HONDA CRF250 RALLY OWNERS
Discussion in 'Thumpers' started by ferdiepick, Mar 18, 2017.
  1. maxtee_crf
    maxtee_crf Been here awhile
    Jun 12, 2017
    100
    Basel, Switzerland
    Snapper...nice...where is that??
    Hi all... so coming back with some photos and info on the rear spring setting to make it harder. I also see in my absence this thread has become an ABS discussion!! Glad I missed it ;)
    So i have attached a couple of photos and a video I took with my phone. Without removing the mud flap and rear tyre is the best I could get. I do not have any definitive answer here, but from what the mechanic said and what I think I see in the photo and from the changes in the bike my best guess is as follows:
    With this adjustment I have the following Conclusions so far:
    Conclusion 1: Bike sits higher
    Conclusion 2: Bike sags much much less
    Conclusion 3: The adjustment is a simple compression of the rear spring and the top of the spring is set lower down on the shock.
    I come to this by the following:
    1. The mechanic said the spring had two "rings" that the spring can be set on. He showed me on the bike and pointed to the top of the spring.
    2. In the first photo you can see the current setting and if you look above it you can see a shiny bit of steel which could be (?) the original setting. Also at the current setting you can see a disc which sits under a ridge holding the top of the spring in place.
    From the above 2 points I am guessing the spring is simply compressed and reset lower down the shock.
    I also have the following input from using the bike:
    1. When I now put it on my MX stand the stand slides 80% under the bike before it hits the engine guard. Before I had to lean the bike onto the stand to get it under. Seems the bike is higher.
    2. Before when I was sitting on the bike I could not have the stand down as the bike sunk and rolled to the right. Same when stopping, I had to stand up to get the stand down as it would hit the ground before being fully extended. Now, I can comfortably sit on the bike and have the stand down. And when I stop I can kick the stand down while sitting (with perhaps a bit of a lean to the right).
    3. Visually the bike looks higher (not measured)
    4. When I sit on it there is much much less sag. The rear shock now provides resistance.
    5. I am further up on my toes when I am sitting on the bike with my feet on the ground.
    Unfortunately I havent been offroad on it yet but I think it will be pretty good.
    In short, I would highly reccomend this change to your bike. Makes it more like an offroad bike.
    If someone more mechanically minded could pick up this thread and provide instructions I think it would be a great addition to the community.
    Cheers
    Richard
  2. maxtee_crf
    Jun 12, 2017
    100
    Basel, Switzerland
    Guys am saying good buy to this thread because as of next Friday I will no longer have my CRF Rally. This summer has been the story of baldilocks and the three bikes. In this summer's search for my perfect offroad bike i have had the CRF250 Rally (baby bike), Honda CRF1000 Africa Twin (papa bike) and the CB500X Rally Raid Level 3 (Mama Bike). Sadly for the other 2 Mama Bike won.
    I have thoroughly enjoyed the CRF 250 Rally and have thoroughly destroyed my plastic fairings and wind screens and even bent the tail up 90 degrees through awful offroad riding skills. This thing takes a beating and is a pretty damned good option for a small adventure bike. It can do the highway ok ( a bit loud, a few vibrations and riding over about 120kmph needs downhill and a tail wind), and has been excellent offroad for my type of riding. Also with the altrider luggage is possible to pack for a couple of weeks with tents, cooking gear and the rest. In the end I opted for the CB500x Rally Raid because it is excellent offroad (for my riding ...) and is allot more comfy on the motorway. No disparaging comments on the CRF... it is a 250, that is the nature of the beast.
    So in parting here are my mods on the bike:
    - tyre change to TK63s. The stock tyres were useless offroard. Filled with mud and poor grip. With the new tyres is a completely different bike.
    - changed the rear spring setting to the lower ring so you have a harder rear. This, again, changes the performance of the bike radically
    - I installed the DRC Edge 2 tail tidy. Makes the rear higher and out of the way, looks cool too.
    - I replaced the stock lights with tiny LED's. Makes the bike looks like a bit weird but keeps the lights out of harms way.
