Honda CBR300 engine swap into a CRF250L.
Discussion in 'Thumpers' started by Cuttlefish, Jan 7, 2017.
  1. Cuttlefish
    Cuttlefish Riding to disappear.
    May 31, 2016
    2,352
    Sunshine coast Qld Australia
    Stoked. That 15 front sprocket will give you the relaxed legs you're looking for on the highway.
    Running 14/38 made a significant difference towards relaxing the revs at speed and fun around town/easier trails. I ran the 14/40 most recently because of the terrain I was riding being more towards enduro vs adventure touring in very hilly country.
    Giving it a fist full in 3rd on dirt and having it spin the back wheel is novel.
    I like the 1st-2nd transition with the 300 gearbox. No more yawning gap inbetween first and second.
    Easy to swap front sprockets.
  2. GSXR
    GSXR Trail Rider
    Sep 14, 2010
    1,887
    Sunshine Coast, Australia
    have you got a link to 15t Pete?
  3. Cuttlefish
    May 31, 2016
    2,352
    Sorry I don't. Sick of this rain yet?
    GSXR likes this.
  4. Rocking Horse
    Rocking Horse Self funded bludger
    May 24, 2017
    992
    Somerset, Tasmania
    GSXR and Cuttlefish like this.
  5. GSXR
    GSXR Trail Rider
    Sep 14, 2010
    1,887
    I've pretty much flogged out the chain & sprockets now, so will look to get a nice combo with 15t front.
    Don't want to commit to any gearing combo untill I get the oxy sensor welded into the header pipe. Want to see what effect this has first
  6. wolftrax
    wolftrax Long timer Supporter
    Sep 23, 2008
    1,057
    Blue Ridge Mtns Ga.
    Put a few miles on after 15t swap. My Africa Single 300 is now far better than I could ever hope for. It's now better off and on road than the Stage 1 250 Still plenty of giddiup in first and second. On the highway it cruises easily at 65 with pull all the way up to 75 MPH. Love this bike. [​IMG]
    Sent from my Moto G (4) using Tapatalk
  7. minkyhead
    minkyhead Long timer
    Jan 4, 2007
    1,544
    uk gods county
    just wondering if your going off the crf clocks or the sat nav ..the clocks are loads out a indicated 63mph is actually 70mph on the sat nav
    wolftrax likes this.
  8. wolftrax
    Sep 23, 2008
    1,057
    Blue Ridge Mtns Ga.
    Going off my GPS. I'm sure it'll do much better than 75. Just don't see any need to go any faster.
    Sent from my KFAUWI using Tapatalk
    falcn and minkyhead like this.
  9. falcn
    falcn Squidless Soul Supporter
    Oct 29, 2006
    1,072
    Los Altos, CA
    I wish these were mainstream enough for a magazine to do a comparison for the Versys-X 300 to the Rallye 324cc incarnation.
  10. jwb
    jwb Local minimum
    Jul 27, 2008
    342
    Oakland
    Hey pals, I read through the thread and I guess I'm pretty surprised at the variety of builds going on here. It seems like some folks are just swapping in the crank kit from the 300r and nothing else? Not even the ECU? Is anybody also using the intake cam from the 300? It's different from the intake cam on the 250l, although the exhaust cams are the same part. The piston is also a different part number ...
  11. Ed@Ford
    [email protected] Long timer
    Jan 16, 2004
    4,311
    Dearborn MI
    I've studied this business for several years. By studying the parts between the 250 and the 300 (286 actually) you can make sense of what to swap (i.e. what's different between the two) important cautions is a 250 piston on a 300 crank will give you almost 13:1 compression ratio....too much!! , second, there is a chance that the 250 ECU will not provide enough fuel at WOT, and a piston might melt. Some guys do not change the balancer or the balancer gears....probably only having a little extra vibration. If you use an EJK you can add fuel, or have it custom flashed by Dobek. Look into the cam swapping business....the 300 cam is different, also, I think the rocker is different. Also the 2017 Rally & CRF-L got a bigger throttle body. Go to thumper talk and read up on technical details of what other folks have done. Also, the 2017 250 has a different speedo/tacho....some fiddling of the wiring harness is required to make certain 300 ECU work and run the tacho. Swapping in whole 300R engines is popular too.....many ways to skin the cat to get more power. Just be careful.
    Kray likes this.
  12. jwb
    jwb Local minimum
    Jul 27, 2008
    342
    Oakland
    Yeah you'd obviously blow it up with a stroker crank and the same piston. The balancer shaft appears different but the balancer drive gears are all the same parts.
  13. Ed@Ford
    Jan 16, 2004
    4,311
    Dearborn MI
    It would run REAL fine if you could get RELIABLY 94 octane or you always stayed above 8000 feet. Early CRF-L had different balancer gears....2017...I think all CRF-L/Rally 250 had 300 balancer gears....working from memory here. Also, when you get a crank kit get the kit provided for recalls of ALL 300's from '15 and '16 because they all had recallable/warranty bad cranks.
  14. jwb
    jwb Local minimum
    Jul 27, 2008
    342
    Oakland
    Seems like I'd need the 'A' type crankshaft bearings, or I'll have to order, receive, and measure the crankshaft and get the correct corresponding bearings, regardless of which bearings are already in my crankcase.
    I've convinced myself this is a cheap and easy project. :hmmmmm
  15. jwb
    jwb Local minimum
    Jul 27, 2008
    342
    Oakland
    The major parts all have, at least, different part numbers. Importantly, the crankcase halves and the cylinder. And of course the crank, piston, cam, balancer, and then the balancer gear looks very different on the CBR fiche compared to the CRF one, but has the same part #.
  16. Ed@Ford
    Jan 16, 2004
    4,311
    Dearborn MI
    At least 2 of the reasons crankcase halves are different # is 1: paint color, # 2 is: one of the halves holds a bearing that supports the end of the balancer shaft. This bearing is larger OD in 300's compared to the 250. Probably because (noted in some documentation on Thumpertalk) the 300 balancer shaft is heavier than for the 250.
  17. jwb
    jwb Local minimum
    Jul 27, 2008
    342
    Oakland
    Yep I woke up with the realization that they paint these different colors. You think the balancer bearing outer diameter is different than the one in the 2017 250? It’s only going to cost me $7 to find out.
  18. KLeptoLee
    KLeptoLee Adventurer
    Apr 27, 2018
    16
    Annville
    I put a 300 crank balancer shaft,cams in my 250l and an 81mm big bore=325. 305 reflash on the ejk. It’s a rocket compared to stock. Something must have self clearanced I found shavings in the first oil change at 250 miles. They may have been hard miles lol. Being paranoid i pulled the side covers off and inspected, either the crank or balancer shaft clearanced it’s self.
    Edited to add content.
  19. Ed@Ford
    Jan 16, 2004
    4,311
    Dearborn MI
    don't buy it...in the description of the bearing there is a 4 digit number . Get each number and google bearing dimensions...you'll find the300 balancer shaft bearing OD is about 5mm more...ID of both are equal, so the 300 balancer will fit in the 250 case with bearing.....obviously honda thought the heavier balance shaft needed more robust bearings. But numerous folks have built 250's with the stroked 300 crank and kept the 250 balancer.....most said they did not notice any vibration increase.....that's about the only real technical issue stroking the 250 with honda parts...but I find it acceptable, as I have no positive opinions of the current choices available in big bore kits for more displacement.
  20. KLeptoLee
    Apr 27, 2018
    16
    Annville
    I had custom thickness gaskets made by cometics to drop the compression. To 12.5:1 if you use the stock thickness gaskets it’s 15:1
    JungleDeath likes this.
