How do YOU handle tailgaters?
Discussion in 'The Perfect Line and Other Riding Myths' started by mylastbike, May 18, 2018.
  1. mylastbike
    mylastbike Been here awhile
    Feb 28, 2014
    765
    Central Alabama
    I have about 2 miles of two lane road (one lane in either direction) on my commute with a 40mph speed limit. The typical speed of vehicles on this road is about 55-60mph (dead straight, open country road). I got a warning from police once so now I always do 40mph (and it's been crawling with police ever since). Every day now in both directions I get tailgated, even when the majority of the route allows for passing. I'm very much a Type B personality, but one of the few things that infuriates me is a tailgater especially when they won't take the option to pass.
    Two lane road and you are being tailgated. How do you typically handle the situation?
  2. ydarg
    ydarg Miscreant
    Nov 11, 2015
    1,619
    Above the Equator
    Let off the throttle to slow them down then open it up. They may get the point or may get pissed off.
    Or if it really bothers you, pull over and let the dorkwad pass.
    In before someone says brakecheck.
  3. mylastbike
    Feb 28, 2014
    765
    Central Alabama
    I actually tried your first suggestion this morning but I guess the dumbass didn’t get the clue. I never brake check a cage out of self preservation but I will roll off the throttle or look back at them with my hand up in a “what gives?” gesture.
    GunNut37086, ydarg and Richarde1605 like this.
  4. metropolis2k
    metropolis2k Been here awhile
    Oct 17, 2008
    450
    London, England
    I'd never brake check because you're not going to come out of that situation well. I usually make a motion with my hand pushing backwards towards them and drivers get the hint. I've never had issues doing that. If I'm particularly concerned I get out of the way (in any direction) as quickly as I can rather than hang around to see what might happen.
  5. DR Donk
    DR Donk Been here awhile
    Jul 30, 2009
    718
    Western Michigan
    I did the pushing backwards hand motion to a tailgater and it worked! I was amazed. :clap The worst thing to do is to flip them off. That's like waving a red cape at a bull!
  6. CRP6001
    CRP6001 Been here awhile
    Apr 2, 2011
    183
    Countryside near Hanover, Indiana
    Stand up on the pegs and look back at them.
  7. Hi-De-Ho
    Hi-De-Ho Mad Scientist Super Supporter
    Feb 6, 2016
    1,884
    Omnipresent
    Install Hyperlites on the back of your bike. Then install them so that they are only ON when you "feather" the brakes, and not on halfway as running lights.
    This way, when you do "touch" either brake lever, the Hyperlites will "flash" On...with a repeating 10 flash.....and really get the drivers attention.
    If done right, you can feather the front brake lever, just enough to actuate the Hyperlites, and causing the Hyperlites to FLASH, without really engaging the front brakes.
    You are not "brake-checking" the driver behind you, but showing them a repeating 10 flash bright LEDs, that...again..if NOT hooked up as halfway on running lights, and only hooked up as brake lights, will be an entire new light that the driver behind you sees, that was not on before...as a running light.
    I use these Hyperlites when sitting at a stop sigh, or red light, and a car approaches me from behind....I will let up off my front brake...hit it again, and it flashes the Hyperlites to get the drivers attention...to say...STOP.
    http://www.hyperlites.com/
    nk14zp, GiddyThump, psd96 and 4 others like this.
  8. Suncoaster
    Suncoaster Been here awhile
    Jul 7, 2015
    798
    Where the girls are green and the grass is pretty.
    As a last resort -
    Pull out into the incoming lane (when clear) as if to overtake, then hit the brakes hard.
    He'll go right by you.
    #8
    Snowbird, SnickterP and neanderthal like this.
  9. Schmokel
    Schmokel Fixing what is not borken.
    Jun 29, 2015
    14,322
    Up. And to the right.
    Grip it and rip it.
    #9
    Roam, CSI, bigphish and 8 others like this.
  10. CaptCapsize
    CaptCapsize Long timer
    Jan 7, 2012
    1,083
    Corrales, New Mexico
    A trick that has worked for me, is to make the bike wobble, so it looks like you are about to lose control. The tailgater backs off, so they won't run over the out of control idiot on the bike. If they think you are going to crash they will give room so it won't involve them.