    - Bark busters are a must! The stock protectors are only good for wind.
    - replaced the plastic base engine guard with a good solid metal one.
    - I didnt do this but would seriously consider a head light protector. My headlight got scratched and the lens cannot be replaced the whole headlight unit has to be swapped out which makes it expensive.
    - I added the Garmin Montana GPS mounted on the bar behind the windscreen and above the dash. Great position as my eyes never wandered far from the road to read it. You cannot read it while standing... so need to decide what is important.
    - I added a cigarette lighter plug to power my air pump in the left rear storage unit. This was a bad place to put it as it is inaccessible when luggage is on the bike. Rally raid have a great mount for the CB500 handlebar which allows two plugs. If something like this was available for the Crf (and it might be), this would be a good addition. On the CB500 I have a plug with two USB sockets on one side and a cigarette socket on the other. I can charge phone and camera through my tank bag, and the socket to plug my tyre pump into is easily accessible. (The GPS holder charges the GPS so no issues there).
    - get the altrider horseshoe bags for the bike. They are a near perfect fit.
    And voila...you have a damned good adventure bike for pretty low coinage.
    As a side note...I traded my CRF for a 1999 Goldwing :) Different bike but loads of fun...and a Honda.
    So guys and gals happy riding and thanks for letting me be a part of this community.
    mbravo, ferdiepick, Bitingdog and 2 others like this.
  3. benlikes69
    benlikes69 Been here awhile
    Nov 24, 2013
    101
    Does the exhaust make a bad g diffence I have seen a you tube post stating the 2 brothers exhaust is ok but the full yoshi system gives you a better power curve feel ?
    How is the full arrow system ?
  4. benlikes69
    Nov 24, 2013
    101
    What where your thoughts on the Africa twin ?
  5. maxtee_crf
    Jun 12, 2017
    100
    Basel, Switzerland
    Hi Ben... I know this is not an AT forum... but.. for me was way too big and unmanageable. I like single trails, steep rocky paths etc.. and this is too much bike for me to handle. Also very heavy if dropped. If the CRF or CB500 is upside down I can still manhandle it upright again. The AT Would be a stretch. The AT is a nice bike and I dont think there is anything bad about it, again, is horses for courses and up to the rider to pick the bike for them. It is probably good for desert riding and open trails, carrying lots of fuel and water etc... but I think (?) for technical riding you need to be very very experienced. Cheers
    The_Precious_Juice likes this.
  6. benlikes69
    Nov 24, 2013
    101
    Glad I picked the rally then. I sold my ktm adv 990 and love the rally for the same reasons as you mention. The ktm was to big. I have had several 690’s and even found them too much ch at times.
    Currently putting cash aside for the rear spring upgrade followed by some sort of exhaust although the market is very limited !!
    Still at AF does turn my head !!
  7. The_Precious_Juice
    The_Precious_Juice 2015 Subaru Forester
    Jun 2, 2013
    7,812
    University of Montana
    Interesting Goldilocks metephore.
    It's intriguing how the Rally still lost out even though the rider likes technical stuff.
    The wheel base on the CB is closer to the 57.3" on the Rally, but the Suspension travel on the Rally and AT
    are similar.
    I would narrow it down between the Rally and CB too.
    In the end the Freeway comfort won out. 48hp p.twin vs 24hp Thumper. Fair enough.
    Liter bikes are designed for the Freeway, Interstate, and Race track.
    Unless it is a crusier bike like the SCR950, with just 52 horses or so.
    maxtee_crf likes this.
  8. Snapper
    Snapper Long timer
    Oct 10, 2003
    3,286
    SW CT
    eh? You sure you meant me (/my last pix)? With nothing but asphalt parking lot in view - I don't know/remember :dunno
  9. jasonmt
    jasonmt Been here awhile
    Sep 20, 2011
    960
    Alberta, Canada
    I think what you are missing is that most people have their links in the signature panel which other users are able to view or not view based on their individual settings, you have links BOTH in your signature panel and inserted into the body every post you make (IE the bottom of your post I quoted...). Having the links in the body of every post you make is not cool in my books and reeks of a commercial purpose; that or a desperate need for attention neither of which leads me to lend any credence whatsoever to the poster or their links.
