Honda CB500X
Discussion in 'Land of the Rising Sun: ADV Bikes from Japan' started by JimmieA, Nov 12, 2012.
  1. dirtdreamer50
    dirtdreamer50 long time rider
    May 12, 2010
    3,677
    texas coast
    Wow, do you live on that thing? Here's hoping for another 100K for you. tp dd50
    maxtee_crf, Sunflash and No-Fret like this.
  2. Cruz
    Cruz Lost but laughing.
    Nov 3, 2008
    9,970
    Northside Brisbane, Qld Australia
    Pilot Road 4s handle and last very well.
    jsonder and Mustang28027 like this.
  3. jwc
    jwc Ready to go
    Jul 20, 2009
    214
    South Louisiana
    I have a 2015 ABS CB500X with ~24k miles. No problems and all scheduled maintenance completed. Last week after a 650 mile weekend back roads ride we were getting close to home steady state on the superslab and the dash goes dark, the bike dies and will not restart. Coasting to the nearest exit ~3 to 4 long minutes later the dash comes back on and bike restarts everything working as it should. Got to be a loose connection. Back home the battery connections checked tight and had the battery itself checked out by a local Interstate Battery outlet and proclaimed good ( I was pleasantly surprised they gave they battery a clean bill of health and passed up on a sale). I pulled the tank and checked all of the plugs I could find. They all seemed fine and I reinstalled with dielectric grease. The chassis ground(s) on the left side is undisturbed and tight. I have Cyclops LED lights which were in use; a USB charger and coax for heated gear neither of which were being used. All accessory wiring is soldered and shrink wrapped with line fuses directly to the battery ( pigtails were made to reduce the number of ring connectors on the battery terminals).
    The only thing I have found "odd" is the main 30A fuse under the right side panel does not offer much resistance when being pulled out or being inserted. It 'seems' ok just doesn't give me the firm resistance I am used to when fooling with fuses. I have put a couple hundred miles on the bike since and had no problems what so ever.
    Please forgive the long post but we sometimes ride in pretty secluded areas and I would really like to avoid having our trusty CBX go dark with some sketchy electrical issue.
    Has anyone had issues with the main fuse being loose or similar issue???
    Grumblez likes this.
  4. ben2go
    ben2go I am Ben! Hear me snore!
    Jun 23, 2011
    6,879
    Upstate SC USA
    Did you do the valve clearance checks? Something in the electronics tray could be loose. Also check the connectors behind the display.
  5. jwc
    jwc Ready to go
    Jul 20, 2009
    214
    South Louisiana
    Yep. ( Valves were all in good order). After checking the battery that’s where I thought I would find my loose connection, but it all seemed tight.
    ben2go likes this.
  6. Garde
    Garde brainz 4 sale
    Oct 25, 2016
    531
    Seattle, WA
    Went out the morning after replacing the air filter and the bike wouldn't power on at all. Main fuse (the 30A) was blown. Still no idea what happened, but everything checked out the same way yours did. Replaced the fuse and good to go. Terrified I'd managed to put the battery in backwards or something...but nope, everything was right. Still is, six months later.
  7. jwc
    jwc Ready to go
    Jul 20, 2009
    214
    South Louisiana
    Assuming it was the fuse in my case. I'll just be sure to always have a 30A spare and the proper allen wrench to remove the panel. Odd for such an otherwise dependable bike. I'd actually feel better if the fuse was blown. Then I could sure I'd found something.
  8. tft
    tft Been here awhile
    Nov 30, 2012
    769
    Austin, Texas
    28f/30r
  9. DaveNYrider
    DaveNYrider Adventurer
    Nov 24, 2016
    66
    Dutchess County NY
    Thanks... I ordered a set
  10. ben2go
    Jun 23, 2011
    6,879
    Upstate SC USA
    I ride to hard and load to heavy for those pressures. I would roll a bead pretty quick.
  11. GezwindeSpoed
    GezwindeSpoed Been here awhile
    Jan 15, 2009
    797
    The land of the Dutchmen
  12. michaelkozera
    michaelkozera Long timer
    Jan 11, 2015
    1,028
    calgary
    damn, and i thought i had alot on my 500twin engine ,122,000km, but then again my crf500L (the donor crf250L i built it on) is pretty much at 250,000km. so i win? :dunno lol
    i bought it end of 2013 so about 55,000km a year average. 150km/day average <----altho not indicative of actual daily mileage, more like 80-90km/day then 800+ km/weekend.
