hot for the Ohlins on the AT? Read on...
Discussion in 'Japanese polycylindered adventure bikes' started by Greg the pole, Aug 7, 2019.
  1. madafakinges
    madafakinges SUPERENDURO
    Nov 14, 2009
    176
    POLAND
  2. Motociclo
    Motociclo Long timer Supporter
    May 18, 2017
    1,129
    I used a 0.05mm shim in my original AT forks to reduce slop.
    The slop may contribute to anodising lose, made zip difference to my stock tubes post Kashima coating.
    Tubes are just to flexy.
    I found the ATAS fork tubes had tighter clearance.
    From what I have researched, 0.10 to 0.20mm is a good bush/tube clearance.
    I found the ATAS tubes were in this range. From memory, 0.16mm on mine. Not worth shimming.
    My original AT tubes were 0.25. Way to much.
    With shim, 0.15mm.
  3. mentolio
    mentolio King of the island of unwanted toys...
    Jul 14, 2016
    843
    Where do you guys source your material for shimming the bushing?
  4. Motociclo
    May 18, 2017
    1,129
  5. mentolio
    Jul 14, 2016
    843
    Ok, thanks!
  6. NorskieRider
    NorskieRider Long timer
    Mar 19, 2011
    1,296
    Minnesota
    I'd be curious to know if Ohlins is aware of this issue? Or the retailers who re-sell Ohlins? If you had purchased your forks new, would this be a warrantied?
  7. mentolio
    Jul 14, 2016
    843
    Not fixing this problem doesn’t seem to bother Honda. Maybe Ohlins would care more about their rep? Hope so...
  8. gve.mcmlxxiv
    gve.mcmlxxiv 2016 Africa Twin DCT No.272
    Sep 5, 2017
    423
    Arkansas
    I have a supply for 10 lifetimes. If you PM me a US address I can put Africa twin sized pieces in the mail box if you are serious about doing it. I’m happy to help out AT do it yourselfers because so many of the people In The know here have helped me with their time and knowledge.
    I ended not using the shims though when I put ATAS uppers on my AT lowers.
    Amphib likes this.
  9. gve.mcmlxxiv
    Sep 5, 2017
    423
    Arkansas
    The problem is a matter of degree. For some people they will never have a suspension dissatisfaction they ride tame and like the Cush. The guys that hang out here are the obsessive hobbyists in pursuit of the perfect suspension and we abuse it along the way. I don’t fault Honda too much because motorcycles need a lot of maintenance in general, but the springs could have been made stronger with an extra shim or two in the valves for $0.00. That was must have been a compromise to hit a deadline. Like they saved it for last and ran out of time to tune.
  10. Lost Cartographer
    Lost Cartographer Been here awhile Super Supporter
    Feb 7, 2011
    756
    AZ and CA
    They had a 13 year gap to tune it ;)
  11. Greg the pole
    Greg the pole There are no stupid questions, only stupid people
    Mar 1, 2011
    2,225
    Calgary, AB
    I don't think they care.
    The excuse for lack of top out is the tampon does its job.
    Coating? you're riding it too hard.
    Not even going to bother.
  12. Greg the pole
    Mar 1, 2011
    2,225
    Calgary, AB
    Same deal as honda..prob even less care now that they switched hands. If Rossi is unhappy with his setup, he's got a few ohlins guys mulling around his garage...I checked, there's no ohlins guy hiding in mine. Just riding it now, not really getting bothered by it. Will check the forks this winter for coating wear
  13. Greg the pole
    Mar 1, 2011
    2,225
    Calgary, AB
    someone said they were too busy on the dct...likely very true. Just like yamaha, suspension is an afterthought.
  14. Greg the pole
    Mar 1, 2011
    2,225
    Calgary, AB
    If one can actually pull it off, SSS complete forks, AT bottoms, or Ohlins bottoms, simply sell the forks separate to the bike. Or lose the one disk.
    But it's not a straight forward job. Far from it. if @Camel ADV has four or so vids on the process, it's not a walk in the park.
  15. Junglejeff1
    Junglejeff1 Long timer
    Oct 20, 2016
    4,708
    Upper Michigan
    The lower AT lugs don't have enough meat on them to machine out for the extra 4 mm,I have a set of sss forks if I need them in future. As of now the stockers are holding up well with whatever Rick coated them with.The sss forks would be sweet but over kill for my riding now.Like you having real offroad bikes keep me from pounding the shit out of this pig.
    Camel ADV and Amphib like this.
  16. Greg the pole
    Mar 1, 2011
    2,225
    Calgary, AB
    correct. @Motociclo mentioned the lack of thickness.
    Mine still gets a workout, but not the really punishing kind.
    Will ride the piss out of the Beta next few nights.
    Junglejeff1 likes this.
  17. Quercus petraea
    Quercus petraea Been here awhile
    Jan 11, 2019
    180
    Spain
    Just a question.
    Are we sure Öhlins fork lugs are just "plug and play" to a Kayaba SSS fork legs? I mean: threading is the same?
    And... would Öhlins offer lust the lugs???
  18. Motociclo
    May 18, 2017
    1,129
    Even if the Ohlins lugs fit SSS tubes, from memory Ohlins are kind enough to use left-hand thread to hold in damper assembly to lug. Won't be able to screw in KYB inards to lugs.
    May or not be the case with Ohlins AT forks, but other Ohlins forks are like this.
    Here are part numbers for Ohlins lugs,
    21935-01 left.
    21935-02 right.
  19. Junglejeff1
    Oct 20, 2016
    4,708
    Upper Michigan
    I never thought of that option.
  20. Junglejeff1
    Oct 20, 2016
    4,708
    Upper Michigan
    Wow that would be cool.I am guessing RT could have new chrome tubes made to fit lugs if needed.This really gets me thinking.Have your cake and eat it to.Guessing Rick could make this work also and friendly to work with.
