Honda Rebel 300 Impressions
Discussion in 'Road Warriors' started by cabanza, Jun 27, 2018.
  1. cabanza
    cabanza Smooth is Fast
    Nov 7, 2004
    13,165
    Kapolei, HI
    Who cares about a slipper clutch? It's getting new suspension!
    #61
    frog13 likes this.
  2. Matt-J2
    Matt-J2 Been here awhile
    Feb 20, 2018
    907
    Appleton, WI
    #62
    frog13 likes this.
  3. cabanza
    Nov 7, 2004
    13,165
    Kapolei, HI
    I really like the new matte blue jeans color. I just wish Honda would include the passenger pegs and seat as standard.
    #63
    TheHeretic likes this.
  4. cabanza
    Nov 7, 2004
    13,165
    Kapolei, HI
    Honda has redesigned the seat and made it thicker but seat height remains the same somehow.
    #64
    frog13 likes this.
  5. cabanza
    Nov 7, 2004
    13,165
    Kapolei, HI
    Dash now has a gear indicator
    #65
    frog13 likes this.
  6. cabanza
    Nov 7, 2004
    13,165
    Kapolei, HI
    Europe will get an "S" version with a cowl and other accessories. I hope the cowl will be available as an accessory here in the US.
    #66
  7. cabanza
    Nov 7, 2004
    13,165
    Kapolei, HI
    #67
  8. AwDang
    AwDang Enabler
    Sep 1, 2014
    4,542
    MABDR mile 0
    Oooo......I wonder if the dash retrofits
    #68
    Isabella2012 likes this.
  9. Isabella2012
    Isabella2012 n00b
    Apr 9, 2019
    8
    Atlanta
    I was just wondering that myself.
    #69
    AwDang likes this.
  10. alex4515
    alex4515 Been here awhile
    Sep 17, 2018
    128
    DFW, TX
    That looks great! My wife is eyeing this as her first bike, would be a good match for my CB300F.
    #70
  11. AwDang
    AwDang Enabler
    Sep 1, 2014
    4,542
    MABDR mile 0
    Parts books are out for the 2020’s!
    The slipper looks like a direct swap for all 300’s. The cover part number remains the same pre and post slipper. I’m ordering the parts and will install it in my CB300R.
    I’m waiting for the service manual and wiring diags to determine if the dash is a direct swap. They use the same plug it appears. But the wiring harness part number is different between 2017 and 2020 Rebels.
    #71
    Matt-J2 likes this.
  12. alex4515
    Sep 17, 2018
    128
    DFW, TX
    Good info! If you have a chance to determine whether the headlight and taillight would be direct swaps, that’s what I am most curious about.
    #72
    frog13 likes this.
  13. AwDang
    AwDang Enabler
    Sep 1, 2014
    4,542
    MABDR mile 0
    Sorry, I didn’t even look at them.
    The LED HL on my 300R uses a non standard connector compared to a normal HL. So atleast that and the flasher will need to be swapped over.
    That said, I’ll have the 2020 service manual in a week or so and will look into it.
    #73
  14. AwDang
    AwDang Enabler
    Sep 1, 2014
    4,542
    MABDR mile 0
    first, all my research is based on a Rebel 300. If you have a 500, your on your own. I have no idea if these mods will work or not.
    second,
    All of my comments are based on what I’ve found in the service manual, parts listings.
    speedo,
    This does NOT appear to be backdate able without extensive upgrades. You’ll need a wiring harness and a gear position switch at a minimum.
    turn signals
    They appear to be a straightforward 2 wire swap over. Don’t forget to get an LED compatible flasher.
    Tail lamp assy
    Appears to be plug and play
    LED headlight
    The ‘20 uses 3 wires in a different 4 wire connector. It would be possible to replace the connector on an old bike and mount this lamp. BUT, due to parts costs.It’s more cost effective to go aftermarket with a normal H4 connector.
    Slipper clutch
    Is NOT plug and play. I’m building a parts list / instructions post for whats required.
    #74
  15. cabanza
    Nov 7, 2004
    13,165
    Kapolei, HI
    I've been looking at this bike the past 3-4 days. I had a CBR250R. Does the Rebel 300 rev high like the little CBR?
    #75
  16. boothmoto
    boothmoto Adventurer
    Sep 19, 2018
    26
    Western MA
    It revs out to 10.5k like the cb300 models. It is tuned slightly differently to increase torque at lower revs but it still pulls hard all the way to the limiter.
    #76
    frog13 likes this.
  17. AwDang
    AwDang Enabler
    Sep 1, 2014
    4,542
    MABDR mile 0
    ^that
    The Rebel pulls a +1 counter sprocket much easier than the CB3. But lacks in top end comparatively.
    #77
  18. frog13
    frog13 Long timer
    Feb 10, 2007
    3,606
    SW Ohio
    A TTO tach would work.
    #78
  19. frog13
    frog13 Long timer
    Feb 10, 2007
    3,606
    SW Ohio
    Hopefully the suspension is a bit better on the 2020 models.....vs the 2019 model I test rode last fall ( spine whacker is was).
    #79
  20. cabanza
    Nov 7, 2004
    13,165
    Kapolei, HI
    #80
