Honda CB500X
Discussion in 'Japanese polycylindered adventure bikes' started by JimmieA, Nov 12, 2012.
  1. JamesHTrotter
    JamesHTrotter Been here awhile
    Dec 31, 2017
    182
    New York
    khemist likes this.
  2. eternalforeigner
    eternalforeigner It's not a midlife crisis if you're methodical.
    Jun 7, 2018
    12
    NC
  3. gmtech
    gmtech Been here awhile
    May 16, 2011
    106
    pirate island illinois
    looking at getting a 19 in the spring. how accurate are the speedos on these. ill be coming from a 12 tenere. have had 2 first one was off by about 10mph my current one seems to be only off by about 5 maybe.
  4. Oyabun
    Oyabun 親分
    Apr 7, 2016
    725
    Budapest, Hungary
    It's an interesting question.
    When I checked my bike (UK spec) in its original form, indicated speed was rougly 5% optimistic. My current setup is reading lower than GPS speed.
    I'm currently using an US spec Speedo unit and a 39T rear sprocket (instead of the oem 41T) - which later is roughly 4% longer than stock. This way the speedo reads about 4-5% over, and the ecu reads about 2% lower - so I assume that the oem US speedo is pretty much spot-on.
  5. CCer
    CCer missing Supporter
    Nov 3, 2008
    229
    unknown
    The speedo on my 2019 is pretty spot-on compared to GPS, Never had any vehicle match like that. Well, it matched until I put on that 16 tooth countershaft sprocket.
  6. racer
    racer Long timer
    May 5, 2004
    2,607
    Indiana
    What he said. Racer
  7. SR56
    SR56 Long timer
    Feb 7, 2013
    3,876
    NW Florida
    JH...what year is it? I haven't learned to tell the difference yet unless it has the stock muffler and I can see it :rofl.
  8. S.O.G.
    S.O.G. n00b
    Jun 4, 2019
    8
    SE Michigan
    It might be tuff to find one next spring.
  9. SR56
    SR56 Long timer
    Feb 7, 2013
    3,876
    NW Florida
    Sort of brought this up previously but has anybody found a decent 17" knobby tire to run on the front of a '18 or earlier bike besides the TKC80?
    The TKC80 is a good tire and I'll probably go with it...just curious to know if there is another option.
    Only options I found are the Shinko 705 and TKC70...using the Chap Moto Tire Selector: https://www.chapmoto.com/dual-sport...tion=25809&tire_width=3419&tire_rim_size=3400. Neither of which is aggressive enough for riding off road where I'll be going :-).
  10. khemist
    khemist Adventurer
    Aug 14, 2018
    88
    Scotland, UK
    delete wrong thread.
  11. Cruz
    Cruz Lost but laughing.
    Nov 3, 2008
    12,681
    Northside Brisbane, Qld Australia
    TKC80 in tubeless 17 inch front i found to be a great tyre. I may have previously responded to you, but there is also the MT60 Corsa front in 17 inch.
    Blakduk likes this.
  12. SR56
    SR56 Long timer
    Feb 7, 2013
    3,876
    NW Florida
    Thanks Cruz...looks like the TKC80 is a little more aggressive than the MT60 and seems to be the best option I have found for a 120/70-17 front tire that might see some sand off road :D. If anybody has a better idea, I am all ears :ear.
    JH...I listened very closely to the video you referenced and I heard the high pitch vibration. Sounds like a shroud, cover, panel...etc. that resonates at a certain rpm. I'd go over everything and make sure you don't have a lose fastener or that you haven't lost a bolt, zip tie, fastener, etc. anywhere.
  13. JMo (& piglet)
    JMo (& piglet) Unicorn breeder
    Apr 1, 2007
    8,940
    California
    Hi Eternal' - I cannot see any reason why that shouldn't fit the 2013-16 bikes too - the frame and swing arm/wheel-size and travel is the same across all years. The exhaust silencer section is different from 2017, and if you have an aftermarket exhaust some don't come with a stopper for the centre stand, but the OEM Honda stand fits those bikes - so if the SWMotech is essentially a pattern part, it should also fit the earlier generation bikes with a standard exhaust*
    * and you can always add/re-position the stand stopper to an exhaust that doesn't have one - using an additional pipe-clamp for example.
    Physically though, I see no reason why it won't bolt onto the lugs on the underside of the frame, and the foot lever clear the swing arm and side stand on the left hand side in just the same way.
    Jx
  14. B-Nads
    B-Nads Adventurer
    Aug 28, 2019
    45
    Quebec, Canada
    I got the new-to-me toy out this past weekend - there was some sliding between those road tires and the rain soaked mud ruts, but a lot of fun none-the-less. I was pretty impressed with how nimble the bike was in general - particularly off the asphalt and packed gravel.
    catfish and Bors like this.
  15. SR56
    SR56 Long timer
    Feb 7, 2013
    3,876
    NW Florida
    Don't let the speedo stop you...I used one of these on several bikes and it is super small, easy to program, and works great: http://shop.12oclocklabs.com/index.php?route=product/product&product_id=59
    Fortunately the speedo on my '17 is dead on accurate...until I change tires :lol3 and then I'll be buying one.
  16. Oyabun
    Oyabun 親分
    Apr 7, 2016
    725
    Budapest, Hungary
  17. MotoSpen
    MotoSpen Adventurer
    May 28, 2017
    37
    Southern Ontario
    Have a look at the Shinko 804 (front) & 805 (rear) set if you're looking for something like the TKC80s. Very similar block pattern and reportedly longer lifespan (and cheaper). I plan to put this set on my '19 next spring.
  18. OHjim
    OHjim Long timer
    Aug 12, 2009
    1,016
    KC
    However, these are not available in 17" for front. And, I wouldn't ride with this particular rear on the front. Not sure why you would recommend them for him?
  19. MotoSpen
    MotoSpen Adventurer
    May 28, 2017
    37
    Southern Ontario
    Woops, didn't see the note RE front only. Thanks!
    OHjim likes this.
  20. danceswithcages
    danceswithcages Been here awhile Supporter
    Mar 17, 2009
    279
    Indiana
