Honda SH 300
Discussion in 'Battle Scooters' started by Paulvt1, Apr 26, 2009.
  1. John Bentall
    John Bentall Been here awhile
    Jan 11, 2011
    210
    London UK
    Unusual to find a guy doing the taxi driver exam on anything larger than a 125.
    The screen is great and one can remove the upper half when it gets hot.
    Just fitted new tyres (Michelin Citygrips) and front pads at 10,700 miles. I found the Dunlop Scootsmarts either difficult to obtain or 35% more expensive than the Michelins.
  2. HondaBlue
    HondaBlue n00b
    Sep 14, 2011
    5
    London, United Kingdom
    Hey Guys,
    My SH is about to come out of its 2 year warranty and im wanting to change the oil and oil filter myself to save a few pennies, i'm used to doing this on cars so have an idea, but would just like some advice as to how to go about it and where best to get the parts, what oil to use, that sort of thing as every penny helps in these current economic times and i would appreciate the help. My honda dealer charges about £60 an hour i think so my normal service is costing me £140 a pop :eek1
    I have looked on your tube for any videos but there aren't any.
    thanks for any comments or help.
    Cheers
    Mike
  3. Steve_Dalton
    Steve_Dalton Scooterist
    Mar 2, 2011
    20
    Essexshire
    Really easy to do. From memory, you need a couple of litres of 10w/40 oil. If you buy this from ebay you will get at least two oil changes from it - http://www.ebay.co.uk/itm/Honda-SH-...pt=UK_Motorcycle_Parts_13&hash=item41671a2913
    Warm the engine up, remove the sump plug and drain the oil, unscrew the filter and screw the new one on, put fresh oil in it and check with the distick (do not screw it in), run the engine for a couple of minutes and then recheck and top up. Job done.
  4. HondaBlue
    HondaBlue n00b
    Sep 14, 2011
    5
    Thanks Steve, i just phoned up and now the service is going to cost me £300+ :eek1:eek1:eek1 , i will definitely do the oil and oil filter myself and thanks for the link, although it gets worse now, Its the 12K service, so its new belt,rollers and sliders they say, is this all true ??...is it possible to holding out until say 16K or do they really need doing at 12k...i can't do the roller and belt as i don't have those skills....but would be happy if you guys can confirm that im not getting ripped off.
    Cheers
    Mike
  5. HondaBlue
    HondaBlue n00b
    Sep 14, 2011
    5
    Just one other thing Steve, is the oil filter easy to get to ??...many panels to remove or difficult screws to undo to get to it ?
    Just like to know before i have a crack at it,
    many thanks!
    Mike
  6. Steve_Dalton
    Mar 2, 2011
    20
    Essexshire
    Oil filter easy to get to - no panels need removing. I changed my belt and rollers at about 12,000 miles. Didn't change the sliders though. I think I paid around £100 for a genuine Honda belt and rollers. I only changed them beause the rollers were sticking and making it sluggish on pull away. I suppose if it's okay and money's tight you could leave it a bit longer. At 12,000 miles I think the plug and air filter will need changing too. Whereabouts in London are you - do you have any independent motorcycle repair places nearby?
  7. John Bentall
    Jan 11, 2011
    210
    London UK
    Hi Mike,
    A service, brake fluid change, MOT and belt and roller replacement cost me £203 incl VAT at Metropolis motorcycles in Barnet, N.London.
  8. Steve_Dalton
    Mar 2, 2011
    20
    Essexshire
    Blimey, they must have been working for next to nothing! Assuming genuine parts were used, Belt and rollers cost me £95. Oil and filter must be another £25. MOT is nearly £35. If it was a 12000 service there's the air filter and spark plug - at least another £20 and say a fiver for brake fluid. I make that lot £180 if you were doing it yourself, buying the parts and paying for an MOT.
    If they are only charging £23 labour for all that I'd get down there a bit quick!
  9. John Bentall
    Jan 11, 2011
    210
    London UK
    No air filter or plug in that service. Definitely genuine parts and also worn parts returned in a plastic bag.
    They are good value and friendly.
