How to Modify H4 LED to reduce glare -- This is the one you want.
Discussion in 'Vendors' started by spiderman302, Jul 16, 2015.
  1. spiderman302
    spiderman302 Recalculating
    Nov 29, 2010
    391
    Ventura County
    With LED bulbs --> similar is Never the same!
    Yes I did add the wire to the bottom slot and that made a slight improvement. H4 COB Leds and leds with large emitters do not focus well and they have a soft cut off.
    Rectangular COBs are better than round ones.
    The Phillips style with 3 or 4 inline emitters create the sharpest cut off line with a thin beam pattern which IMO is best for long range vision (DEDC).
    The wider emitters give a taller beam and better lights up the close in stuff which is better for off road and windy roads.
    but you do not want too much close in lighting because it limits your ability to see far. So you have to match your main led to your riding style.
    Then you can add aux lights for other conditions.
    Which LED do you have that is similar? I bought another "similar" COB led with a shield that was horrible. There is still a lot of junk out there.
    We need to help each other by letting others know what works well on your bike.
    tundradirtbiker likes this.
  2. tundradirtbiker
    tundradirtbiker Been here awhile
    Aug 5, 2009
    834
    Oregon City
    A ton of work. Thanks for the work and posting it here.
  3. appliance57
    appliance57 Long timer Supporter
    Dec 11, 2014
    2,700
    Boston
    Many thanks for this tip. I installed the cyclops led in my hyperstrada and there was a beam problem - the 20 gauge solved it. Plenty of focussed light and a nice sharp cut-off. Much appreciated.
  4. Don Coyote
    Don Coyote Long timer
    Oct 3, 2008
    3,297
    Upper Midwest, US
    Any more feedback on the DEDC H4? I like the warmer light and lower power draw of this over the G6. Can you advise how far the fan protrudes back from the mounting plate? The G6 was measured earlier here at 44mm. The DEDC looks problematic for clearance with the cord leading directly back from the rear instead of to the side.
    Are these fans water resistant in general?
  5. jjxtrider
    jjxtrider questionable
    Aug 17, 2013
    4,314
    Halfway to hell (WI.)
    I have a set of those in my truck , H13 base . they're really nice . The cutoff is about the same as the stock bulbs but much brighter . Only issue is they should be superglued or something to the base once they are installed. At least on my H13's the bulb itself can technically fall out since the little locking channels/pins are too small and weak to hold, mine could pull straight out without a whole lot of effort but in 2 months haven't moved . I do have a set of H4's now sitting waiting for time to install in one of my bikes to compare to the others.
  6. Don Coyote
    Oct 3, 2008
    3,297
    Upper Midwest, US
    Do the pins/channels on the H4 look any different than a stock halogen?
  7. spiderman302
    Nov 29, 2010
    391
    Ventura County
    Using my DRZ headlight here are the three patterns of the DEDC top, Evitek G6 middle and the COB on the bottom. The exposures might be different since they were done on different days. But it will show you what I mean by thin vs thick vs flood. one is not better than the other, rather it provides the rider a choice of how he wants the road illuminated. All have a nice cut off the bottom is a bit fuzzy and the top is the sharpest.
    Again it is nice to have these choices. (updated the links at the beginning of this thread for these three lights)
    16VGTIDave likes this.
  8. spiderman302
    Nov 29, 2010
    391
    Ventura County
    IMHO...
    The modern projector lights have cut off that is too sharp. There is "NO" light above the bright horizontal line. This creates a problem in that the rider can not see above the line. This is a real problem when riding on dark windy roads. The DOT specs does allows about a 10% or less light intensity spillage above the line so as to fill in this shadowed area and this light level is tolerable for on coming traffic. 10% may not seem much but our vision is logarithmic so it does help a lot. So the LED converted halogen reflector actually works better than projector lights in this instance.
    The "ideal" low beam has 90% of it's output on a"razor" thin line on the horizon. The light below the horizon should fall off logarithmic.
    Any bright light close to you makes it harder for you to see far away. You will notice this if you use "flood" lights. You can see a lot close up but stuff far away is dark.
