How much does oil type, grade matter?
Discussion in 'The Garage' started by Breezlife, Sep 15, 2019.
  1. Breezlife
    Breezlife Adventurer
    Jun 12, 2019
    91
    Dublin,Ireland
    I have an RE Interceptor 650, a couple of months old. Just had its first service and the official RE dealer's workshop insisted on putting semi-synthetic oil into it, whereas RE clearly stipulates fully synthetic 10w40 -- CORRECTION: 10w50. My service record makes no mention of the grade used, but I'm guessing 15w50.
    At the risk of sparking a bunfight, to what extent does this matter? Should I rush out and change to the recommended stuff?
    I'm in Ireland, so there's lots of humidity but moderate temperatures.
    REALGRAVEROBBER likes this.
  2. katbeanz
    katbeanz earthbound misfit, I Supporter
    Feb 12, 2005
    10,492
    Kansas City
  3. anotherguy
    anotherguy Long timer
    Jun 18, 2009
    15,491
    the hills
    Plain bearing crankshaft and parent metal cam journals make it a big difference. Bearing oil clearances are set for the weight of oil specified in design. Especially on cold start.
  4. ozmoses
    ozmoses .
    Jul 3, 2009
    43,890
    Blo,ME
    If your oil is more than a couple days old it's already toast. :augie
    dmftoy1 likes this.
  5. anotherguy
    Jun 18, 2009
    15,491
    the hills
  6. shovelstrokeed
    shovelstrokeed Long timer
    Jun 20, 2003
    5,708
    6South Florida
    Since your motor doesn’t read, it doesn’t matter.
    sieg, gonzomup, ohgood and 2 others like this.
  7. Motomantra
    Motomantra Registered Lurker
    Mar 6, 2008
    3,163
    Beaverton, OR
    I'm not too sure. It's not a Jap bike. :lol2
  8. shovelstrokeed
    Jun 20, 2003
    5,708
    6South Florida
    5 BMW , an assortment of British and a few Italian and Spanish plus a couple from Central Europe and about 6 from HD. Been riding since 1961. Never saw a bike that wouldn’t run on 30 wt oil.
    #8
  9. bwallca
    bwallca Been here awhile
    Aug 4, 2007
    221
    Edmonton, Alberta Canada
    The correct viscosity is more important than synthetic vs semi-synthetic.
    #9
    REALGRAVEROBBER, Kris and LuciferMutt like this.
  10. Jeff Sichoe
    Jeff Sichoe ruddy bastard
    Feb 7, 2011
    420
    Wellington
    I put the wrong oil in my bike once and the bike came alive and murdered my family.
    don't risk using the wrong oil!!!
    #10
    local1, concours, baldman1 and 8 others like this.
  11. Baroquenride
    Baroquenride Everyone dies, but not everyone truly lives.
    Apr 10, 2011
    4,532
    Clark Co, Wa
    ^ Bwahahaha :lol3
    Avatar+statement= Awesome!:imaposer
    #11
  12. nbsdave
    nbsdave Been here awhile Supporter
    Jul 26, 2012
    701
    sarasota, fl
    nothing is hurt
    #12
  13. ohgood
    Sep 21, 2010
    10,100
    alabama
    yes, put oil in it.
    #13
    Xchemie, DeepBarney and TonyKZ1 like this.
  14. H96669
    H96669 A proud pragmatist.
    Nov 20, 2009
    5,989
    Hiding off Hwy 6, B.C.
    I just looked at the RE owner's manual.10w-50 is the recommendation for a 2018 Interceptor.
    Specifically some Elf Moto4 lubricant sae10w50 synthetic?
    If so and from what I can see on the Elf website the Moto4 is a synthetic technology based lube (Semi-synthetic for the North Americans) and NOT a true 100% synthetic such as their "Race" oil.:1drink
    #14
  15. Breezlife
    Jun 12, 2019
    91
    Dublin,Ireland
    You're right. I should have said 10w50, especially as I was being all precise.
    Interesting on the definition of fully synthetic!
    #15
  16. anotherguy
    Jun 18, 2009
    15,491
    the hills
    Look here.
    #16
    Breezlife likes this.
  17. LuciferMutt
    LuciferMutt Rides slow bike slow
    Aug 19, 2008
    16,842
    New(er) Mexico
    I agree.
    Where you start splitting hairs, particularly on motorcycles with engine oil-lubed transmissions and clutches, is how the oil affects things like shift feel and clutch slippage.
    I find shift feel to be considerably better with synthetic oils, but beware of "energy conserving" oils, which can cause your wet clutch to slip. They would be fine in a bike with a dry clutch. Also, synthetic oils handle extreme temperatures a lot better than standard oils, so I prefer them for air cooled bikes. That's also why most turbo engines recommend full synthetics.
    OP, your owner's manual should advise on the correct weight.
    #17
    TonyKZ1 likes this.
  18. Bounder
    Bounder Typing...
    Mar 2, 2011
    2,140
    West Cork, Ireland
    I don't think here in Ireland the difference between 10w40 and 10w50 is that significant, the temps aren't extreme enough to make that big of a difference.
    good 10w 40 is fine.
    #18
  19. zaxrex
    zaxrex I don't know. Do you know?
    Apr 7, 2018
    471
    Frederick, MD, USA
    Spend some time over at BITOG (www.bobistheoilguy.com) -- some of those guys/gals are oil geniuses.
    As I understand it, the synthetic argument only shows benefit in film strength breakdown over time. Royal Enfield engines seem like they are understressed, so probably never going to be an issue.
    My thought -- ride the bike, short-change the OCI for this instance. If you are really concerned, send a sample to Blackstone for analysis and peace-of-mind.
    #19
    REALGRAVEROBBER and Breezlife like this.
  20. foxtrapper
    foxtrapper Long timer
    Sep 6, 2011
    4,629
    It's deep and convoluted rabbit hole. I would not fear using a semi-synthetic or even regular oil. But, if it is a wildly hot engine or does have a turbocharger, I'd reconsider. Conventional oils break down at a lower temperature compared to synthetic oils, as very broad sweeping statement.
    That said, you've got a warranty to consider, since you say the bike is only a couple of months old.
    #20
