Honda CBR300 engine swap into a CRF250L.
Discussion in 'Thumpers' started by Cuttlefish, Jan 7, 2017.
  1. Cuttlefish
    Cuttlefish Riding to disappear.
    May 31, 2016
    2,365
    Sunshine coast Qld Australia
    That's right folks...My humble, utilitarian Honda crf250l 2015 is about to receive a cbr 300r engine swap.
    My crf started making strange noises and so I went back into the Oz vendors section to find a thread for a new mechanical business on the Sunshine coast.
    Drivewell mechanical.
    http://advrider.com/index.php?threads/drivewell-mechanical-sunshine-coast.1181800/
    I took the bike over to Gerard and we had a good chat about what he's done with bike tours in the Far Nth of Australia.
    I ran my thoughts about some prospective bikes to replace my Triumph scrambler since I was more into exploring off road with the crf than road riding with the scrambler.
    Essentially the crf while being a fun bike showed its suspension and power deficits when pushed faster both off and on road. So I was thinking of just one bike to simplify things.
    Is it too soon to insert? ....Buy a KTM...which one? ...who cares which one...ok, ok ... A 500 exc!
    Ok.
    Now I've got that out of the way. I did get as far as test riding some used bikes the week before the crf signed off.
    I rode a Ktm 530 exc, a WR 250r, dr650, drz400e and a Kawasaki klx450r.
    Funnily enough I got back onto the crf thinking if it had a bit more power and I had the suspension upgraded it would be spot on for cruising around and exploring the hills and dirt roads out the back of the Sunshine coast hinterland where I live.
    I'm not looking to ride single trail or snotty terrain since I'm doing it solo.
    I have a large VW van to either wheel it into or put it on the back with my rack n roll carrier so it doesn't have to be a "adventure cargo bike". I can drive the way further afield and use it as my camping base to explore areas if I want.
    Anyway...Gerard called me with the bad news that the top end was going to need quite a few parts.
    So while looking for used top ends on Ebay I came across a used cbr300r engine with 15,000kms on it. The vendor also had the ecu, throttle body, coil and spark plug listed too.
    I started researching a prospective engine swap.
    Rick Ramsey did an excellent comparison sheet of the engines.
    http://www.rickramsey.net/CRF250Lresearch.htm
    To date I've found threads on Thumpertalk where people have swapped various parts and even the majority of the cbr's engine but none have simply done a straight entire cb300r engine swap into the crf-l.
    So Gerard also did his own research and agreed to do the work for me and document it along the way.
    I can take the bike to Full force racing suspension specialists (famous now for their plex valve DR 650 transformation) to re-valve my stock rear shock and front forks once the engine is in.
    https://www.fullforceracing.com.au/
    I'm on a bit of a budget. Probably will need a ejk fuel controller down the track too.
    The crf has an FMF Q4 pipe with power bomb header, standard airbox with K&N filter (bought it used this way) and I've put a 13 tooth front sprocket on it.
    The engine should leave Dubbo in NSW tomorrow and so by middle of next week the transplantation could commence.
    Here's the crf waiting for its donor engine.
    enduro16, 59DEN, Kray and 15 others like this.
  2. The_flyer
    The_flyer Been here awhile
    Jan 3, 2017
    369
    White Mountains, NH
    Looking forward to seeing this project!
    Cuttlefish likes this.
  3. wolftrax
    wolftrax Long timer Supporter
    Sep 23, 2008
    1,057
    Blue Ridge Mtns Ga.
    Subscribed
    Sent from my XT1019 using Tapatalk
  4. swimmer
    swimmer armchair asshole
    Oct 9, 2007
    20,000
    Tucson, AZ
    Interested in weight increase if this ends up working.
    Cuttlefish and The_flyer like this.
  5. adventurebound9517
    adventurebound9517 Long timer
    Mar 28, 2011
    1,138
    Lake Havasu City, AZ.
    Subscribed.
  6. Blossem12
    Blossem12 Adventurer
    Dec 24, 2015
    71
    South Pacific Crimes Gold Coast
    Subscribed
  7. Cuttlefish
    May 31, 2016
    2,365
    Engine is on the way....due by Thursday.
    SFC_Ren likes this.
  8. shortman
    shortman Beta 500 RS, X-Trainer 250 Supporter
    Jun 14, 2013
    1,804
    Cumming Georgia
    Morning Cuttlefish.... I'm the same @shortman that is on Thumper Talk....
    I wanted to elaborate on the transmission thing a little more.... If you keep the CBR300 engine as is I recommend you go back to the stock 14/40 gearing... Because of the close ratio box in the 300 engine 6th gear (when running the stock 14/40) feels like the CRF250 engine when running 13/42 gearing.... Hope that makes sense...
