
    3,898
    South of Indy in the hills
    Or go for a drive for some pie:D that’ll clean them off
    Nicely done :clap
    #90
    villageidiot likes this.
  11. Hodakaguy
    Jul 30, 2007
    3,004
    Eastern WA State
    Next up on the Drifter is to install an awning. We installed a Shadow Awning on our last FWC and loved it so we decided to go the same route this time around. The shadow Awning is a 270 Deg awning that deploys quickly, offers a ton of shade and is built very sturdy. The Shadow Awning will handle quite a bit of wind without having to deploy the leg and tie downs.
    Here is a link comparing the Shadow Awning to the Batwing 270 Deg awning which is another option in this class. We swapped our Batwing for the Shadow on the FWC and I documented the differences, the Shadow awning is far superior: CLICK HERE
    Camper ready for the awning install.
    First up is to move the rear latch on the passenger side. The passenger side latch is located right where the rear awning bracket will be located and needs to be moved to the rear of the camper.
    A drill and a punch make quick work on removing the latch assembly.
    With the latch removed we marked and drilled the holes to mount the latch on the rear of the camper. A few pop rivets later the latch is installed and functional again.
    We re-installed rivets in the existing latch holes to seal them off.
    We planned on fabricating custom brackets for the awning but Iggy from Vagabond Campers contacted based on a post I made and let me know he just designed some stainless steel brackets for this exact awning. Iggy had a set on hand and got them out to me ASAP......Thanks Iggy! These brackets look great and will save a lot of fabrication time!
    A picture of the brackets....Nice!!
    Test fitting the rear bracket. I used a drill bit to mark center on each bolt hole then drilled the 4 mounting holes into the camper.
    With the rear mounting bracket holes drilled we turned our attention to assembling the mounts onto the awning. You need to make holes in the awning cover for the mounting bolts to pass through, here we are making the holes for the rear bracket. I used a awl for the centering holes to mark the correct locations.
    Once I knew where center was I slid a thin board inside the cover and used a gasket punch to enlarge the holes to the correct size.
    Rear bracket mounted in place. You can only get to three of the mounting holes while the awning is on the ground, it needs to be fully extended to get to the 4th hole so we will assemble this bolt once the awning is mounted on the truck.
    Repeating the process with the front mount. The front mount can be located anywhere along the awning, we chose about 1.5' back from the front of the awning
    We used regular nuts instead of lock nuts at this step since the front bracket will have to come back off once proper location is marked on the camper.
    Wife and Dad helping out holding the awning in place while I mark the front bracket location. The awning is not heavy at this point since the lips on the brackets hold the weight of the awning against the camper.
    Front bracket location marked. Now the awning can come back down and I removed the front bracket once again to use as a pattern to mark the mounting bolt hole locations.
    Front and rear mount holes drilled.
    This is the backing plate for the rear mount that goes inside the camper. Since our camper had the latch in this location and now has two rivets that are plugging the existing holes for the latch we had to drill two holes (One hole and one notch) in the backing plate to clear the rivets and let the plate sit flush up against the camper.
    Mounts back on the awning. Both nuts will be swapped out to lock nuts once on the truck. I applied Butyl rubber tape to the mounts to seal the bolt holes going through the camper.
    Awning mounted to the camper. Here is a shot of the rear bracket before it's tightened down.
    As you tighten the mounting bolts the Butyl rubber squeezes out of the bracket, it also squeezes around the bolts and forms a tight waterproof seal.
    A plastic scraper makes quick work on removing the excess Butyl.
    Next up is attaching the tension strap to the rear of the awning. I used an awl to make a hole big enough for the pop rivet and doubled the material for strength at this connection.
    Hole drilled in the rear awning arm and strap mounted in place.
    Latch assembly mounted onto the rear corner of the camper.
    And in action. The tail has been trimmed and the edges sealed/melted.
    And finished! The shadow Awning is a sweet setup offing a lot of shade in a small package. Living in the desert the shade from this baby will be welcomed!
    Awning on the truck.
    Front shot with LOTS of bugs on the camper lol.
    Awning deployed with the top down.
    And with the top up.
    More to come.....
    Hodakaguy
    #91
  12. MartiniUp
    MartiniUp Long timer
    Jul 14, 2010
    3,723
    TX
    With enough room (Height) to put a full size dirt bike inside.
    #92
  13. PowerT
    PowerT Long timer Supporter
    Jun 27, 2005
    1,142
    Just West of Foat Wurth, Tejas
    V
    #93
  14. Hodakaguy
    Jul 30, 2007
    3,004
    Eastern WA State
    Heater vent mod time. The outlet of the Propex unit is on a swivel and angles out at about a 45 deg angle, unfortunately the hot air still manages to hit the aux battery box. My dad has been placing something in front of the battery to deflect the heat but it's time to fix it for good and fab up a permanent deflector.
    Here you can see the heater outlet in relation to the battery.
    First up measuring, cutting and welding. Starting with a scrap piece of metal plate.
    One deflector minus mounting tabs.
    Next up....cut out some mounting tabs
    Tabs rounded, welded in place and the whole assembly painted. We will be installing the deflector onto the heater unit with Rivet Nuts.
    Drilling holes and installing the Rivet Nuts into the heater box.
    And bolted in place.
    I ran the heater for about an hr on wide open to see how much heat transfer made it to the heater box, the deflector itself gets hot but the box itself stayed just warm to the touch around the deflector area. The solar charge controller stayed nice and cool which is what I was concerned about...perfect.
    One more thing off the to do list.
    Hodakaguy
    #94
    marret, Mr. Fisherman, MYUMPH and 4 others like this.
  15. MartiniUp
    Jul 14, 2010
    3,723
    TX
    Why not use a spring/shock/strut unit already assembled? None available for a Toy that fit your needs? So much easier and safer.
    #95
  16. Hodakaguy
    Jul 30, 2007
    3,004
    Eastern WA State
    Assembling your own allows more choices of strut and spring combos. I could have paid extra to have the shop I purchased the parts from assemble the units but why? It's not a hard job and I already have the correct tools....why spend the extra? With the propper tools It can be done at the home shop perfectly safe as well.
    Hodakaguy
    #96
  17. Hodakaguy
    Jul 30, 2007
    3,004
    Eastern WA State
    My Dad is currently down in AZ enjoying the warm weather! He's reported that the camper and heater are working perfectly and he's been pouring on the miles while out exploring. Good Stuff!
    Hodakaguy
    #97
    rjnutt, Devo 1, katbeanz and 14 others like this.
  18. goosecreek
    goosecreek Ashes ashes all fall down Supporter
    May 25, 2010
    8,158
    One foot out the door.
    This.
    The problem is the amount of moisture they produce, I had it rain on me one morning.
    #98
    mbabc likes this.