  10. zippy500
    zippy500 n00b
    Jun 25, 2013
    1
  11. Taipan
    Taipan Adventurer
    Mar 1, 2005
    97
    Essex, England
    Hi All
    Anyone got a download link for the workshop manual for a Sh300?
    Many thanks
  12. Taipan
    Taipan Adventurer
    Mar 1, 2005
    97
    Essex, England
    Hi All
    Trying to fit a new sidelight bulb too my Sh300 but cant get the central panel off? The manual says,
    "Position Lights Bulb
    1. Remove the front shield(1):
    unfasten the top screws (2), disconnect
    the two expansions pins (3) and remove
    the shield by disconnecting the bottom
    tabs(4). "
    But I cant see any expansion pins?? Anyone taken this panel off?
  13. Taipan
    Taipan Adventurer
    Mar 1, 2005
    97
    Essex, England
    Boing! Tried again last night but cant see how to release where the panel is fixed at the midway points? Must be missing something obvious here, beside a brain that is!
  14. Taipan
    Taipan Adventurer
    Mar 1, 2005
    97
    Essex, England
    For the benefit of the archives, I managed it last night. The little push clips grip the panel very tightly. i had to wiggle a screwdriver in and prise the panel out each side. I managed to do this without breaking anything despite the stupid designs best efforts. The little clips dropped down into the abyss behind the radiator. I put the front wheel up on the kerb and bounced it about and they both fell out of the grid bit! I reluctantly refitted them. Still I now have two sidelights working so it was worth it. Crap design by Honda though.
  15. SAVVAS
    SAVVAS n00b
    Apr 10, 2014
    1
    Athens Greece
    Hi everybody and greetings from Athens Greece.
    I have read the posts here for a while but i managed to enter the forum just the other day.
    In order to help the fellow owners who like to do service by themseves i 'll show some videos of our foum, i hope they 'll help you.
    PS : Forgive any spelling problems.....
    Changing the front brake pads and cleaning the pistons of the brake caliper :
    https://www.youtube.com/watch?v=heggkhJXvxQ
    https://www.youtube.com/watch?v=hXvUBg6wfPg
    I hope they will help you.:beer
  16. Mick27
    Mick27 n00b
    May 3, 2015
    8
    England
    I've just bought a nice used example of the little Sh300, my first scoot and I'm pretty impressed with it. I just wanted something cheap and small for the daily commute, through the traffic its actually quicker than my other bike a Honda Crosstourer, simply becaue its so narrow I can filter through the queing traffic far easier. Anyway, the reason I'm posting is that I also had real difficulty removing the upper most cowl above the clocks, it had to come off to get at the brake fluid reservoirs. I did manage to break one of the retaining hooks unfortunately but now I know how to do it its fairly easy. The trick is to prize the cover straight upwards from the riders seat side first, there are two expansion clips on this side plus two hook clips on the side nearest to the front wheel, if try you pry those upwards you'll break them, just like I did. There are also a couple of smaller hook / clips on the black side pieces of the cover, these didn't cause too much difficulty though. It does take quite a bit of force to release those expansion clips though. I've posted some pictures of the various panels, hopefully it may help someone trying to do the same in the future. https://s3.amazonaws.com/advrider-photobucket-images/images/M/Miffas100_Sharing%2520folder_Honda%2520SH300_P1000814_zpsclg3xztj.jpg
    https://s3.amazonaws.com/advrider-photobucket-images/images/M/Miffas100_Sharing%2520folder_Honda%2520SH300_P1000816_zpsvjoltghc.jpg
    https://s3.amazonaws.com/advrider-photobucket-images/images/M/Miffas100_Sharing%2520folder_Honda%2520SH300_P1000817_zpswpsgljcl.jpg
    https://s3.amazonaws.com/advrider-photobucket-images/images/M/Miffas100_Sharing%2520folder_Honda%2520SH300_P1000827_zpsisq5rzya.jpg
    https://s3.amazonaws.com/advrider-photobucket-images/images/M/Miffas100_Sharing%2520folder_Honda%2520SH300_P1000825_zpswsxvujre.jpg
    https://s3.amazonaws.com/advrider-photobucket-images/images/M/Miffas100_Sharing%2520folder_Honda%2520SH300_P1000821_zps8j08iuze.jpg
  17. Jerry_R
    Jerry_R Adventurer
    Apr 29, 2013
    42
    Hello, does anyone have an idea, how suspension of longer SH300 compares to SH150?