    160,000km tho..... im impressed. :clap
    i too use the cheapest 5w-30 oil i can find, 5w instead of factory recommended 10w because i ride year round in the winter so the 5w helps cold starts when its -20C outside. and of course in the summer i run 10w-30 as recommended in the manual.
    this is addressed to Mustang28027
    people have to remember this is a de-tuned 500twin. its low compression, 87 octane, with a 24,000km valve check interval! and with a 12,000km oil change interval! its a bullet proof engine. after 122,000km the engine still pulls just as hard as when i got it new, and the fuel economy has not changed at all, if anything its gotten slightly better.
    funny enough too, i sent my oil in for chemical analysis and after riding it very hard for 12,000km my oil still had a theoretical life of 40% left. this means if you really wanted to you could do 20,000km+ (or 1 year, whichever comes first) if you rode it calmly and normally. i think honda said 12,000km as insurance incase someone rode it like they stole it they would not cook their oil after 12k.
    just proves that this little 500twin is very durable and economical.
  13. Mustang28027
    Mustang28027 Been here awhile
    Dec 29, 2004
    180
    Concord, NC
    Pretty impressive on the oil and mileage. Obviously you ride year round. That is impressive, too!
  14. Mustang28027
    Dec 29, 2004
    180
    Concord, NC
    Saving a wreck.... my rebuild. So I got this as a salvage wreck. Hoping to turn this into a gravel runner as JDRocks has done on his builds, but saving the plastics. I think it looks pretty cool... Got the right fork used off ebay, ordered the left tube, cheap, from a dealership that had it on sale. Someone had extra parts left over from a Rally Raid conversion, and I got them cheap. Put the right fork on, easy. Rebuilding the left fork, should be simple, but that upper race that is just below the seal and washer... what a pain. The tolerances on that to fit are nearly impossible. After trying to press it into the lower fork for nearly an hour, I finally resorted to taking some fine grit sandpaper and reaming the lower housing out a bit. Then it fit fine. Got it all put together and was hoping to go for an initial ride.... but then discovered the rotor is warped. The wheel will not turn. Denied! Back to ebay to find a rotor. We are fortunate that our bikes share parts with the CB500f and CRR500.
  15. Mustang28027
    Dec 29, 2004
    180
    Concord, NC
    More work on the rebuild... When I got the bike the left front turn signal was broken off. I discovered the previous owner had tried to Gorilla Glue it back on, then tried electrical tape. Failure. I took the broken parks and used two part JB Weld epoxy to put them back together. Yes, JB Weld WILL WORK ON OUR PLASTIC PARTS. Still, I don't like it . Don't like the look. So I have ordered a new left front signal light. Problem is, the wiring connects inside the fairing and it is well hidden. Does anyone have instructions on removing the fairing pieces to get to it? Please post.
  16. johnpma
    johnpma Been here awhile
    May 15, 2017
    274
    Western Mass
    Man that is a TON of shifting :rofl Good for you that is awesome:lift
    Night_Wolf likes this.
  17. Mustang28027
    Dec 29, 2004
    180
    Concord, NC
    Need a front wheel. My salvage rebuild was hit in the front and the forks are done. Rotor was warped and replaced, but the wheel wobble is still there. Rotor is rubbing on the brake pads and caliper, far more then spec. So I need a front wheel. Anyone out there with a RR3 build and have the front wheel they don't need? Dave
  18. playinatwork
    playinatwork Been here awhile
    Jul 30, 2010
    381
    Jacksonville FL
    Dave, you might want to check the axle, it might be bent instead of the wheel.
  19. ben2go
    Jun 23, 2011
    6,879
    Upstate SC USA
    Beat me to it by a minute.
  20. Sunflash
    Sunflash Been here awhile
    Mar 28, 2016
    511
    North Pole, Alaska
    I would probably sell my wheel set.
    Sent from my LG-H872 using Tapatalk
