    Dismiss Notice
HONDA CRF250 RALLY OWNERS
Discussion in 'Thumpers' started by ferdiepick, Mar 18, 2017.
  1. rexbro
    rexbro Been here awhile
    Aug 4, 2008
    455
    SE PA
    Crappy weather here in Southeast PA - high is ~39F and been raining most of the day. I’m not complaining though because there was some wet snow in the Poconos but temps are high enough that it won’t stick and black ice shouldn’t be a problem tomorrow.
    My girlfriend is working from home for the next few weeks at least and her work requires peace and quiet or she’s on the phone with clients. I made myself scarce by doing bike maintenance in the garage and planning some new routes.
    I had to wash my bike the other day (2nd time since I got it) to fix the fuel filter issue. Today I checked, lubed, and adjusted everything I could think of so maintenance is all taken care of for a few weeks - so much easier on a clean bike!
    Tomorrow I’m looking forward to getting out the door by 9 or 10 am for a long day of dirty roads and social distancing. :ricky:happay
    Brokenoldbiker and JungleDeath like this.
  2. Pilomajajo
    Pilomajajo Adventurer
    Jan 26, 2019
    74
    Netherlands
  3. rexbro
    Aug 4, 2008
    455
    SE PA
    JungleDeath and SnowGS like this.
  4. JungleDeath
    JungleDeath Been here awhile
    May 22, 2016
    257
    Reno, NV
    Bicycle floor pump for top offs and a
    Motopressor at full tire change. It's hard to get a bead to seat with my floor pump.
    This. Is simple, cheap and easy. Preferably with the gauge at the top of the body. Easier on the eyes.
  5. Brokenoldbiker
    Brokenoldbiker Adventurer
    Mar 8, 2020
    70
    Michigan USA
    RileyRallyBike likes this.
  6. Phmode
    Phmode Most of the gear, little idea!
    Nov 29, 2018
    847
    Herefordshire, UK
    I wonder if it was the ethanol content in the fuel. Does it have that sort of effect on stuff? Here in Europe we don't really have much of it and if you stick to the decent stuff it has none.
  7. Phmode
    Nov 29, 2018
    847
    Herefordshire, UK
    It's fine if a little pricey as it is badged Michelin. Here is what I have...
    https://www.nippynormans.com/r1200-adv-lc-2014-on-2018-on/airman-electric-air-pump
    ...and I have power cord fitted with a plug to fit the Optimate charging lead which is fitted straight across the battery so I can use the pump in the field if I need to. A foot pump is all very well but not practical to carry with you.
    For tyre fitting I have a proper compressor but at 35 kg I can't carry that and a 5 mile power cord on the bike :-)
  8. minkyhead
    minkyhead Long timer
    Jan 4, 2007
    1,463
    uk gods county
    did you here the one about daddy pig mummy pig and baby pig
  9. Pilomajajo
    Jan 26, 2019
    74
    Netherlands
    I have tried a few bicycle floor pumps, even supposedly high quality (SKS airworx). Pumphead malfunctioned within a year.
    Also have one of these (see pic). Fried a fuse on the weestrom at first use..
    JungleDeath likes this.
  10. rexbro
    Aug 4, 2008
    455
    SE PA
    Blackburn pumps are what I’ve used for years with my bicycles and motorcycles.
  11. Brokenoldbiker
    Mar 8, 2020
    70
    Michigan USA
    Epic ride! Beautiful country! Would like to know the artist in the first track, I liked it. Your suspension work really looks like it has paid off in those rock sections, looks very stable. Need to reread your conversion on the fork to get a shopping list, that looked KTM stable. Briefly thought about looking for a blown up KTM and putting the Honda motor in it after I got this heavy pig stuck in the mud . Ha! 100 pounds is huge when you are pushing! Thanks.
    minkyhead likes this.
  12. Brokenoldbiker
    Mar 8, 2020
    70
    Michigan USA
    We have Non-alcohol premium around here. Manual says 87, but with an ICU controlling timing I can't see the harm in running the Non. I use it in all my small engines and have not had to rebuild a carb in years. Will be in next tank.
  13. Phmode
    Nov 29, 2018
    847
    Herefordshire, UK
    The ECU may indeed control the timing but the Rally doesn't have a knock sensor so it can't compensate for the fuel you use. Brian
    Brokenoldbiker likes this.
  14. Brokenoldbiker
    Mar 8, 2020
    70
    Michigan USA
    Ah, did not know that, but higher octane will not cause knock, just has less energy in it so in the interest of being alcohol free..... At the very least the last tank of the season should be alcohol free for those of us up here in the snow belt. I know they make provisions for it when they design, but the moisture it collects in winter will still be harmful . Going to try some today and see how it runs.
  15. Phmode
    Nov 29, 2018
    847
    Herefordshire, UK
    And that is why you should connect the pump directly across the battery and fit a higher rated fuse in the line. I keep my pump well away from the on-board electrics. Brian
    Pilomajajo and RockyDS like this.
  16. Phmode
    Nov 29, 2018
    847
    Herefordshire, UK
    Another great vid, as usual. I didn't even see the rock/hole that got you off (so to speak), and I guess, nor did you :-)
  17. minkyhead
    Jan 4, 2007
    1,463
    uk gods county
    its very nice now much more surefooted in the rugby ball roacks and the like ....and the rebound is obviuse when hitting summet fast it just doesnt bounce up anywhere near as much ...that said i really dont theink the stock set up is that bad .....a bit stiffer and better rebound stack it would be fine ....i dont think they do a bad job at all overall :hmmmmm ....but i wont be swopping back anytime soon :D
    music is lightening bolt by jake bugg
    braaaaaaaap
  18. vbonline
    vbonline Adventurer
    Aug 23, 2014
    46
    Switzerland
    Hi,
    Anybody with a source for fitting short brake and clutch levers for a 2018 CRF250 Rally (MD44)?
    I got a pair from China, but they are not fitting.
    I drive short levers on all my bikes and I really want some for my "Africa Single" :-)
  19. Ed@Ford
    Ed@Ford Long timer
    Jan 16, 2004
    3,775
    Dearborn MI
    I had similar issue with shorty chinese made levers. Aliexpress I think. Brake lever works perfect. Clutch doesn't. I tried remachining it to get the correct pivot bolt hole. Still no luck. Others have had similar luck. However....I think...someone came up with a shorty clutch lever that DOES work...maybe he/she/they can comment. The machine work on them is outstanding...but most made them to the wrong dimensions.
  20. 78er
    78er Been here awhile Supporter
    Aug 10, 2017
    143
    Dumaguete City, Philippines
    I fixed my stock clutch lever with a Dremel. Very happy with the result.
    thanossw1 and BarryB like this.