    The reason I ask: I used to have SH150 (latest model) and had to sell to, as I was feeling constant backpain. I ride in the city mostly.
    I also was riding Yamaha Xenter, SH competitior, which has motorcycle suspension (MONOCROSS, like Yamaha TMAX) and it was quite acceptable to my back. But it has no ABS, so idea came up to think of 2015 SH300 again (putting a helmet under the saddle is also a plus).
    Anyther questions, when 1st SH300s were available - there was no yet Honda Integra 700\750 on the market, would SH300 users consider buying now Integra instead of SH300? Doesn't it seem to be better choice, at least for some of you?
    Cheers,
    Jerry
  18. pingo
    pingo Adventurer
    Aug 15, 2009
    38
    Slovenia, Coastal region
    I am reviving this thread. What is the situation today, is SH 300i still worth buying? I am looking for something that looks and feels small, agile and fun in the city but is strong enough to accelerate to 120kph occasionally.
    1. How does SH 300i feel when driving at low speeds (30-50 kph)?
    2. I am wondering what is the difference between SH 150i and SH 300i? How do they compare in weight and maneuverability?
    3. What are the 300's main competitors and how well can they compare? I have seen mentioned the Sim Citycom 300i and Kymco 300 People GTi is there anything else I can take a look at?
  19. Claude Bottom
    Claude Bottom n00b
    May 21, 2018
    3
    Frankfurt am Main
    Hi there Pingo,
    From what I've read, the SH300i is still the best option for handling, technology and reliability, so I'm planning a test ride of an SH300i in the next week or so.
    In addition to the Sim Citycom and the Kymco, other alternatives I've been considering are the Vespa 300 GTS or the BMW C400X.
    The Vespa is much better looking than any of the Honda, Sim Citycom or Kymco. Frankly, those three are all great scooters, but they're all pretty damn ugly. The Honda seems to lead from the handling, technology and reliability aspects, but the Vespa still offers something the Honda doesn't. It appeals to the heart not the head, but you're paying a big premium for its looks which, for me, isn't worth it. The BMW C400X could also be a great alternative, but it's a bit of an unknown at the moment. It's not going to be available for a few months yet, and even when it is available, it's going to be in a totally different price bracket.
    But still, at least it's nice to have a choice! Good luck with your decision...
  20. aguim
    aguim Long timer
    Dec 27, 2007
    1,050
    Northern Quebec
    Zippy, SH engine is same as Forza, so :
    First, the stock variator is in no need of replacement. Good stuff from Honda. Just clean it,
    change the rollers, add a tiny bit of moly to the crankshaft, collar, seal lips, bolt threads,
    and you're done (making sure NO grease ends up on the belt or sheaves of course).
    Then the belt cannot be removed without pullling out the driven pulley, too. So while at it, you should lubricate its insides. Big nut is 41mm (1 5/8" fits) -- watch out, there's a relatively strong SPRING behind that clutch-shoe plate ! ). Moly grease is used on the cam grooves and pins then made accessible. Same moly grease should be used on the 2 inner input shaft bearings. The whole clutch-shoe plate can be re-installed using light gorilla gymnastics (as shown by many internet videos). No drama mechanicals here, just basic prudence...
    TORQUE VALUES are : Variator bolt (14mm head) : 61 pounds (83 N-m) /// Bell nut (17mm head) : 55 pounds (74 N-m) /// clutch-shoe plate 41 mm nut : 58 pounds (79
    N-m) . Personally I use a small electric impact gun and tighten all 3 "just enough" -- but I understand this is not standard procedure, so...(no, haven't seen parts flying off, nor threads ruined, yet)*
    *with time, most mechanics develop 'torque feel' with small impact guns.
    Note : to facilitate belt installation, introduce a small piece of wood/plastic/whatever
    between the 2 Driven's sheaves, this will let the belt sit comfortably high against
    the Variator's movable one. Take it out once the Variator's 14mm-head bolt has been tightened ( I use a 1/4 x 4" stick ).
