HONDA CRF250 RALLY OWNERS
Discussion in 'Thumpers' started by ferdiepick, Mar 18, 2017.
  1. minkyhead
    minkyhead Long timer
    Jan 4, 2007
    1,285
    uk gods county
    [/QUOTE]
    off ebay 80 quid ...ive looked and its not listed at the moment ,,so i have no link ..sorry
    Hi-De-Ho likes this.
  2. Cuttlefish
    Cuttlefish Riding to disappear.
    May 31, 2016
    1,836
    Sunshine coast Qld Australia
  3. minkyhead
    Jan 4, 2007
    1,285
    uk gods county
    ahh they are different so the post idid a while back about the spring is missleading
    the spring pins are much longer on the rally and the kick stand does hold up with no problems on rough ground ..
    the 250l stand gave me bad problems with the stand comming down on bigger jolts and even enough to cut the ignition ..it looks like the rallys is a good bit longer
    and thats good ..hopfully the 2017 L stand has improved spring points too
    its easy enough to make a new spring point on the stand simply drill and put a bolt though with two locknots ...if your going to weld the spring point back on
    id go as far to say
    why not just cut the rally stand and weld the foot back on or even a new one ?..seems a cheap easy solution and fine tuned to your bikes height
    if it has the short spring points deffo retain the rally spring and defo dont fit a 250l spring to the new stand
    here is what i had to do to make the 250l stand safe ..a much stronger spring ..and relocating the spring point much further down with a bolt ..you can see the old one that i cut off several inches further up
    it took about an hour to cut weld a 2in extension on and move the spring point
    anyway if you fit a L stand retain the rally spring and attachment points
    and stop falling out ..its a sidestand ferchissakes :hide:hide
    [​IMG]DSC_0419 by minkyhead56, on Flickr
    Knobbly Studios and Hi-De-Ho like this.
  4. Tysonb
    Tysonb Now rolling on a 98 R1100GS, and an 04 XR650R
    Oct 16, 2015
    39
    Lewisporte, Newfoundland, Canada
  5. Tysonb
    Oct 16, 2015
    39
    off ebay 80 quid ...ive looked and its not listed at the moment ,,so i have no link ..sorry[/QUOTE]
  6. Kray
    Kray Long timer
    Jul 13, 2013
    1,627
    Knoxville, TN
    Minky, I bought the CRFL stand and springs (which are an inch shorter) to direct swap over. The thought of cutting and welding on a brand new motorcycle makes my stomach turn. Plus, if we need to lift the motorcycle back up eventually I want to have all the stock parts to do so.
    I've re-ordered the correct parts from a 2017 CRFL and will try again once they arrive.
  7. minkyhead
    Jan 4, 2007
    1,285
    uk gods county
    he he ... i dont worry about such stuff ..to be fair if its done neatly and sprayed over no one would notice
    ..anyway i understand your reasons ..but do retain the spring off the rally and the fixing points ..the old 250l stand is pretty dam dangerous when it starts sagging could easy dig in and pitch you off it is not up to big hits cuts the ignition and sags like a witches tit on rough ground hopfully the 2017 will have the improved attachment points and spring setup
    keep well
    Kray and Hi-De-Ho like this.
  8. Leroybrown238
    Leroybrown238 Adventurer
    Mar 27, 2017
    66
    Melboring Australia
    I have a stupid question, sorry. How do I remove the front wheel? There doesn't seem to be a nut. Do I need a special tool?
  9. docgonzo
    docgonzo Old Gadfly
    Mar 1, 2002
    19,904
    within 20 miles of the Center of the Universe
    I was wondering the same thing yesterday when I was going over my tool kit for the bike. Looks like I have to make a trip to Home Depot to get the correct "allen"....
  10. Snapper
    Snapper Long timer
    Oct 10, 2003
    3,387
    SW CT
    2 pinch bolts and a 14mm Hex wrench (got mine from Amazon for $9). Motion Pro has a multi hex axle tool but I haven't seen it in 14mm.
  11. Kray
    Kray Long timer
    Jul 13, 2013
    1,627
    Knoxville, TN
    Whew. That doesn't sound fun at all! I put something like 10,000 miles on our original CRFL and never had any issues. Wonder if that's why they revised the part numbers for 2017.
  12. hooverider
    hooverider Adventurer
    Jul 28, 2007
    23
    I'm sorry haven't been on the site in days and after I've seen your post I just realized I don't have any new pictures it's time for me to get with it I guess
  13. 1litre
    1litre In over my head
    Mar 15, 2016
    1,257
    Orangeville, Ontario, Canada
    Only you shorter riders :jack oh I'm not that tall either I should shut up!
  14. Pitch
    Pitch Adventurer
    Feb 24, 2017
    76
    Nebraska
    Spent the weekend repairing my front end after a fall in Moab. Used this opportunity to convert to LED flashers and tail light.
    Fun fact, the entire dash is held up via this bent part:
    If you have any questions about the LED conversion, or how to fix this frontend. Let me know.
  15. AnAverageExplorer
    AnAverageExplorer Adventurer
    Mar 30, 2017
    99
    Possum Kingdom Lake, TX
    Got to do a little of this over the weekend:
    This is what the bike was made for. I've decided the soft suspension is perfectly good, if you're blasting back roads.
    MewZiKat, Wind_Rider and Hi-De-Ho like this.
  16. AnAverageExplorer
    Mar 30, 2017
    99
    What did you do to get that kind of damage? And more importantly, you alright?
  17. Pitch
    Pitch Adventurer
    Feb 24, 2017
    76
    Nebraska
    Took a fall on the Slick Rock trail in Moab. Bike was more than capable, I was not. Fell to the right side and broke the flasher (hence the upgrade to LED) and bent this bracket. I was physically unhurt and continued to ride the bike for another week.
    EDIT: Just to add more detail, the fall happened at a very steep decline, with a swtichback halfway down. I was letting 1st gear pull me down and thought I was going too fast to make the turn (I probably wasn't) however if I was I would have dropped 50ft. This resulted in me hitting the brakes which equals instant fall as there is no way to get your feet down. Slick Rock is more like sandpaper, tons of traction. The bike fell on the right side but there was a decline so it probably hit with an additional 3 feet. Had barkbusters on and those protected everything. All in all, I think the bike actually took that damage really well. Nothing permanent or structural to the main frame.
    MewZiKat, Hi-De-Ho and BkADV like this.
  18. fridolin
    fridolin Been here awhile
    Jun 21, 2008
    403
    The pain in the ass of Donald Trump.
    Any damage to the plastics? And how did you fix the front?
  19. BkADV
    BkADV Been here awhile
    Feb 22, 2017
    323
    Brooklyn
    there are parts available for the front lights on bikerzbits
  20. webbiker
    webbiker Been here awhile
    Jul 11, 2010
    268
    Finland
    Tip for the budget minded d.i.y. people. A company called Nawa makes boat accessories and has this rugged plastic mount that happens to fit very well for the dash cross bar. The part is under $10 and I've used the 32mm version on my previous bike with success.
    The part (ss bolts&nuts)
    My first test application
    More details : https://honda250rally.com/2017/06/05/cleaner-better-gps-phone-mounts-for-the-250-rally/
    Sent from my iPad using Tapatalk
    MewZiKat, Hi-De-Ho and Wind_Rider like this.