  10. benlikes69
    Nov 24, 2013
    101
    A few people seem to really dislike this guy ? Does it really matter ?
    His blog is pretty good surely we could just try ignoring it or just not click on it. Simples !!
    ferdiepick and Daniel Bonnér like this.
  11. GR0NK
    GR0NK Got some screws loose!
    Sep 24, 2006
    9,542
    Stuck in 80s
    Really? Interesting point of view... :hmmmmm
    Oh it's not quite a liter bike... :ricky
    Sean :scratch 18671265_1559449530793820_4973238385691453961_n.jpg 20161001_154058_zpscsgyui1q.jpg image2_zpshdnks2rv.jpeg 20161016_153033_zpsmald2ds9.jpg
  12. Ed@Ford
    Ed@Ford Long timer
    Jan 16, 2004
    3,021
    Dearborn MI
    Exactly....there's good info there, nothing harmful, not hyper opinionated....take it or leave it, leave him be!
  13. Anders-
    Anders- 690R
    Aug 23, 2013
    3,219
    Швеция
    It's not so difficult to grasp the idea of putting links in the signature as opposed to in the body of the actual post.
  14. The_Precious_Juice
    Jun 2, 2013
    7,812
    GRONK,
    It's not fair to bring up the Baja ADV. It's like bringing up a Green Beret or Navy SEAL when talking about US Naval Reserve personnel.
    How many US Soldiers can ruck with a 30lb load with rifle, for 30 miles and still be combat ready at the end of the day?
  15. benlikes69
    Nov 24, 2013
    101
    Do you and your mates really have nothing better to do than troll this forum, critics other people’s opinions and bully this bloke from behind your keyboards about his blog.
    Surely at some point in your lives someone must have said to you that if you have nothing nice to say, don’t say anything at all.
    And don’t try kidding yourselves or others that there is some principle your arguing the case for.
    It’s a free to use forum for like minded people to share useful information and owner experiences.
    Find something else to spend your energies on
  16. GR0NK
    Sep 24, 2006
    9,542
    Stuck in 80s
    Fair enough but you should know better than to generalize like that. :beer
    Sean :D
  17. Nostop
    Nostop Been here awhile
    Aug 25, 2012
    257
    England
    You forget old boy ;0) these people need to be going as fast as possible, to prove they are riding gods. Adventure riding isn’t racing, it’s about enjoying the ride, the view and meeting people.
    Webbiker’s blog has given many on the crf Rally thread some very useful information, I can’t imagine anyone who’s got a Rally or is interested in buying one, would want it banned.
  18. fridolin
    fridolin Been here awhile
    Jun 21, 2008
    397
    The pain in the ass of Donald Trump.
    It's up to the mods to deal with webbikers posts. It's not the business of kyns, anders, jasonmt or anybody else. Just the mods.
    Kartik and Daniel Bonnér like this.
  19. Raabe
    Raabe CAW CAW!!!
    May 29, 2013
    78
    Austria
    Fresh mods and additions, with images.
    QuadLock Moto mount
    Oxford Touring heated grips and Acerbis Rally Pro protectors
    Protectors were extremely pleasant to mount.
    Heated Grips were (almost - right side not so much as left side) a perfect fit
    The mounting bracket for the control unit had to be bent and drilled a bit. As it comes out of the box, the bending is too steep and the holes miss about 3 millimeters to fit perfectly onto the mirror mount.
    Cabling was a bit of a bitch, considering that there is almost no faring to hide any excess cable or any connectors.
    Over all it took me about two hours, most of it really just dedicated to somehow managing the cables at the front so that they are as hidden as possible.
    Next up:
    Better seating
    USB power
    boboneleg and Squily like this.
  20. Anders-
    Anders- 690R
    Aug 23, 2013
    3,219
    Швеция
    How is speaking ones mind equal to being a bully? Bit touchy? :lol3
    (and yes, I'd say the same to someones face, in case you wonder)
    wiswoodsguy and GR0NK like this.
