How I fixed the slow leak on my Tubliss
Discussion in 'The Garage' started by _CJ, Mar 18, 2019.
  1. _CJ
    _CJ Rugged Individualist
    Dec 29, 2010
    3,254
    The 719
    Ever since installing my new tires and Tubliss system, I've had a slow leak on the low pressure side of the rear tire. It held air fine for the duration of a ride, but would lose about half it's pressure every night until zeroing out. I gave it some time, hoping it would heal itself, but it didn't.
    Not wanting to repeat the entire installation process (as suggested by the Tubliss trouble shooting guide), I removed the valve core from the low pressure side, squirted about ten pumps of soapy water from a spray bottle into it, reinstalled the valve core, aired up the tire, and voilla! no more leak! Even two days later, it hasn't lost any pressure.
  2. Aviatordoc
    Aviatordoc BMW R1200 GSA LC and S1000XR rider Supporter
    Dec 25, 2008
    1,145
    Chattanooga, TN
    You should a tried Stans sealant. Great stuff.
  3. _CJ
    Dec 29, 2010
    3,254
    The 719
    My understanding is that if you want to use a sealant, it has to be used from the start instead of soapy water. Once the soapy water is used as part of the installation, you're married to it.
  4. P 0 P E Y E
    P 0 P E Y E Bald rider Supporter
    Nov 13, 2008
    1,987
    southern Connecticut U S A
    I’ve been Running Tuubless since God was in diapers. With wonderful success.
    The valve core needs to be re-tightened after the first couple of rides. Then checked occasionally for tightness.
    ChromeSux and _CJ like this.
  5. noyolk
    noyolk Certified Preowned
    Aug 27, 2012
    247
    Boring Damascus, OR.
    Just be careful, I damaged the valve core and could not remove it as the tangs broke. Call to tubliss and they do not sell the stem, only a new liner with stem. Was able to save it with a left hand drill bit removing the core without damage to the stem.
  6. ohgood
    Sep 21, 2010
    9,698
    alabama
    dirty valve stem will do that
  7. nzrian
    nzrian renegade master Supporter
    Feb 20, 2009
    1,715
    Queenstown , NZ
    My tubliss system on the rear leaked around the rim to tire interface on both sides of the rim with a motoz arena hybrid.
    Apparently the motoz bead width isn't as thick as most tires, so this is a known problem.
    I fixed it by removing the valve core on the low pressure side and squeezing in some slime tire sealant, without removing the tire.
    Fixed it up good as gold.
    _CJ likes this.
  8. _CJ
    Dec 29, 2010
    3,254
    The 719
    Interesting, mine is a Motoz tire too.
    #8
    nzrian likes this.
  9. nzrian
    Feb 20, 2009
    1,715
    Queenstown , NZ
    Try it, you get some puncture protection as well.
    I see you have it sorted anyway.
    #9
  10. nk14zp
    nk14zp Long timer
    Feb 24, 2010
    2,869
    Maine
    I like to add a burst of air to the tire after getting it up to pressure to clean the valve. Got in that habit working on semis with equal in the tires.
    #10
  11. ohgood
    Sep 21, 2010
    9,698
    alabama
    equal in the tires? for balancing?
    #11
  12. nk14zp
    nk14zp Long timer
    Feb 24, 2010
    2,869
    Maine
  13. _CJ
    Dec 29, 2010
    3,254
    The 719
    On the topic of balancing.......I was getting a cyclical vibration at 35+mph that kind of smoothed out above 55mph. The vibration would build for a couple of seconds, then tapper off and disappear for a couple of seconds, then come back. It had me puzzled because it seemed like a tire balance issue would be constant. Long story short, I removed the wheels and did a home balance job with some lead sinkers that cost me $3.00. Wrapped them in electrical tape and zip tied the ends of the tape to keep it from unraveling. Ended up with 5oz of weight on each wheel just about opposite of the low pressure rim lock thing. It's not pretty, but it works. Took it for a test ride, and it's smooth as glass.
    My theory with the cycling of the vibration is that it was because the wheels are different diameters, and when they synced up the vibration would be most intense, then when they were 180 degrees out, they would kind of cancel each other out.
    #13
    Eatmore Mudd and ohgood like this.
  14. worncog
    worncog YBNormal Supporter
    Oct 19, 2011
    997
    Florida Panhandle
    Stans is good stuff. Raced mtn bikes for a few years when tubeless was in its infancy. Used Stans rims and latex compound with great results. Not a hiccup in the last two years of using Stans in the enduro tires.
    I use Stans to lube the bead when mounting and install the bulk amount thru the valve stem. Getting ready to mount a new rear tire on the DR and will be using Stans in the tube for extra security.
    #14
  15. _CJ
    Dec 29, 2010
    3,254
    The 719
    yeah, some people swear by the sealant. Doesn't mix with soap/water though, and that's what I used when I installed the tires. Plus, it's one more thing to buy vs. mixing up dish soap and water that I already have on hand. We'll see if my opinion changes after a puncture. :lol3
    #15
  16. tomrux
    tomrux Been here awhile
    Sep 18, 2010
    817
    northside Briswegia
    Dish soap can be pretty destructive on a rim tho. The reason I wont use it as lubricant when mounting tyres. Find a quick squirt of cheaparse cooking spray works atreat and after the first wash leaves no residue.
    Cheers Tom R
    #16
  17. _CJ
    Dec 29, 2010
    3,254
    The 719
    Soap destructive to the rim? How so? It IS tubliss's recommended method of installation. Hard to believe they'd recommend something that's going to damage the rim.
    #17
  18. BikePilot
    BikePilot Long timer
    Jul 5, 2005
    11,754
    Golden CO
    IMO sealant is the way to go for tubliss. I've run Stans forever on Tubliss setups and it seals up great and also helps a lot should you get a puncture.
    #18
  19. tomrux
    Sep 18, 2010
    817
    northside Briswegia
    Washes any oil of the rim and leaves a corrosive film behind. Too much caustic in dish soap. Shouldn't use it to wash a bike generaly either. Use a mild soap if you must.
    Cheers Tom R
    #19
  20. teambft
    teambft teambft
    Feb 19, 2009
    1,279
    Brentwood, TN
    So wanted to clarify - if I used soapy water to initially install my Tubliss, I cannot now use Stans as a sealant?
    #20
