How to inspect the valves on a KTM LC4 In three easy steps.
Discussion in 'Thumpers' started by creeper, Oct 8, 2004.
  1. lauris47
    lauris47 Adventurer
    Jun 20, 2016
    81
    Denmark
    Does this sound like bad clearance of valves to you guys?
    Sound does not disappear on higher rpms.
  2. javahitman
    javahitman Been here awhile
    Mar 19, 2014
    241
    Melbourne AU
    i think it sounds more like bearing.
    but check the valve clearance first anyway as its probably the simplest thing to do at this stage anyway.
    then you might want to take the rocker cover off and inspect rocker arm bearings and other components while there
    also does it sound the same when in gear and during riding ?
    can you tell if the sound coming from the top of the engine or clutch side ? it could be cllutch too.
    also post it to 640 Index thread, there will be more people looking at it.
    and post more details about the bike what Year, how many KMs etc.
  3. Queen of Spades
    Queen of Spades tall drink of water
    Mar 20, 2009
    1,944
    Decatur, GA
    That sounds like something other than valve lash to me.
  4. lauris47
    lauris47 Adventurer
    Jun 20, 2016
    81
    Denmark
    It's after rebuilt of broken cam chain, sprocket change etc.
  5. javahitman
    Mar 19, 2014
    241
    Melbourne AU
    can it be the cam chain slapping inside ?
    have you checked the chain tensioner
  6. lauris47
    lauris47 Adventurer
    Jun 20, 2016
    81
    Denmark
    Cam chain is tensioned and in place.
  7. meat popsicle
    meat popsicle Ignostic
    Feb 9, 2004
    14,634
    Circumlocution Office of Little Dorrit
    Just did my valves - mileage approaching 30k:
    intake valves were a tight 5; exhaust were more than a loose 7 - probably 0.008 (dang I just realized I should have checked with the other end of the feeler gauge... dork). I adjusted the exhaust valves to at least a loose 7; really hate claiming I nailed the 6. I left the intakes at tight 5s. The bike fired up like it appreciated the attention - just my imagination or do slightly loose exhaust valves play that much of a role?
  8. N3il.H
    N3il.H Adventurer
    Jun 2, 2018
    27
    Plymouth UK
    So I did mine the other day! Sad to say I didn't follow this guide and for sure I did it wrong! As I know have a very tappety engine. So that was 3hrs of my life wasted, owell practice makes perfect lol
    Now iv read this guide hopefully I won't get it wrong.
  9. lauris47
    lauris47 Adventurer
    Jun 20, 2016
    81
    Denmark
    Make sure engine is in the right TDC, piston can be at the top twice, but only at one place it is correct . To be sure you are in TDC Lock the cranshaft with cranshaft locking bolt or view trough the sign glass for the little mark on the flywheel, which indicates TDC. I never like the straw method, but what Ive mentioned always worked for me.
  10. rojomurp
    rojomurp n00b
    Apr 10, 2019
    6
    Santa Fe, NM
    I was following the directions for inspecting the valves. When I got to the part about using a soda straw in the spark plug hole to find TDC I didn't have a straw handy so I used a pencil because I had one in my pocket. As I spun the rear wheel the pencil rose up in the hole as expected. I pulled the pencil out and found that the erasure and metal retainer had snapped off the end of the pencil and fallen into the engine. I tried using a strong vacuum to pull it out but to no avail. Anyone have any bright ideas for getting it out? I thought of a magnet but the metal part of the pencil is aluminum. I have to laugh because it's so ridiculous.
  11. Powderfinger
    Powderfinger Been here awhile
    Mar 3, 2013
    120
    SW PA
    Bore scope with a claw? That would get the big piece. Then a vacuum necked down to a fuel line to get the small debris. You will probably want to turn the wheel backward so the piston drops to give you room to work.
  12. meat popsicle
    Feb 9, 2004
    14,634
    put a big wad of chewed bubble gum on the end of a telescoping magnet retrieval tool.
    make sure its well attached so you don't have two things in there...
  13. rojomurp
    rojomurp n00b
    Apr 10, 2019
    6
    Santa Fe, NM
  14. timeOday
    timeOday Long timer
    Jun 20, 2008
    3,378
    New Mexico
    I've read at least 3 accounts of people breaking off pencils in their cylinder on this website. I've also done it myself, but IIRC it was just a bit of lead and wood so I just left it in there assuming it would burn up and blow away.
  15. SlowAndBulky
    SlowAndBulky n00b
    Jan 31, 2020
    3
    Czech rep.
    I have been lurking here for a while and wanna thank you all for awesome tips and trick regarding our bikes. let me thank with this insignificant item, a printable "handle" for feeler gauge. If you have an access to a 3D printer, it is printed in less than 10 minutes. Thanks once again, enjoy
    https://www.thingiverse.com/thing:4137959
    XRkeg, Jaxx625, AlexMZ and 4 others like this.
