Honda Moly 60 paste alternatives
Discussion in 'Australia' started by adv_rider, Jul 7, 2009.
  1. Big Willy
    Big Willy Gen. Italia
    Nov 28, 2008
    4,446
    Sunshine Coast
  2. dirtsurfer
    dirtsurfer Adventourer
    May 10, 2006
    3,384
    On the road to recovery
    I think I have some at home if you want a dab. I can post it up to you
    #22
  3. BergDonk
    BergDonk Old Enough to Know Better
    Nov 15, 2010
    9,635
    Snowy Mountains Oz
    #23
  4. Gunerdo
    Gunerdo fromwanerbe
    Aug 3, 2017
    332
    Westraya
    Clymer workshop manual, as an alternative, recommends never-seize.
    The silver shit that gets every-where, once you take the lid off.
    #24
    spokester and Big Willy like this.
  5. Beemerboff
    Beemerboff Long timer
    May 23, 2005
    3,146
    Adelaide, South Australia
    Maybe find out what Honda recommend in its place - I bought four tubes of the 60 while i could!
    I assume that you want it to lube the splines on a paralever driveshaft - before Moly 60 we had a similar problem with the IRS on our Triumph cars and we used a special Renault grease supplied for the CV joints on their FWD autos .
    #25
    spokester likes this.
  6. Quirky
    Quirky Been here awhile
    Nov 11, 2011
    715
    Denman, Oz
  7. diabolik37
    diabolik37 Deadly Gubba
    Jan 15, 2008
    2,938
    Down Under QLD
    Yes.. the Moly 50 that you can buy in any good tool shop around Australia... Being using it for years...
    #27
    Big Willy likes this.
  8. farqhuar
    farqhuar Human guinea pig
    Mar 3, 2008
    2,466
    Islands in the sun, Oztralia
    Castrol LMM for me. Available at any BP servo as well as the usual AutoBarn, Supercheap and Repco etc. stores.
    #28
  9. Gunerdo
    Gunerdo fromwanerbe
    Aug 3, 2017
    332
    Westraya
    #29
  10. Boxa
    Boxa 2 Smoking Barrels
    Jul 22, 2014
    418
    Adelaide Hills
    Aussie made Molybond. https://www.itwpf.com.au/molybond-lubricants/ga50/
    "GA50 – An assembly compound containing 50% of molybdenum disulphide in a lithium based grease used as an anti-seize and anti-scuffing compound for metal parts which may reach temperatures up to 400°C. It has excellent anti-seize capabilities compared to nickel and copper based anti-seize compounds and is extremely effective in preventing fretting corrosion in closely fitted parts assembled using freezing or heating techniques. It can be used for mechanisms which may not be lubricated during service life."
    #30
    BergDonk likes this.
  11. Brian Barr
    Brian Barr n00b
    May 22, 2010
    6
    Alberta, Canada
  12. Hay Ewe
    Hay Ewe Just a Wannabe
    Jul 17, 2005
    6,380
    FNQ - AUS
    Munich bmw over in perth have small tubs for when doing cluthch changes, thats i used.
    Other times i use Thixo-grease.
    Bell helicopters allow its use on spline drives and main rotor grips. If its good enough for them, its good enough for me.
    #32
  13. SaAdvRider99
    SaAdvRider99 Been here awhile
    Apr 26, 2015
    342
    Adelaide Hills South Australia
