How does rim damage happen?
Discussion in 'The Perfect Line and Other Riding Myths' started by SteadyStare, Oct 30, 2016.
  1. SteadyStare
    SteadyStare Adventurer wannabe
    Mar 26, 2015
    563
    Ettalong, NSW
    Ok, so I've bent my fair share of rims but I'm curious as to what is actually happening. Usually when you run lower pressure, especially on a heavy ADV bike, bent rims seem to come out of nowhere. So what's the actual cause?
    1. Is it the actual tire sidewall deforming and being forced outward, bending the rim and compromising its strength?
    Or
    2. Is it that there is so much force that the tire essentially goes flat and the rim contacts the ground through the tire?
    I've heard arguments for both, but I'm curious if any has any actual proof like a still picture or slow motion video of a rim bending. The outcome is the same either way, just hoping to settle a late night bar argument.
  2. dddd
    dddd Long timer
    Jan 15, 2012
    1,391
    Montreal, Canada
    can't be #1. how would we put on new tires over the rim...
  3. SteadyStare
    Mar 26, 2015
    563
    Ettalong, NSW
    So you are saying with enough tire pressure you could prevent all rim damage (not including side hits our other odd angles)?
    Not saying you are wrong, I'm generally interested. Think about squishing a water balloon on the top and bottom, which causes the sides to bulge. Could that not be happening with a tire? Could the force of the impact be keeping the tire bead in place while sides are forced out wide enough to bend the rim?
  4. windblown101
    windblown101 Long timer Supporter
    May 17, 2010
    6,569
    Star Tannery, VA
    No, the force exerted by the air inside of the tire is distributed equally all the way around the tires circumstance so if it was just air pressure causing the bend it would not be localized. More air pressure does protect rims.
    In my area the rocks are largely to blame for tire and rim damage, landing jumps into rocks exacerbates the problem. Here's a pic of tire and rim damage from rocks on my 1190R, notice the rim isn't bent, that's because I tend to run pretty high pressure on big heavy bikes. It's also why I run a front tube, tire damage around here is rarely pluggable. Heres my front tire at the moment. If it didnt have a tube in it there is no way I'd continue to run it.
  5. shovelstrokeed
    shovelstrokeed Long timer
    Jun 20, 2003
    5,708
    6South Florida
    It is actual contact between the rim and the obstruction. Yes, the tire deforms to that extent. It can even happen on a square edge where the tire deforms on both sides. The distortion of the tire is absorbed by a momentary increase in air pressure throughout the tire which helps to keep the bead seated. Run enough air pressure in the tire and rim damage will be minimized but not fully eliminated. All it takes is the right angle of attack and a sharp enough edge and the obstacle will penetrate to the rim.
    The relative profile of a dirt tire does little to help in this situation as they typically run from 80 to 100% section to width and thus have a tall profile which is more conducive to collapse under impact.
  6. cyclopathic
    cyclopathic Long timer
    Dec 23, 2007
    8,136
    Wrong analogy gas (air) compressible and liquid (water) is not. Even with liquid the pressure applied to one point would be equally applied to all.
    The main difference that in liquid you would have a high pressure high speed shockwave and gas lower pressure lower speed wave, and tire filled with air can reduce volume and one filled with liquid stays constant.
    Regardless the damage occurs from tire collapsing and rock hitting rim. On tubed tires you also getting pinch flat.
  7. aldend123
    aldend123 Long timer
    Sep 1, 2011
    5,082
    Bristol County MA
    It's number 2. Take a bicycle, lower the air pressure, and slowly press the tire on to the square edge of a curb. That type of action is the easiest way to do it, and rocks will do similar. Or pressing the wheel hard in to a rut/pot hole. On a dirtbike, easiest way to lose a tube is a pinch flat (also common on bicycles). The tire flattens enough to contact the rim, then the rim tears the tube.
    I know this is a bicycle, but same concept. What's happening could also bend the rim on a rim with a larger lip, like those on motorcycles.
    Idle likes this.
  8. High Country Herb
    High Country Herb Adventure Connoiseur
    Apr 5, 2011
    28,994
    Western Sierras
    I agree. It is number 2. In the engineering world, they call that a "point load". Pounds per square inch has to get pretty high to damage a rim, and reducing the area where a load is applied is an easy way to do it.
    #8
  9. Maggot12
    Maggot12 U'mmmm yeaah!!
    Feb 21, 2010
    19,934
    Canada's ocean playground
    2. Bent a car rim on a pothole..
    #9
  10. Andyvh1959
    Andyvh1959 Cheesehead Klompen Supporter
    Feb 16, 2012
    4,179
    Da frozen tundra eh? 1.5 mile west of Lambeau
    My 94 BMW R1100RS is known to have "soft" rims. But in 188,000 miles of riding typical non smooth Wisconsin roads I have never experienced a bent rim on the bike. However, I consistently run at least 38psi in the front tire and most often I have it at 40 psi. So I'd say low tire pressure is a contributor.
    #10
  11. tlub
    tlub Long timer Supporter
    Oct 23, 2012
    2,998
    Madison, WI
    If you bend a rim, be aware that you just used the tire sidewall to deform fairly strong metal, in a concentrated area. There probably is internal damage to the sidewall, and you should replace that tire, especially if you are going to run at any kind of speed with it, which will stress the sidewall further.
    #11
    GETTHUMPER2 likes this.
  12. KeithC
    KeithC Been here awhile
    May 22, 2014
    594
    CT/RI Bordertown
    :y0!....Not enough lubrication?:hide
    #12
  13. Telemarktumalo
    Telemarktumalo Go Red Sox!
    Dec 11, 2012
    603
    Bend, Oregon
    All things being equal, a higher pressure will result in less rim damage than a lower pressure when striking a sharp object. So, if you want to run low pressures for a better ride, then a larger volume tire will reduce the chances of a rim strike. As mentioned earlier, bicycle wheel makers are exploring different tire volumes and pressures that can be run. Some of the big volume fatties are running 5-6 psi with a good ride, traction and big hit forgiveness.
    #13
  14. eatpasta
    eatpasta Lawnmower Target
    Jul 5, 2006
    16,208
    Santa Barbara, Ca
    I think people under estimate how many G's that tires/wheels/forks experience during normal riding. I remember reading about it somewhere - can't recall the exact figure but I remember it being significant
    #14
