Honda TLR200 Reflex carb carburator fix jetting thread.
Discussion in 'Trials' started by taxonomy, Mar 12, 2012.
  1. taxonomy
    taxonomy The Most Liberal Person in the World.
    Jan 21, 2012
    29
    Northampton, MA
    I recently purchased a Honda TLR200 Reflex. In stock condition the bike is jetted pitifully lean, is hard starting and has poor throttle response, runs hot and will not idle well.
    The TLR is not blessed with a common carburetor that takes common jets. So, fixing the carb is a problem and most people resort to putting a CRF or XR100 carb. There are problems with this. For one the air box boot needs to be stretched over the larger intake of the xr/crf carb. It will get around it but you're stretching 24 year old rubber. Damaging it is a concern and your talking about replacing parts on a bike with many obsolete parts. You'll also need a new throttle cable, and there are conflicting reports if a standard xr or crf cable will work. A good used carb will cost you around $70 on eBay (be sure you get the right one!) and the cable will be about $25 before you get jets.
    The good news is you can make the stock carb work very well!
    Your going to want to get Honda parts:
    99124-076-0400 #40 slow jet. This is the most important and hard to find part. It's some odd Keihin slow jet that isn't commonly stocked. Since it's a very important jet at small throttle openings it's very important for a trials bike. I think this part is actually for a CB400F but it works in the strange PO Keihin carb that comes stock on the TLR. I am not arguing.
    99101-GHB-1000 #100 Main Jet. I know that most posts list the 105 main jet, but I used a 100 and like it. Also, the main really only comes into full play with the throttle wide open. So, for this bike it doesn't matter too much and it works great in my application.
    16012-KJ2-305 which may have been replaced by 16012-KJ2-672 mine came from my local dealer who ordered it as part 16012-KJ2-305 and that what it says on the package but I couldn't find a reference for it on the web. The kit contains a new needle jet and air screw and also a cap for the air screw that will let you manipulate it even though it's behind a frame tube. It was issued by Honda when it became apparent that the stock carb was hopelessly lean.
    If you dissemble and clean your carb this will take care of the lean condition and allow you to retain the stock carb. All up parts should cost around $40.
    Don't worry too much about the main jet, you really want the #40 slow jet and the needle. That's going to make everything good up to well past 3/4 throttle. With my air screw 1 1/2 turns out the bike starts on one kick from cold with the choke full on and will run almost instantly with the choke closed. It's very responsive and has much better power than I would have thought it could have.
    I am new to trials this year and the TLR will serve me as a novice. It's steet legal so I don't need to load it into a truck to take it out of my urban home to practice and I am sure the problems will come from my lack of skill rather than the bikes short comings.
    It's already been geared down and I have a set of the B&J "down and wide" footpegs en route. Real trials tires go on next week. I am booked at a one day skills camp.
    You may also want a new air cleaner 17211-KJ2-002and carb rebuild kit 16010-107-305. The air filter and gasket kit will set you back a further $18.
    Even though I have posted internet links for all the parts, this was for reference. I recommend buying these parts from a local dealer. In my case the shipping made the parts more expensive than the dealer, and I believe in supporting local businesses. After all when I need something quick I want them to be there. Being known at the parts counter is worth something too. Most dealers will give AMA or other club members a 10% discount.
    Happy Jetting.
    motobene likes this.
  2. neilking
    neilking Been here awhile
    Mar 1, 2008
    507
    Austin, TX
    Thanks man! I'll give that a try.
  3. taxonomy
    Jan 21, 2012
    29
    Northampton, MA
    Please post back here when done I'd love to see your result!
    Adam
  4. Twin-shocker
    Twin-shocker Long timer
    Jan 28, 2012
    1,779
    If your TLR has done very low hours from new, and the carb body, slide, needle, needle jet, are not noticeably worn, and you are happy to retain the very restrictive stock air cleaner set up, then changing the jetting will certainly greatly improve TLR's which have been jetted very lean to comply with US emissions rules.
    However its worth bearing in mind that a Mikuni pit bike carb from Ebay (about £20 in Uk), and modification of the stock air cleaner set up, will mean increased performance as well as far better running at all engine speeds.
    onefootinthegrave likes this.
  5. taxonomy
    Jan 21, 2012
    29
    Northampton, MA
    My impression is there are no high mile TLR200s. 3000 would seem a lot for a bike that has an too low seat and really isn't geared for anything over 30 miles. Most seem to be forgotten relics that never really fit in anyplace.
    If I wanted a much more powerful bike I would buy one. For me, the much improved throttle response is fine, but the TLR will never be a fire breather. I just want it to work right.
    I don't really know, mine is certainly has "increased performance as well as far better running at all engine speeds". The oft recommended replacement is still a 22mm carb, it's just easier to get jets for and a more common and better understood unit. The change in performance was dramatic when I got it set up properly. FWIW it's useing more or less the same jets as I have seen recommended for the Mikuni and or CR/CRF carbs.
