    Dismiss Notice
How do you check if the alternator is functioning properly.
Discussion in 'Parallel Universe' started by EnderTheX, May 8, 2011.
  1. Dirt wolf
    Dirt wolf I'm your huckleberry
    Feb 27, 2013
    589
    Prescott Arizona
    So... battery showed 13.1v no load and 8v under load test. New battery and I'm good to go! :super
  2. GETTHUMPER2
    GETTHUMPER2 Been here awhile
    Feb 1, 2013
    559
    SOUTHERN CALIFORNIA
    CONGRAT'S,>>>>>>>>WISHING YOU MILES OF SMILES
  3. =o&o>
    =o&o> I like to ==o&o>
    Mar 22, 2008
    164
    Rocky Mtns.
    Looks like the replacement stator fried yesterday. Had to jump-start at the last fuel stop, and rode 170 miles home in the dark on a moonless night with the headlight unplugged (shadowed various vehicles relying on their headlights).
    Stator output (plugged in) is 10.0, 6.9, and 7.3 volts, 73,939 miles on the bike now, so 45,272 miles on the second stator.
    Already have a Ricks Motorsports Electrics replacement stator on the shelf. Probably need to order a CE-605-SB regulator (and rotors, fork seals, chain & sprockets, etc.).
  4. Mauser556
    Mauser556 Been here awhile
    Aug 2, 2016
    217
    Watford City, ND
    Just checking mine. At idle recently with my high beam and Cree lights on my voltage is reading 13.4 to 13.6 volts. With hand grip warmers on and 4 ways it drops to 13.0 to 13.2. But above 1500rpms, it's charging at 14.4. With high beam just on it goes to 14 volts at times.
    The image shows with everything on at idle. 20180111_170754.jpg 20180111_170748.jpg
  5. Mariachi F800 GS
    Mariachi F800 GS n00b
    Oct 10, 2018
    4
    Cali, Colombia
    So what are the recomendations for the stator and R/R combo to replace them on a 2011 F800 GS? Has fried 2 rebuilt stators in 10,000 miles.
    Stator: electrosport ESG 831 vs. Ricks 21-023?
    Regulator/Rectifier: compu-fire 55402 vs. CE-605?
  6. JRWooden
    JRWooden Homeless motorcycle vagabond ... and ... loving it
    Jul 5, 2008
    6,423
    The great state of confusion
    For folks with issues, there is a nice troubleshooting flowchart on this page:
    https://www.electrosport.com/pages/technical-resources
    (Click the link "Fault Finding Guide")
    Mariachi:
    My vote would be fore the ESG 831 and the CE-605 - I've talked to Kyle Wood at ElectroSport, and Jack Flemming at Roadster
    They both impress me as stand-up guys.
    I've had that setup on my bike for 40K tough miles and no issues so far.
    Here's the notes on my upgrade: http://www.advrider.com/forums/showthread.php?t=890729
  7. Mariachi F800 GS
    Oct 10, 2018
    4
    Cali, Colombia
    JRWooden:
    Thanks for the recommendation and the info, I just sent Jack an email and will try to locate the CE 605 and the ESG 831, I hope not to run into any snags since I live in Colombia South America I need to get it shipped over seas.
    JRWooden likes this.
  8. 320driver
    320driver n00b
    Feb 21, 2013
    3
    Do you have a picture of the final install please? I am about to embark on the very same project.
  9. JRWooden
    Jul 5, 2008
    6,423
    I used the CB 605 which is also bigger than stock..............
    I made an adapter plate from (IIRC) 3/16" aluminum as shown here and it worked out well.
    Thick enough to countersink the two machine screws from the stock R/R to hold the adapter plate on,
    and also thick enough to get sufficient threads to screw the new R/R to the adapter plate.
  10. tofire409
    tofire409 Geared up and ready.
    Sep 6, 2009
    900
    Toronto, CDN
    I'm using the CB605 since June 2016, 30,000 kms still getting 14.1/14.2v and the original 7 year old battery (that is getting replaced this winter). I used the retaining nut clips from the OEM system.