    This is why it is better to turn off the low beam when you turn on the high beam. Your eyes dynamically adjust to the brightest light.
    but the flood type of lighting is better for off road where you do not need to see far but you need to see what is up close....
    More light is not better. Light in the right place is better.
    The H4 led bulb connector fits firmly into the H4 socket.
    Alexander B and 16VGTIDave like this.
  9. Don Coyote
    Oct 3, 2008
    3,297
    Upper Midwest, US
    After receiving and attempting to install the DEDC, i can say the mounting point is slightly different from stock H4s. The metal ring with the three flat 'pins' around it is secured to the plastic base with two screws. On the stock halogens i have these are tiny screws around the cylinder of the bulb, while on the DEDCs these are larger screws on the flat part of the ring. The plastic moulding that receives the screws is in a position that blocks the plastic lock ring on my 06 BMW F650GS from snapping into place. I had to carve away the plastic in two spots with a box cutter to make enough room for the ring to snap in...
  10. bensgone
    bensgone Been here awhile
    Nov 4, 2009
    628
    nw oregon
    Thanks to all! Good info, good comparisons!
  11. AZ Dean
    AZ Dean Moto Paparazzo
    Oct 7, 2009
    130
    Valley of the Sun
    @spiderman302, any 9007 LEDs to recommend?
    Thanks for your hard work on this, it is very, ahem, enlightening. :D
  12. spiderman302
    Nov 29, 2010
    391
    Ventura County
    I have no experience with the 9007 bulb.
  13. Baroquenride
    Baroquenride Everyone dies, but not everyone truly lives.
    Apr 10, 2011
    4,267
    Clark Co, Wa
    AZ Dean, I asked him about that recently and I'll try to forward you our conversation. I have yet to buy any 9007 LED but he recommended a couple different ones.
  14. Whiteeyelashes
    Whiteeyelashes Adventurer
    Apr 14, 2016
    95
    Bahamas
    Spidi, you are now recommending the Kawell light over the Evitek? That's the updated link on page 1. I'm confused
  15. spiderman302
    Nov 29, 2010
    391
    Ventura County
    Evitek is the fabricator. Kawell is a vendor (middle man). I do not care from whom or where you buy your lights. I do not make anything from this. Today there are a lot of choices to pick from. If anyone finds anything better or lower cost, I will up date the first post to keep it current if I can so that new readers do not have to dig through the entire thread looking for the best link. But vendors come and go so it is best to do a quick search yourself. I have published this information so the fabricators will get the correct process to make the H4 led bulb and you will know what you should be looking for. It is a WIN WIN for all.
  16. Whiteeyelashes
    Apr 14, 2016
    95
    Bahamas
    Thanks, the Kawell you linked to are half the price of what I find when I google Evitek g6 h4. You're a champ!
  17. massrider
    massrider Been here awhile
    Apr 23, 2006
    481
    Mas a chews its
    @spiderman302
    I ordered the Kawell H4's you linked to in the first post, https://www.amazon.com/KAWELL-LED-H...011&ie=UTF8&qid=1484735178&sr=8-1&keywords=h4
    I received these a few days later; IM003837.JPG are these the correct lamps you posted about? The ad listed them as 6,400 LM but these are clearly 4500LM and although they look just like the Evitek there is nothing on them that says who made them. At only $34 shipped it's not like I am too worried about them but if I was suppose to receive something else I'll try to contact Kawell and see what's up.
    By the way, thanks for all your work testing these and I'll be certain to post my impression when I get a chance to try them.
  18. spiderman302
    Nov 29, 2010
    391
    Ventura County
    Yes I recently ordered two sets from Kawell to help outfit a friends bike and to have some spares. One bulb the shield was not level. easy fix. Power and brightness is the same. You should be good.
    Alexander B likes this.
  19. massrider
    Apr 23, 2006
    481
    Mas a chews its
    Ok, thanks. I'm glad they're the correct ones, it is an awesome deal for that price.
    I did notice one shield was not level, I'll tweak that before I install them.
  20. Whiteeyelashes
    Apr 14, 2016
    95
    Bahamas
    I just installed a Kawell on my bike yesterday. Love it! Box had 6400 Lm ticked. Thanks Spidi!
