How to open GPX files and resize tracklogs with Mapsource
Discussion in 'Mapping & Navigation' started by PhilSpace, Dec 12, 2005.
  1. PhilSpace
    PhilSpace The Ex-Gov
    Feb 1, 2002
    36,075
    Springfield, VA
    I have had a couple folks ask how to open a GPX file from Mapsource, it's simple. Click on open and then select the file type pull down at the bottom - nothing to it:
    Some of the Garmin GPS's have a configurable tracklog allowing the user to record points more frequently which makes them real big. If you have a monster that you want to work with or post, simply open it up in Mapsource, right click on the track log and select properties. From there you can click on the filter button to change the sampling of the track:
    If you have any other questions, post them here. That way it will be easier to search for routes and tracks in the future without all the clutter.
  2. iDave
    iDave Been here awhile
    Jan 27, 2003
    910
    I'm using Mapsource Metroguide Version 5.00, which would NOT open downloaded .MPS or .GPX files after multiple attempts. I went to the Garmin site, downloaded their latest version of MapSource, version 6.9.1, now the files open without a hitch. Hope this helps someone with similar frustrations :D
  3. dlearl476
    dlearl476 Two-bit Throttle Bum Supporter
    Oct 5, 2005
    64,735
    Happy Valley, USA
    Anyone still here???
    I just downloaded a few .gpx tracks and some (most) open fine. One (the one I really want) gives me a "Can't Open File" error message. Nothing else i.e. different version, file corrupted etc.
    Any ideas?
  4. Countdown
    Countdown Long timer
    Oct 20, 2003
    6,933
    Carson City/Ridgecrest
    No such thing as ".gpx tracks".
    ".gpx" is a file extension that tells the computer what type of file it is.
    "Tracks" are data within a file.
    Mapsource and many other programs will open a ".gpx" file. If program says it can't open a file, you are SOL.
  5. dlearl476
    Oct 5, 2005
    64,735
    Happy Valley, USA
    Yeah, I understand all that. It sucks it won't open. Looks like a great trip.
    http://www.gpxchange.com/fileinfo/index.asp?fid=106210&return=geofinder
  6. ramz
    ramz Professional Trail Rider Supporter
    Dec 11, 2006
    2,836
    Salida, CO
    Not that this helps, but on my iMac, I was able to download the gpx file and import it into NG Topo with no problems. The file is 8,210 lines long, looks like a normal gpx file, and starts with (<> removed):
    ?xml version="1.0" encoding="UTF-8" standalone="yes"?
    gpx version="1.1" creator="DeLorme Topo USA® 8.0 - http://www.delorme.com" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.topografix.com/GPX/1/1" xsi:schemaLocation="http://www.topografix.com/GPX/1/1 http://www.topografix.com/GPX/1/1/gpx.xsd"
    <metadata><name><!--[CDATA[Big Water to Kodachrome area]]--></name><desc><!--[CDATA[Dirt Bike route from Big Water to near Kodachrome.]]--></desc><author><name><!--[CDATA[Derek]]--></name></author></metadata><name>Big Water to Kodachrome area</name>
    Ooops, looks like some text got deleted; probably looked like html. But you get the idea.
    I could send you the file..... but the download is probably identical. You may have a file type problem, I'm not a windoze guru.<gpx version="1.1" creator="DeLorme Topo USA® 8.0 - http://www.delorme.com" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.topografix.com/GPX/1/1" xsi:schemalocation="http://www.topografix.com/GPX/1/1 http://www.topografix.com/GPX/1/1/gpx.xsd"><trk><gpx version="1.1" creator="DeLorme Topo USA® 8.0 - http://www.delorme.com" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.topografix.com/GPX/1/1" xsi:schemalocation="http://www.topografix.com/GPX/1/1 http://www.topografix.com/GPX/1/1/gpx.xsd"></gpx></trk></gpx>
  7. 250senuf
    250senuf Long timer
    Feb 17, 2008
    3,889
    Nelson area, Kootenai, BC, Canada
    Can you get back to the source of the faulty track on the chance something went wrong before they uploaded it?
  8. tbirdsp
    tbirdsp REMF
    Mar 22, 2002
    8,950
    Nebraska
    Yeah, something is screwy with the file. I downloaded it, started opening with Mapsource, then it said "file could not be imported" :dunno
    #8
