how easy to steal bmw luggage?
Discussion in 'Parallel Universe' started by slawthecyclist, Jul 30, 2020.
  1. slawthecyclist
    slawthecyclist Adventurer
    Mar 11, 2015
    14
    colchester, essex
    afternoon all, just came across a FB post regarding the theft of luggage (with bmw locks) with a master key, anyone come across this before?
    so concerned at the idea of the worlds most exspensive tin boxes being stolen, i thought i'd ad another layer of security, padlocks still to be purchased, (or nut and bolt)
  2. JRWooden
    JRWooden Homeless motorcycle vagabond ... and ... loving it
    Jul 5, 2008
    6,375
    The great state of confusion
    I have the varios for which I'm pretty sure there is no master key as they are keyed to the igniton.
    I have been told that the number of unique keys for the tin-boxes is very limited(five or less) so a thief could potentially make a master, or carry one each of the handful of key codes and wander off with your boxes...
  3. nonchuck
    nonchuck Adventurer
    Jun 1, 2018
    38
    US
    So theres a master key to the ignition too? I've rekeyed mine to match.
  4. FredRydr
    FredRydr Danger: Keep Back 300 Ft.
    Aug 16, 2005
    4,168
    Carlisle Pennsylvania USA
    A big screwdriver and a vise grip will turn the locks open.
    JRWooden likes this.
  5. slawthecyclist
    Mar 11, 2015
    14
    colchester, essex
    i was under the impression that the barrels for varios and aluminium were the same? plus keys being matched to ignition barrels surely means that their cannot only be 5 masters
  6. Loutre
    Loutre Cosmopolitan Adv Super Moderator
    Nov 28, 2010
    13,629
    :o)
    I think a thief is more interested in the inside, than the boxes themselves. they are bulky and not easy to run off with.
  7. JRWooden
    Jul 5, 2008
    6,375
    I could be wrong here... and got the BMW branded tin-boxes mixed up with another brand.
    I do recall going to a BMW MOA rally a few years back where one of the gags was to switch people's gear into other BMWs guys panniers,
    because they were a diff. key blank (not like the ignition) and while there were many possible key-cuts only a very few were in use.
    So not master-keys per say, just that only a few "key cuts" were in use....
  8. FredRydr
    Aug 16, 2005
    4,168
    Jim, That happened when people did their own lock cylinder pin swapping to avoid buying new and expensive BMW cylinders matched to key number, after buying used cases. Pins would be filed down, or the wrong length pins used anyway until the bike key would work. As a result, far more keys would work in the jury-rigged lock. I doubt it was ever an issue of a "master key."
    Yes, I'm guilty.
    #8
  9. JRWooden
    Jul 5, 2008
    6,375
    I agree ... not aware of any "master key" ... I should have avoided that word :photog
    #9
  10. Rella
    Rella Brakes for coffee
    Nov 17, 2019
    10
    Western SD
    I also have the vario boxes and I don’t think the lock actually engages the case (lid and box) it only secures the handle in the closed position, blocking access to the yellow release lever to open the lid (and red release to dismount the box). There appears to be a small yellow plastic plate that slides into a slot on the closed handle that prevents it from opening when locked. So, again, a large screwdriver and leverage to pop the handle loose would allow the case to be opened without a key.
    #10
  11. JRWooden
    Jul 5, 2008
    6,375
    Yes ... I've had mine apart and at least the Varios I have do work like that ...
    The lock just locks the handle in place in the down position.
    #11