    Because you already have the 250 engine out of the frame it's not too much more work to just split the cases and swap the gear box OR put the crank in the 250 cases..... You will be much happier, I promise!
    #8
    Kray and Cuttlefish like this.
  9. Cuttlefish
    May 31, 2016
    2,365
    G'day. Thanks Shortman. I was already thinking of going back to the stock front sprocket after what you'd said.
    Since the crf will be run on plenty of twisty hills on-road to gravel roads and 4wd tracks as opposed to single trail as its primary riding the cbr 300r transmission ratios may still be good for me.
    I will probably sell my Triumph scrambler soon so the crf will get some road rides in its use too. I'll see how it goes first.
    Will run through the transmission swap with Gerard before the engine installation. Should turn up tomorrow...or even today!
    #9
  10. mekros
    mekros Adventurer
    Oct 5, 2011
    70
    I'm very interested to see how this progresses, thanks for starting the thread.
    #10
  11. Cuttlefish
    May 31, 2016
    2,365
    For those following this thread, Shortman has already done the cbr300r swap.
    #11
  12. swimmer
    Oct 9, 2007
    20,000
    Tucson, AZ
    So you can run the 300 crank and cylinder on the existing 250 case? Do you retain everything else from the 250? Sorry some of this might be repeated questions. OP said you've already done the swap. Is that documented somewhere? Thanks.
    #12
  13. shortman
    Jun 14, 2013
    1,804
    Cumming Georgia
    No... I didn't have the time to document mine and really didn't think it was necessary... The engines are basically identical... The 300 has some minor internal differences with the biggest one being the longer stroke that provides 38 more cc of engine size.... I added a Bill Blue "283" big bore kit to mine before installing it to further increase displacement....
    Yes the 300 crank will drop right into the 250 cases.... I suggest the use of the 300 balancer....
    #13
  14. Sootgrinder
    Sootgrinder Been here awhile
    Jul 27, 2016
    467
    Once completed this sounds like the perfect sensible dual sport, mini adventure machine. Can't wait to hear the rest of the story.
    #14
  15. shortman
    Jun 14, 2013
    1,804
    Cumming Georgia
    I really think it will be... At least that's what I was thinking when I decided to buy and build it.... I have a KTM 500 for the gnarly single track and big dual sport rides I attend thru out the year so the Honda is gonna be my "go to" bike when I wanna ride from home somewhere OR maybe take a multi day trip....
    I've only ridden it enough to know the engine upgrade was well worth what it cost... I plan to log many more miles as soon as my house remodel is finished and I yank the engine back out for a transmission swap....
    I also wanna throw out there for someone reading this who is thinking they might like to do the same thing... I have the complete 250 engine that came out of my bike sitting in the basement... Would love to pass that along to someone who wants to wants to go down the same road of building up an engine then just do the swap
    #15
  16. swimmer
    Oct 9, 2007
    20,000
    Tucson, AZ
    Thanks. Rick Ramsey stated back in '14 on his site that the 300 crank won't fit. I guess he had bad info at the time?
    #16
  17. Sootgrinder
    Jul 27, 2016
    467
    How involved is it to get the honda suspension up to an acceptable level of performance to go along with the new "big block" motor? I also have a 500exc, but someday would like to add something similar to the crf 300 for mini adventure type activities.
    #17
  18. shortman
    Jun 14, 2013
    1,804
    Cumming Georgia
    I can't really say... I've not made it that far but from what I've read it comes down to a new rear shock and race tech valves in the forks.
    #18
    CRD and retroone like this.
  19. retroone
    retroone Long timer
    Jan 11, 2006
    2,046
    albq NM
    "New rear shock and race tech valves in the forks"
    That's the minimum :dirtdog Shock and forks is what I would do. :ksteve
    #19
  20. Cuttlefish
    May 31, 2016
    2,365
    Talked to Gerard about the transmission gearing and he'll install it as it is with the 14/40 standard sprockets and we'll test ride the bike to see how it goes.
    This way we can give a benchmark for others who may also do this swap in the future.
    Then we'll look at different sprocket combos to adjust with the 14/42 being the next step (thanks Shortman).
    So far with my stock suspension (rear pre-load wound right up for my 185 lbs/85kgs) the ride is fine for me on road. Off road my main gripe is with the sluggish rebound of the rear shock. The terrain and pace I'm riding doesn't tax the front too much. I will have Fullforce racing re-valve the forks and look at springs/fork oil adjustments as they see fit in the future.
    #20
