How many miles are on your GS, what year
Discussion in 'GS Boxers' started by scooteraug02, Feb 27, 2005.
  1. scooteraug02
    scooteraug02 Dog Rancher
    Feb 18, 2003
    4,585
    Atlanta, GA
    I have an 03 ADV with 24,000. Bought March 2003 with 40 miles.
    Problems:
    Had the recalls done.
    My rear wheel didn't have the spacer, wore my brake pads out and added drag. Dealer added spacer under the recall.
    Std Adventure crash bar cracked at the mount under the tank, hear it is common. To be replaced under waranty.
    Lately it will occasionally stall after slowing to stop at a signal. I need to take care of that soon. I am due for a fuel filter.
    Fuel gage acted screwy a few times then worked normally.
    Occasionally the horn will honk when I cancel the blinkers.
  2. Curtis
    Curtis Life serve the risk taker
    Nov 1, 2002
    1,308
    Chandler, Arizona
    I've got 54K on a 02. I twisted my driveshaft crush drive and had to replace but that's about it. While in there I changed my clutch. Normal maint., replaced belt, brakes fluids.
    For your stalling you want to check the TPS voltage, then balance and idle. I had an intake airleak at the throttle body that made my bike run rough but that was it. Could be O2 sensor flaking also but my bike did that when I had the TPS misadjusted and way below spec on voltage.
  3. * SHAG *
    * SHAG * Unstable
    Nov 28, 2001
    5,648
    Bradford, Pa
    Not one problem with my 1150. Had the brake line grommet warranty thing done .
  4. configurationspace
    configurationspace delooper
    Jan 26, 2003
    12,028
    Kanadia
    2003 Adv. I've had all but one of the recalls done -- some 4th and 5th gear transmission thing that I just found out about. No problems with the bike so far. Yup the spacer was missing on my rear wheel, too. I think these bikes go through the rear brake pads quick -- I'm getting the same wear patterns with or without the spacer. I'm at 30,000 miles.
  5. bunkie
    bunkie Adventurer
    Dec 3, 2002
    14
    SF CA
    I have a 2002 GS Adventure; purchased in Europe...105,000 KM on it.
    Two years of non-stop traveling on it. I blew out the final drive at 98,000 just after crossing the US border (lucky me! -- I did replaced the bearing at 60,000)
    I blew up an Ohlins rear shock in Peru (2 up dirt roads) that my European seller
    Kroon Imports honored, even through it was way out of warrenty.
    Toasted the clutch in Sumatra in a mud bog...ran it until I could rebuild the in Australia. I have been reading about the final drive failures...and I am watching this much more on my bike now.
    Other than that, it has not let me down yet.
    I need to do a complete service on it and maybe True the wheels.
    -bunkie
  6. Max Kool
    Max Kool Xtankteam™
    Jan 19, 2004
    4,950
    Los Angeles
    I have a '94 1100GS with 50k on it. First gearbox, first clutch, first final drive. Runs better than new actually ever since I put in a tune-up chip. I had the rear swingarm to final drive bearings being replaced last service. It still shifts smooth
    (BMW-smooth that is, so it's a little clunky) and still tops out at 125 mph.
    The bike let me down once when the hall-sensor gave the ghost at 40k. last year. Set me back about $220,-. I can live with that.
  7. blunsford
    blunsford Adventurer Supporter
    Mar 27, 2004
    12
    Milwaukee WI
    2004 GSA bought in Jan 2004, have 22000 miles with no major problems. Crash bar cracked after a get off in the mud, but dealer replaced no questions asked (Mischler of Beaver Dam WI). Recalls done, bike just gets stronger. Thinking about 650 Dakar for the rough stuff
  8. Jim Moore
    Jim Moore "You ain't black!"
    Dec 24, 2001
    35,899
    Jax, FL
    42K miles on my '02. Had the fuel pump replaced under warranty because it was loud, besides that, nada.
    #8
  9. Rootkiller
    Rootkiller Been here awhile
    Mar 23, 2003
    436
    Monroe, Washington
    01 with 26000 miles,no problems!
    #9
  10. Colt03
    Colt03 Been here awhile
    Apr 25, 2003
    563
    ct usa
    O4 GS with 29000 miles. I had a hydraulic clutch fail, dealer replaced under warranty. I have had some abs faults that were cleared once but need to be re-evaluated. Overall happy,
    #10
  11. jonasf
    jonasf Ich mag Sauerkraut
    Sep 29, 2002
    250
    Corvallis OR
    02 with 34500 mil,no probs
    #11
  12. Lone Rider
    Lone Rider Registered User
    Jan 29, 2002
    25,130
    out and about
    '02, tagged Aug '02
    105,000 miles
    2 alternator belts went at 24k ea, current belt is at 56k
    Lost rear drive bearing and seal at 82k
    #12
  13. eap
    eap El Adventurero Solitario Supporter
    Nov 1, 2001
    3,395
    Maryland, Least Coast USA
    01 w/ 35K miles, no problems.
    #13
  14. kildala2000
    kildala2000 The GS Store.
    Aug 9, 2002
    2,203
    Northern BC Canada
    Hello Adv riders, :D
    O2 Adv with 34.000 km.
    Had the recall on the rear brake line, fuel clamps, had to have the rear swing arm tube replaced due to marking from the brake hose rubbing almost through the casting. But other than warranty issues NO PROBLEMS.
    Hope it stays that way. Warranty is up in August.
    Ride Safe,
    Rick. :thumb
    "The Skid-Plate Guy"
    #14
  15. SourKraut
    SourKraut Long timer Supporter
    Nov 20, 2004
    8,928
    Vermont
    00 w/33K miles, no problems
    #15
  16. pilot
    pilot ...
    Dec 23, 2002
    35,912
    Right here
    2003 GS Sport, 34,000 miles. Nothing major, just adjust the valves and change fluids. I put a new belt on this last fall. I change tires alot. What's up with that? I'm on my fourth set of tires already. I suppose I should by two sets when I change them again in July.
    #16
  17. Squidward
    Squidward At home in my jammies
    Feb 9, 2004
    1,842
    Central Coast, California
    8 months old and 7000 miles. The only problem has been the lack of riding time..
    #17
  18. Scalzitti
    Scalzitti Adventure Driven
    Dec 24, 2003
    442
    Lake Zurich, IL
    02 Adventure - bought in 2/04 with less than 11,000 miles. As of today I'm a stone's throw from 30,000 miles. Knock on wood - this bike is a dream - no problems.
    #18
  19. inte
    inte neophyte serendipity
    Dec 27, 2002
    2,744
    USA
    winner!
    #19
  20. Gary Stofer
    Gary Stofer Been here awhile
    Apr 30, 2002
    118
    Sacramento, Ca
    '96 GS, 212,000 miles. 1 driveshaft. 1 starter. 1 set head gaskets. 1 clutch, 1 right side throttle body
    Gary in Sacramento
    #20
