How much does oil type, grade matter?
Discussion in 'The Garage' started by Breezlife, Sep 15, 2019.
  1. AviatorTroy
    AviatorTroy Long timer
    Oct 15, 2007
    2,395
    Castle Rock, CO
    Exactly what don’t I understand about viscosities? Let me know so that I can straighten you out on that. Yes I am aware that the first number is how it flows cold. So unless you are starting your bike when it is as you point out 0C or so, it is too thin. And since you are apparently in South Florida, you aren’t doing that either.
    #41
  2. shovelstrokeed
    shovelstrokeed Long timer
    Jun 20, 2003
    5,708
    6South Florida
    My point is that unless you are operating the engine at or near the extremes of temperature the engine will never see the viscosity equivalent printed on the bottle. The label is deceiving in that sense as the engine sees equivalent viscosity at both low and high temperature but not, for example, 50 wt at zero C or 5 wt at 120 C.
    #42
  3. ohgood
    Sep 21, 2010
    9,619
    alabama
    LOL !
    do you think they specify the bearing clearances to run a different oil ?
    how about cam journal tolerances ?
    these threads allways entertain, it's hilarious marketing regurgitation every time
    #43
    Andiflip likes this.
  4. anotherguy
    anotherguy Long timer
    Jun 18, 2009
    14,496
    the hills
    Here's some entertaining "marketing" for you to interpret you ignorant fuck. Hope you find it funny.
    The typical rule that most engine builders follow is that bearing clearance establishes the viscosity of the oil to use within a given oil temperature range. Generally, the tighter the bearing clearance, the lower the viscosity the engine can use while wider clearances require thicker oil.
    #44
  5. ohgood
    Sep 21, 2010
    9,619
    alabama
    buwahahahaha ... which is exactly NOT what you stated earlier.
    of course tolerances determine desired oil viscosities! but what your said earlier was market-speak crap.
    it's funny to read, even funnier to see fills get mad about it when they mix the wrong quotes !
    #45
  6. DeepBarney
    DeepBarney International Bumbler
    Jan 7, 2014
    2,799
    Wichita, KS
    Nah mate, I read his first comment to be exactly what that last one expounded on.
    I know it's an oil thread and delicate egos hang in the balance, but how about some civility during discourse gents.
    #46
    Rockred, cal08 and ohgood like this.
  7. anotherguy
    Jun 18, 2009
    14,496
    the hills
    What a buzz killer. :D
    #47
    ohgood likes this.
  8. bomose
    bomose Long timer
    Jul 22, 2007
    3,617
    Dixie
    #48
    anotherguy and ohgood like this.
  9. WindBlast
    WindBlast Sonorous and Effulgent
    Apr 1, 2007
    2,618
    Philly is ova dere
    #49
    CROSSBOLT likes this.
  10. FlyingDutchman
    FlyingDutchman Dirt Biker
    Jun 10, 2007
    936
    Ontario
    I was at walmart and Mobil 1 15w50 was priced at $0.11CDN a quart, by accident on clearance, I did not check. I went back and bought every bottle and paid cash! The kid at the cash was confused that I had a total bill of $2.49 for a cart of oil...about a $1.78US including 13%tax.
    I mix it with 5w50 Quaker state that I picked up at Canadian Tire for $0.99 a bottle on clearance! Again, I bought every bottle I could find.
    Is it safe to assume that by mixing the two oils, I get 10w50?
    Yes, no friction modifiers on the label
    #50
    spokester, CROSSBOLT and Baroquenride like this.
  11. Motomantra
    Motomantra Registered Lurker
    Mar 6, 2008
    3,035
    Beaverton, OR
    Whatayadoin? Tryin' to start another thread bashing?:rofl
    #51
  12. anotherguy
    Jun 18, 2009
    14,496
    the hills
    Quaker State the Milwaukee's Best of motor oil.
    #52
  13. FlyingDutchman
    Jun 10, 2007
    936
    Ontario
    If you pour it in a Motul bottle, it feels the same when you pour it into your bike. That sure is a pretty bottle.
    #53
    ohgood and Baroquenride like this.
  14. radmann10
    radmann10 Derf Supporter
    Apr 29, 2014
    1,127
    Phoenix, AZ
    My motor home takes 5 gallons of oil, I use Rotella T6 full synthetic at $20/gallon I'm good with that. Yes it is Type III dino base stock but it works for me. The big Cat diesel's RPM is limited to 2400. Not a high stress motor.
    My motorcycles take 1.6-2 quarts, I use Motorex 10-50 at $20 per quart I am also good with that. The big difference is PAO/ESTER base stock, resistance to breakdown and wet clutches. No dino oil in my bikes too small of a capacity and high stress engine environment.
    #54
    Breezlife likes this.
  15. Breezlife
    Breezlife Adventurer
    Jun 12, 2019
    48
    Dublin,Ireland
    Quarts. Love it!
    #55
  16. radmann10
    Apr 29, 2014
    1,127
    Phoenix, AZ
    Yeah, we are a Colony remember!
    #56
  17. PunkinHead
    PunkinHead Moobless Adventurer Supporter
    Dec 10, 2005
    9,731
    Land of Walmart Shoppers
    A bottle of Rotella-T killed my dog.
    #57
    concours likes this.
  18. concours
    concours WFO for 47 years
    Dec 2, 2008
    7,133
    Kensington, NH USA
    “WRX back in the day. ”
    Now that’s going back a ways....:photog
    #58
  19. PeterTrocewicz
    PeterTrocewicz Been here awhile
    Nov 18, 2009
    565
    Kincardine Ontario
    10w50 sounds right for an air/oil cooled bike, particularly one made where the climate is hot. Most manufacturers usually do provide a range of grades to use depending on temp. 10W40 would be fine if you live where it does not get that hot. That being said, I am a firm believer in using exactly what the manufacturer recommends during the warranty period, if you do your own changes. And keep the reciepts. Manufacturers can get antsy about about warranty claims with people that do their own work, and can deny warranty if the customer cannot prove that they used the "correct" oil. I have seen it happen.
    #59
    TonyKZ1 likes this.
  20. motu
    motu Loose Pre Unit
    Dec 28, 2001
    6,531
    New Zealand
    Half a quart of bitter !
    #60