  6. Twin-shocker
    Jan 28, 2012
    1,779
    If your carb is not badly worn and doesnt have a porous float, then changing the jetting will make running much better.
  7. montibank
    montibank Happy
    Feb 7, 2007
    3,196
    Fresno, Ca
    Thanks for posting this info! Very helpful rejetting now... And as expected my local shops couldn't get the parts I needed. :D
  8. montibank
    montibank Happy
    Feb 7, 2007
    3,196
    Fresno, Ca
    Well got my pilot and needle (finally) but no time to test it yet. The main I ordered is on back order, and my forks are in a million little pieces all over the workbench waiting (impatiently) for oil/dust seals to arrive from another vendor. Will post up with results as soon as I get the thing all back in one piece.
    #8
  9. montibank
    montibank Happy
    Feb 7, 2007
    3,196
    Fresno, Ca
    Well crap... My petcock is leaking pretty bad. I ground the rivets out and pulled the rubber out and it is pretty fooked. Tried rebuilding it but its trashed. Anyone know a direct bolt on petcock replacement from another model machine? Gonna head down to the motorcycle salvage place in town to see what they got in stock.
    #9
  10. dean-o
    dean-o Dabs often
    Sep 27, 2005
    1,465
    old hickory,tn
    like it in mine & shimmed the needle up about .025"
    simple, fun ride...
    dean
    #10
  11. montibank
    montibank Happy
    Feb 7, 2007
    3,196
    Fresno, Ca
    Pilot seemed just right running really good. Found a petcock that bolted right up.
    Seems a little flat with the supplied needle, but I didn't shim it - next time I have the carb out I will shim it and see.
    #11
  12. hoffa509
    hoffa509 Adventurer
    Nov 28, 2006
    49
    Elkton, Md
    I did the same mods to mine with great results. I did tear the eningine down to make sure everything was spec. You can see my low budget build in my signature.
    #12
  13. Bark
    Bark Panic Dancer
    Jun 26, 2012
    84
    Currently N California
    I realize its been 5 months since this thread was posted on but what the heck.
    Just wanted to add that when I bought my Reflex new in 86 it would die when I quickly gave it the gas. It also seemed to run a little cold.
    This resulted in it constantly embarrasing me because I would be on a log or rock, give it some gas, the bike would die throwing me forward so my knee would hit the horn button.
    It was sort of like anouncing "BEEP---Look at me Im going to crash".
    After bugging the Honda dealer they finally found out that there was a technical bullentin out on it along with a recommended repair kit. They got the kit and installed it. I believe it had a jet and a screw in it but cant remember.
    Anyway, it fixed the problem. Supposedly one of the few changes they made to the 87 model was to fix the problem at the factory.
    The other thing is that for me, a few thousand miles is not high mileage on these bikes. Mine only has 7k miles on it (some of it pretty rough) and still runs very strong. The only engine work has been frequent oil changes (been using synth since 87) and valve adjustment.
    In Quartzite Arizona I ran into a guy with an 87 who had 24k miles on his. He did not do any serious off roading (he had it licensed) but did some desert riding along with puttering around towns (he traveled with it on his RV).
    Anyway, just wanted to say that I think they are the greatest "puttering" bikes made and I hope to get another 26 years out of mine.
    #13
  14. McDerry
    McDerry n00b
    Feb 23, 2016
    5
    Maine
    The hot ticket is an 85 200x carb. 38 pilot 1 1/4 turn on pilot screw. 102.5 main. Factory gearing. Snorkel pulled out of air box. Has power enough to hit 60 mph.
    #14
  15. lineaway
    lineaway Long timer
    Oct 1, 2011
    16,466
    Edgewood, New Mexico
    Stock gearing does not work for TRIALS!
    #15
  16. McDerry
    McDerry n00b
    Feb 23, 2016
    5
    Maine
    And that has what to do with getting power out of the TLR or being able to have it rich enough to perform well.
    #16
  17. lineaway
    lineaway Long timer
    Oct 1, 2011
    16,466
    Well we usually run the 200X head and cylinder too for real power!
    #17
  18. McDerry
    McDerry n00b
    Feb 23, 2016
    5
    Maine
    And how's the cylinder add power? I can understand the higher compression piston and the cam out of a 200x.
    #18
  19. lineaway
    lineaway Long timer
    Oct 1, 2011
    16,466
    The cylinder has bigger fins to dispense heat since we mainly ride slow, the head has bigger valves.
    #19
  20. McDerry
    McDerry n00b
    Feb 23, 2016
    5
    Maine
    Got yah. Easier to use the 200x head then have valve seats cut in the TLR head. Will have to put the 200x jug on the shopping list.
    #20
    montibank and lineaway like this.
