How I mounted my GPS: 800GS
Discussion in 'Parallel Universe' started by kkesp, Nov 7, 2008.
  1. kkesp
    kkesp UPSIDERIGHT
    Aug 8, 2006
    242
    Lost Wages, NV
    This is what I did. I used two pieces of aluminum angle 2" and a piece of aluminum round that I drilled and tapped. I already had the GPS holder from my 1200 GS and if you look those are 1200 GS bar risers as well. In the other pictures you can see the antenna mount ($12 I believe) from RAM. I attached it to the bottom of the GPS mount to make it a single unit, and the last picture is of the earphone jack (so I can listen to XM).
  2. Stretch67
    Stretch67 Mad Scientist Supporter
    Mar 22, 2006
    23,578
    Bent, But Not Broken
    Very sexy. Mad skillz.
  3. FT BSTRD
    FT BSTRD Welcome to The Dispersive
    Aug 6, 2005
    4,338
    TN, WHERE THE MEN ARE MEN AND THE SHEEP ARE SCARED
    Did ya have to sweet talk it first? :D
  4. tmex
    tmex Long timer
    Apr 20, 2006
    2,039
    NorCal
    That mounting location obscures the instruments. I looked at doing something similar but ended up mounting the Zumo to the left side of the bars.
  5. Halfway
    Halfway There
    Nov 8, 2008
    100
    Yorktown
    It doesnt block it much. unless your really staring at the RPM gauge it isnt a problem.
    I can see the speedometer just fine. :eek1
  6. kkesp
    kkesp UPSIDERIGHT
    Aug 8, 2006
    242
    Lost Wages, NV
    I used a touratech GPS mount adapter on one bike, and it doesn't block anything, but with the bar risers on the other bike I had to have something lower.