  11. dpike
    dpike BeeKeeper Supporter
    Nov 21, 2015
    1,908
    New Jersey
    just finished replacing my rectifier with the mosfet fh020aa from roadstercycle. made a bracket pretty much like tofire's. installation was straight forward clipping the connectors off of the OE rectifier and soldered the two positive and two ground wires together before crimping them with waterproof butt splice.
    shuswap1 likes this.
  12. Indy Unlimited
    Indy Unlimited Long timer
    Jan 21, 2007
    1,959
    Parker, CO
    I got approx 30,000 miles on the Electrosport ESG 831 unit and it was starting to drop voltage when running my heated grips so replaced it. On my second unit now with a few thousand miles. Quality appears very good for aftermarket stator.
    Loutre likes this.
  13. spencermarkd
    spencermarkd Been here awhile
    May 10, 2017
    138
    Pullman, WA
    Replacing my stator today and had a quick question.. how much oil is behind that engine cover? I'm guessing it's just a couple tablespoons or residual? Is this a keep it on the side stand job? Or a lean against a wall job? Or a lay'er'down job?
    Thanks y'all
  14. tresfechas
    tresfechas n00b
    Jun 17, 2013
    4
    Hi,
    Just on side stand, and no oil leaking.
    Vsss
  15. spencermarkd
    May 10, 2017
    138
    Pullman, WA
    Funny timing, got the email alert for this as I was tightening the last bolt back up. Did it on the sidestand, I think I had one drop of oil come out. Super easy job if your crash bar lower bolts aren't bent and a little rusty, about an hour and a half total moving real slow.
  16. tresfechas
    tresfechas n00b
    Jun 17, 2013
    4
    Congrats!!!!
    Funny is that happened the same to me with the Motech crashbar bolts ( i learnt is not necessary Bolt fixer - loctite type, LOL)
    Hope you enjoy lots of miles with no more issues!
    Best regards from Spain
    Vsss
  17. Jonno.T
    Jonno.T n00b
    Sep 12, 2010
    8
    Hi all,
    I had a battery fail after 2.5 years on my 2009 F800Gs (46K km on the odo)
    I replaced the battery, and put a bluetooth monitor on..
    Once started, the battery's voltage will hover around just 12.15 - 12.4 volts for minutes on end at idle. When riding, it will sometimes go to 13.8v, but never rises to a healthy 14v-plus
    THe battery just seems to slowly drain over weeks of 10 minute trips twice/week.
    I tried testing the stator, putting the probes of a basic multimeter in as per page 1 of this thread.
    I used the V~ 200 setting (I don't know much about auto electrics!)
    Readings were: 1&2 =15.4 2&3 =15.4 1&3 = Nothing! Ziltch.
    Can I assume this is a burned stator and proceed with replacing with the electrosport? Looks pretty easy to DIY
    (The bike also doesnt maintain consistent revs very well, ie - RPM varies when revving, despite holding the throttle dead-steady)
    Cheers legends,
    Jon.
  18. JRWooden
    Jul 5, 2008
    6,423
    1-2 2-3 and 3-1 should all give readings close to each other in value.
    15V - 20V at idle
    and something like 70V (AC volts) at 4K - 5K rpm.
    So if one of them is dead ... yeah new stator time ...
    I like the electrosport.
    1. not hard to swap but remember the cover will be hard to remove due to the magnets,
    2. there is a VERY sharp ridge in the "cup" of the flywheel don't cut yourself
    3. you may need an impact driver to loosen the two screws that hold the stator wiring harness retaining clip to the inside of the side cover
    lexaria likes this.
  19. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,070
    East Med, Greece
    You will also need to consider replacing your R/R with a series one. The OEM shunt type R/Rs put a lot of stress on the generators, getting them to burn overtime. Shindengen SH775 and SH845 the most known candidates.
    Cheers
    lexaria, JRWooden and dpike like this.
  20. Jonno.T
    Jonno.T n00b
    Sep 12, 2010
    8
    thanks for your help and advice,
    I have the new stator bolted back in and about to attach the right hand case back onto the engine (excited)
    Can a kind soul please tell me the tightening order and torque settings for this? (F800GS 2009)
    Cheers again :)
    Jon.