    #10
  11. 51%
    51% ReadyToRide
    Nov 17, 2011
    469
    Somewhere in North America. Probably.
    In my experience usually turning my head and shoulders to look them full in the face does it. For those too oblivious or angry I'd pull over and let them go.
    Maybe you can enlist one of the ever present cops if it's happening in his view. Can't hurt to pull over and ask them to help.
    #11
  12. Eatmore Mudd
    Eatmore Mudd Mischief on wheels.
    May 28, 2012
    2,851
    Wet side of WA.
    Riding like I'm drunk has been working for me.
    #12
  13. flei
    flei cycletherapist
    Apr 1, 2013
    8,621
    Western Mass.
    Fucking tailgaters! I hate them. I say give 'em the ole brake check. What could possibly go wrong?
    #13
    mysticbus, CSI, JohnCW and 1 other person like this.
  14. EastRoad
    EastRoad Road Viking
    May 10, 2014
    1,969
    Switzerland
    there's a few things in my arsenal...
    most of the time if it's just a tad too close to be comfortable I rapidly tap the rear brake a few times - JUST TAP but I DO NOT BRAKE... I've fine tuned the lever to first activate the brake light before the brake actually engages... so that just flashes my tail-light
    some get the hint, some don't.
    if I CAN I let them pass...
    If I can't:
    if that doesn't help I usually slightly look back and make a back-off-sign with my hand (flat palm downwards, waving up/down a bit)...
    in 90% of the time they get that.
    I sometimes - say in dense traffic - engage my emergency flashers... ... for some reason that seems to help.
    if that doesn't help I usually get off the throttle and repeat the hand motion.
    in the Very Very rarest case this doesn't work... and depending on the situation and the danger-factor involved and the inability to stop / move aside to let them pass I might accelerate beyond to the point where I have the desired safety distance again - IF possible. if the traffic is too dense than I'm just trying to be extra cautious always keeping an eye on the rear view mirror and search for the first option to let the idiot pass, usually followed by flipping the bird, simply because.
    as an extrema ratio sort of last resort (say I truly feel my life being threatened...)
    I SLOWLY STOP... come to a complete stop... and get off the bike and knock on the cager's window and calmly and kindly explain the situation.
    had to do this ONCE... and it worked miracles... maybe because I'm such a charming chap .
    #14
  15. BetterLateThanNever
    BetterLateThanNever Long timer
    Dec 31, 2014
    2,184
    Ontario, Canada
    ... and the first thing the driver does is check for damage to his car. What the hell has become of us. :fpalm
    #15
  16. filmfan
    filmfan Long timer
    Sep 13, 2011
    2,673
    Live Free or Die
    My usual first step for situations like you describe where there is an open passing lane is to slow until they can't bear it anymore and they pass me. Sometimes that's 2 mph and 1 millisecond, occasionally a lot more.
    I've also used all of the tactics described already. Which works best depends on the specific situation, and the "driving style" of wherever you are. For example, in places where drivers are typically impatient, around here, Boston comes to mind, slowing a tad works almost instantly.
    #16
    KneeDrachen and SnickterP like this.
  17. EastRoad
    May 10, 2014
    1,969
    Switzerland
    And after that probably walks over to the half-dead rider and beats the remaining daylight out of him.
    Just not on camera.
    aye, that vid was pretty sick.
    but again, that's why you don't pull a stop...
    #17
    joef likes this.
  18. jwhuls
    jwhuls Been here awhile
    Mar 30, 2012
    356
    Loogootee, Indiana
    My favorite answer to this came from a friend many years ago. he would slam his center stand to the road. sparking like hell. they would always back off.
    #18
    03WrxRob, Moto Jimmy, dgeezer and 7 others like this.
  19. GunNut37086
    GunNut37086 Been here awhile
    Aug 7, 2016
    223
    La Vergne, TN
    two words....ninja caltrops
    #19
  20. Turtletownman
    Turtletownman Been here awhile
    Apr 27, 2014
    517
    Four lane divided highway running at least five over-tailgater will not pass. Two lane flat straight no double yellow they will not pass. Do those econo box cages not have enough horsepower to run faster without drafting a motorcycle. They even do it with my 2500 four wheel drive truck.
    THEY ARE A$$HOLES that's why!
    #20
    Snowbird likes this.
