How have you improved your HF tire changing stand?
Discussion in 'The Garage' started by scottdc, Jun 30, 2019.
  1. scottdc
    scottdc Been here awhile
    Jul 21, 2006
    543
    Portland, OR
    Finally decided to get a real tire changing stand, the portable dirtbike one I've been using is way too wobbly and generally sucks for street tires. I held my nose and bought a Harbor Freight rig as I couldn't quite justify the No-Mar/Cycle Hill setup this year. I already own a MojoLever and am planning on adding Mojo Blocks but what other ways can the HF changer be improved? Should bother with upgrading the hardware to see if I can make it more sturdy?
    My wife and I are both daily riders, year-round, so anything to improve the tire changing process would be appreciated. We wear out a couple pairs of tires each every year and one of us usually ends up with a puncture at some point.
  2. AZgman
    AZgman Addicted to curves
    Jan 1, 2014
    558
    Gilbert AZ
    Key thing is to get it mounted securely to the floor. Once I did that, things got much easier. +++ on Mojo blocks and the No-mar tools (all of them).
    Arbolmano and scottdc like this.
  3. scottdc
    Jul 21, 2006
    543
    Portland, OR
    I've got some Redhead 1/2" inserts to bolt it down on a concrete patio with, should be almost overkill :)
  4. racer1735
    racer1735 Long timer
    Dec 30, 2005
    1,238
    Amarillo/Canyon, TX
    As mentioned, mount it to something sturdy. I chose a wooden pallet. But don’t use just any pallet as most use cheap, flimsy wood. I found a pallet at a rock/gravel outlet. Both the tire changer and myself can stand on it with no issues.
    Secondly, get a set of mojo blocks to replace the rim clamps. These will save your rims. A mojo bar makes demounting a tire a breeze. Others find it helps with mounting the tire but I’ve found frustration and use three irons.
    scottdc likes this.
  5. JimVonBaden
    Feb 11, 2005
    87,846
    Alexandria, VA
    Adding nylon blocks, nylon to the bead breaker, bolting it solid, and a way to keep the wheel from turning.
    I also have used a NoMar bar for years.
    That said, today I bought a Cycle Hill, with a bunch of accessories, for $150.
    After 300 sets of tires, time to see if something other than the HF unit works better.
    scottdc likes this.
  6. roger123
    roger123 Long timer Supporter
    Jun 23, 2007
    2,359
    VA Beach, VA
    Nothing, just make sure you bolt it down, I bolt mine into concrete anchors. MoJo stuff works well.
    scottdc and JimVonBaden like this.
  7. NurseBill
    NurseBill Been here awhile
    Aug 20, 2017
    725
    Central PA
    I bought mine last year and did some work to it. I used to do machining work before being a nurse. My fabrication tools at home are a drill, drill press, bench grinder, sawsall, 4 inch angle grinder, hammers, vise... yeah pretty sad considering what I had access to. I miss having access to a mill and lathe.
    So far I have only done 1 set of tires with it I modified the clamps using an old nylon cutting board. I made blocks like the mojo blocks. I cut the nylon in strips, one longer and ground a groove in it. Pushed them into the holder and ran a bolt through it.
    I did copy this guys bar...
    It worked good taking tires off, tough to use putting them on.
    I did some more mods. I made the upper arm be able to be flipped up out of the way.
    I added threaded rod that fit into the threaded hole since nothing I own has that big of a bearing. I might make others smaller as soon as I have access to a welder. I added washers to help hold the wheel down and a nut. I use a strap to keep it from turning, but I like the idea of the padded bar idea.
    I made a new bar for a changer. I used a heavy piece of black iron pipe. I cut out a mount for the duck head using a piece of plate steel that was heavier that the original one I made.
    Figure I cut the head mount with a damn sawsall and ground it in with a bench grinder. The mount is pounded into the flattened iron pipe. I don't have a welder so I used a self threading bolt into a hole I drilled, cut the bolt off so it's pinned in place. Coated the whole thing with truck bed coating and added some rubber tube as a handle.
    I slipped a piece of old inner tube over the bead breaker base. I have several small 2x4's handy to support a wheel.
    Next time I have a wheel off, mine are all 17" on my street bikes, I'm going to break the bead down, put the mount/demount head into the rim and mark where the mount demount bar and center bar meet. On either side of the center bar I'll drill a hole for a u-bolt to go through so the mount demount head can't twist and (hopefully) stays against the rim.
    Now I just need some tires.
  8. bearcat1
    bearcat1 Been here awhile
    Aug 27, 2006
    337
    Olympia, WA
    Gentlemen, thanks for posting to this thread. I just purchased the HF motorcycle tire changer and wheel balancer. Great info that is helping me out. It is going to take a little time to sort it all out and make the mods.
    Generally I change 1 or 2 street tires per year and would just order my tires through the dealer, drop the wheels off and have them do it. This last go around I was told by the service dept that they no longer will do tire changes on HD wheels because a previous customer complained about a scratched rim. I figured that's fine, I'll just invest a little money, time & effort. The setup should pay for itself after about 5 tire changes. The bonus is my riding friends can use it also.
    #8
    NurseBill likes this.
