    Dismiss Notice
How I copied everyone else's Sportster ADV build
Discussion in 'Some Assembly Required' started by CopyCat, Aug 31, 2019.
  1. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    14,383
    Orange County, CA
    wow! The low sets I received didn’t look like that
    #81
  2. madrider5150
    madrider5150 Riding somewhere
    Oct 15, 2013
    1,329
    PNW
    Yeah I havent gotten to ride mine hard enough to notice any frame flex. As far as the lowsets, I have played with the shifter position before and found some positions very difficult to shift, had to do some trial and error.
    Maybe I missed it, what kickstand are you running?
    #82
    villageidiot likes this.
  3. madrider5150
    Oct 15, 2013
    1,329
    PNW
    Right? I was thinking I want those- look a bit more like carducci type
    #83
  4. CopyCat
    CopyCat I am NOT like the others Supporter
    May 16, 2015
    786
    behind the cheddar curtain
    I have an extended KLR stand
    #84
    madrider5150 likes this.
  5. CopyCat
    May 16, 2015
    786
    No? What do they look like?
    #85
  6. villageidiot
    Apr 29, 2010
    14,383
    Orange County, CA
    They weren’t as beefy, they were quite spindly lookin really
    I don’t have any full pics, just close ups of the shit workmanship that I received.
    #86
  7. CopyCat
    May 16, 2015
    786
    Yeah, i know that was a pile of shit workmanship. I still can't figure that whole thing out
    #87
  8. madrider5150
    Oct 15, 2013
    1,329
    PNW
    Little comparison- see the style you got goes the upper bolt like the carducci, more material etc. Looks like a much better set up
    #88
    davyjones, buzzword and villageidiot like this.
  9. CopyCat
    May 16, 2015
    786
    Oh my. There is a big difference, isn't there? It really shows up the geometry differences also. JTH has all his levers in a nice straight line with 90 degree angles.
    #89
    davyjones and madrider5150 like this.
  10. madrider5150
    Oct 15, 2013
    1,329
    PNW
    I think that bottom pivot might be braced too but cant tell for sure. It would be a really good set up combined with the folding tip. BTW how did you do the folding tip? Custom hole size from Shane? The stock set has different thread size shift peg than stock so cant just bolt one in from alloy art.
    #90
  11. CopyCat
    May 16, 2015
    786
    I used a Woodcraft on Shanes recommendation. It has a little pin in it to keep it from rotating, I just ground a small slot in the arm to locate the pin. It allowed me to rotate it forward a bit for my size 15's
    https://www.solomotoparts.com/Woodc...THVYKW2KGSkS3bZGhhYRmyMckhtr8aEhoCYQcQAvD_BwE
    #91
  12. molochnik
    molochnik Anhedonic Enthusiast
    Aug 28, 2018
    512
    HiDez SoCal
    You appear to have some fabricating skills and I realize this may not be the proper rig for your intentions but you could go the way of the stock "tuber" Buell rig. I also included a shot of the mock-up on my XS650. No shifting issues with either one.
    Sportys seem to require a pretty long pull regardless.
    #92
    CopyCat likes this.
  13. CopyCat
    May 16, 2015
    786
    That is not unlike @johnwesley original design.
    #93
    davyjones, molochnik and johnwesley like this.
  14. johnwesley
    johnwesley wanta be
    May 11, 2006
    3,362
    mena, Ar
    Believe it or not that is a Chainsickle setup on my bike. Before he got all fancy. The shift lever was soft and easily bent is probably why he went with the design you have though it’s not as functional as the one I had. Using a harder aluminum alloy would have fixed the bending issue with the risk of being more brittle. Going to a steel shifter would have been easier and cheaper but then we would all complain about the weight. Even though it would still be less than half of what we took off the bike. Maybe you could get him to build a set like mine and then just have the shifter copied in a better material.
    #94
  15. yokesman
    yokesman Long timer
    Sep 12, 2008
    2,738
    SW. Idaho
    On the toe peg , if you get a brass toilet bulb screw to hold it, when dropped will give and not damage anything else, little permatex to lock it in. bought a spare just for? this is what I used on my Buell after a steep parking lot drop.
    #95
    CopyCat, JagLite and molochnik like this.
  16. molochnik
    Aug 28, 2018
    512
    HiDez SoCal
    It's a very delicate balance - designing/fabbing something like John's where it looks nice, sleek, and lightweight *or* my general approach where I hope there is some aesthetic value in a beefy look and the expectation of maintaining the item's functionality.
    Sleek, light, and survivable is where the real beauty lies.
    The Buell style monkey-motion will provide more room/material/options to find the right lever ratios for your taste. I've not had any problems with the Rube Goldberg rig on my Cyclone - on the street or on the track. Haven't had any regrets on the rigid either...but I haven't ridden either one on dirt (on purpose).
    #96
    madrider5150, CopyCat and johnwesley like this.
  17. CopyCat
    May 16, 2015
    786
    LOLOLOLOLOL!!!!!! Vibration in right peg issue resolved. It seems I tightened the chain roller too much and it wasn't rolling. Don't tighten these like axles:imaposer! Replaced with a skateboard wheel that's working great. When I get the replacement wheel Imma make up a spacer between the bearings so I can tighten it like an axle
    #97
    loganlexow, smolt, davyjones and 7 others like this.
  18. CopyCat
    May 16, 2015
    786
    I found the clutch set up after I adjusted it to have a very narrow friction range for some reason. It was "grabby" and like alight switch with almost no smooth transition. Made woods and slow speed riding a jerky exercise. I could never seem to get it adjusted out correctly. Got a new clutch pack to eliminate the spring plate as a precaution, installed a Muller power clutch and a 2 finger RSC stunt clutch lever. What a difference!!!! The friction range now is very easy to ride slowly, and the clutch is now truly a 2 finger affair, almost a 1 finger action. Not the Beta trials bike but not far off. The spring plate was pretty loose too so I'm glad I did the change.
    #98
  19. madrider5150
    Oct 15, 2013
    1,329
    PNW
    Im interested in seeing a pic of your bar control set up .. real interested in converting to 1 1/8- 7/8" bars whenever I get my bike back together lol
    Good to hear the muller works so good, I bought the knock off- forget the name years ago, never installed it
    #99
  20. CopyCat
    May 16, 2015
    786
    @madrider5150 You mean like these? Buell Blast controls and clutch perch. Just need a Buell clutch cable and the Buell throttle cables fit right on. If you mean the risers I just used Rox 7/8 to 1 1/8
