How to tie off Ancra Cambuckle straps
Discussion in 'The Garage' started by Keithert, Oct 2, 2019.
  1. Keithert
    Keithert Long timer
    Jan 6, 2013
    1,363
    NW suburbs of Chicago, IL
    My mechanic buddy showed me a way to tie the end of a cambuckle strap in a way that made it harder for the cambuckle to come loose. He used a slip knot so that it could be easily released when I wanted. But I can't remember how he did it. Does anyone know such a technique?
  2. concours
    concours WFO for 47 years
    Dec 2, 2008
    7,169
    Kensington, NH USA
    Genuine Ancra cam buckles do not come loose. The diamond shaped stipples penetrate the webbing, as designed. (the nylon stretches, so the strap gets loose.) Tighten after a couple miles. I use electrical tape to keep the tails from wind flapping my precious cargo.
    And, today only, special sage wisdom for you all.
    Take the same roll of electrical tape and close the “S” hook, all of them. If you do this, and your truck/trailer hits the mother sized sucker bump from hell, you remove the very slight but-it-has-happened chance the S hooks will “unhook” themselves as your moto suspension bottoms as well.
    Your welcome.
    rufus, Boatman, DonM and 1 other person like this.
  3. Zuber
    Zuber Zoob Supporter
    Sep 28, 2004
    5,958
    West of the West, Oregon
    I found when Ancra's get old they can slip. I thought they were worn out after 20 years. But, it was only that the pivot on the release was corroded and a little bit of WD40 fixed them right up. I'm still using my originals from 1973.
    To prevent all my tiedowns from slipping, I put a loop around and under the buckle.
    Take the loose end and make a loop. Keep the ribbon flat and loop it around the tiedown and tuck it under the buckle and under itself making a simple slip knot. The end remains hanging out, you just pull it to release. Tucked under the buckle, it will jam the knot tight if the clamp slips.
  4. MattLikeyBikey
    MattLikeyBikey Been here awhile
    Nov 8, 2018
    423
    So Cal
    Pretty much covered but yes I like to keep the length past the buckle completely parallel until passed through the metal loop, then tie it off. The technique here for trucker's hitch would work to tie off.
    DonM, anonny, Guano11 and 1 other person like this.
  5. DonM
    DonM Do-dah Do-dah Supporter
    Jan 13, 2008
    2,666
    Atlanta, GA
    On a similar note, My way of hooking to soft ties on forks , frame or bars. Don’t see how it could disconnect.
  6. Baroquenride
    Baroquenride Everyone dies, but not everyone truly lives.
    Apr 10, 2011
    3,831
    Clark Co, Wa
    ^ Not just like, but really like!
  7. MattLikeyBikey
    Nov 8, 2018
    423
    So Cal
    For sure. Soft straps can be scary. Nice technique.
  8. DonM
    Jan 13, 2008
    2,666
    Atlanta, GA
    Photos or it can’t happen for me:confused
    #8
    Baroquenride likes this.
  9. concours
    Dec 2, 2008
    7,169
    Kensington, NH USA
    I think he means “lube the pivot pin/spring”
    In the frozen North, snowmobiles, road salt, it’s a preventative maintenance thing.
    #9
  10. concours
    Dec 2, 2008
    7,169
    Kensington, NH USA
    No, but the other end of the strap can.
    #10
    rufus likes this.
  11. markk53
    markk53 jack of all trades...
    Dec 20, 2007
    17,986
    Delaware Ohio
    I will wrap the strap through the hook loops if there is a lot of slack. Then I tie them off, by wrapping them around the straps until almost all wrapped up then I stick the end down through the last wrap and pull it up (or down) tightening the knot like a neck tie. It should keep the strap from pulling loose and it keeps the end from slapping around in the wind.
    #11
