    Dismiss Notice
How I copied everyone else's Sportster ADV build
Discussion in 'Some Assembly Required' started by CopyCat, Aug 31, 2019.
  1. CopyCat
    CopyCat I am NOT like the others Supporter
    May 16, 2015
    781
    behind the cheddar curtain
    HA!!!!!! Nice catch, Loctite is a friend....use it
    AK650 and villageidiot like this.
  2. Kai Ju
    Kai Ju Long timer Supporter
    Jul 29, 2009
    4,529
    Long Beach, California
    weight reduction ? to make up for the R/R cover...
    CopyCat, JagLite, AK650 and 1 other person like this.
  3. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    14,281
    Orange County, CA
    On a solid mount sportster, blue loc-tite on everything.
    c1skout, Ginger Beard and AK650 like this.
  4. AK650
    AK650 Long timer Supporter
    Jun 26, 2013
    1,861
    Alaska
    And safety wire where you can!:D
    victor441, CopyCat and villageidiot like this.
  5. CopyCat
    May 16, 2015
    781
    Problem: Folding brake tip too short and too slippery to inspire confidence in stabbing for the brake in an awkward situation. I did what a good CopyCat would do.....copy @jdrocks idea of using a much larger brake tip. He uses a small footpeg but that's too big for me. Some mill time and used the folding mechanism from the old peg and presto!!!! 1" longer, 1" wider and vicious teeth for a sure grip. It folds very nicely so maybe it won't break the lever.
    Achtung, JagLite, AK650 and 5 others like this.
  6. Kai Ju
    Jul 29, 2009
    4,529
    That extra weight is going to negate the weight savings of leaving the skid plate bolt out.
    Nicely done, looks like it'll do the trick, but...is there a weld missing on that stand ?
    JagLite, AK650, Ginger Beard and 2 others like this.
  7. CopyCat
    May 16, 2015
    781
    You eagle eyed guys, I swear. Stop noticing stuff:dirtdogIts welded along the bottom.
    JagLite, AK650 and villageidiot like this.
  8. Kai Ju
    Jul 29, 2009
    4,529
    But that's not the load path...
  9. CopyCat
    May 16, 2015
    781
    Nonsense...Thats all voodoo and black magic.:imaposer Its all fun and games till it gives way and I hurt myself, then its fookin hilarious!
    JagLite, AK650, Kai Ju and 1 other person like this.
  10. Kai Ju
    Jul 29, 2009
    4,529
    Pictures when it does...though I hope it doesn't. Just a spot weld would make me feel better for your well being. Pretty please...
    smolt, AK650 and villageidiot like this.
  11. CopyCat
    May 16, 2015
    781
    Oh OK then. I guess I can't use the excuse anymore that I don't have the time
    JagLite, Kai Ju, AK650 and 2 others like this.
  12. CopyCat
    May 16, 2015
    781
    Problem: Where I mostly ride has lots of trees. Trees fall across my trail often enough to justify carrying a folding saw. Last year I lost two due to poor mounting systems. I contacted @Ginger Beard as he does some custom sewing. I explained my needs and he agreed to modify a Motopossum tent pole bag to fit the saw. It has a molle system on one side for straps and I can fit it discreetly between my rack and the rear fender. It has a nice roll-over closure like a waterproof bag. It arrived and i was impressed with the quality of workmanship. First rate!!!!! And I thought reasonably priced. Gonna work great!!!!
    loganlexow, smolt, Webman and 8 others like this.
  13. CopyCat
    May 16, 2015
    781
    Been at this one for awhile now. Problem: I fall down ( a lot). The carb and air cleaner stick out like a wart on the right side, and it looks like it could easily be damaged. I have always loved the Carducci sportster bar, so as opposed to my normal copy process, I asked @JimmyTheHog for permission to copy him which he graciously granted and sent me this:
    I found out that the smallest radius dies I could find for bending were 3". I bent up some bends and couldnt get the darn mount around my exhaust pipe and still have 2 bends without sticking out needlessly long and found that because I moved my air cleaner forward 2" a bar would prevent me from removing the air cleaner. I remade the lower mount to sit ON the frame rather than over the downtubes then had to use 45 degree bends to get the angle right.
  14. JagLite
    JagLite Long timer Supporter
    Jun 17, 2010
    8,782
    Anchorage Alaska
    The bars came out great! :thumb
    AK650 and CopyCat like this.
  15. madrider5150
    madrider5150 Riding somewhere
    Oct 15, 2013
    1,328
    PNW
    You fabbed them up? Very nice work!
    CopyCat likes this.
  16. Achtung
    Achtung Wicked Pisssah Adventurer Supporter
    Nov 1, 2002
    3,085
    Waltham MA
    Where did you get the donor foot peg?
    Wow, those came out great. Where did you get the tubing and what bender are you using?
  17. CopyCat
    May 16, 2015
    781
    I guess i wasnt clear on the brake thing. I had a small folding tip already and that is the spring mechanism I used. JDrocks used an unknown donor peg as a tip. I went to local bone yard and they wanted WAY too much money for mashed ugly pegs, so I had one made. The tubing and bender were donated by a friend, I do know its some sort of high zoot 7/8" tubing. (He builds racing bicycle frames)
    Ginger Beard and Achtung like this.
  18. Achtung
    Nov 1, 2002
    3,085
    Waltham MA
    They came out great.
