The first one (early this year) the bolt that holds the spring pulled out of the aluminum kickstand allowing all of the supporting pieces to fall off. Bought an OEM replacement and did exactly two rides. This past weekend the bike was parked in our campsite and the ground was just slightly soft allowing the kickstand to sink in an inch or so. I didn't think anything of it until the bike tipped over a few hours later. After picking it up I saw that the kickstand had broken right across the plane of the bolt which secures it to the frame. For the record, no I do not stand or sit on the bike while on the stand, use it to pivot the bike, or otherwise abuse the kickstand.
I've been getting on my bike " John Wayne" style using the left footpeg and have not had any issues with the bolt breaking or the stand bending. But I always make sure the stand is on firm footing and I inspect/lubricate the bolt every now and then.
My statement wasn’t meant as an accusation, I was just stating my experience with this issue. My buddy owns a KTM dealership so I’ve seen my fair share of broken bikes, and the kickstand seems to be pretty high in the list for the dirt bikes. FYI, the owners manual also makes a statement to this:
Wow, those two are just weird really. I can't believe it broke supporting the bike at your camp. And like you, I've never stood on a footpeg/kickstand to get on a bike.
2000's era Husky 610 "steel" stands are actually made of silver painted rigatoni. I had one break while the paint shaker was idling in my driveway. Had a bad weld break on my GF's '04 KTM stand mount, don't know how it held on as long as it did. The plastic foot on KTM stands do kinda suck. We never mount bikes with the stands down, even street bikes, which gets me some strange looks. PMB stands are nice and super stout, worth the weight. I've had two with no problems, wouldn't mind one on the 570.
Wus! Who reads the directions. LOL I get on all my bikes by stepping on the peg. Apparently then, my PM program has got me through my lapse in judgment. I guess this is like " what oil you using?" LOL All kidding aside, like I stated I always step on the peg to get on my bikes. I simply ensure the bike is parked on a firm surface preferably with any uphill slope on the stand side. I always make sure that the weight my foot places on the peg is straight down on the stand. Sideloading the stand is a bad idea. I give the set up a weight test before putting my full weight on it and keep myself balanced over the stand while swinging on. I did trash a stand getting off the bike without stepping on the peg. The buckle on my MX boot hooked something and down we went. With a little pratice, you'll master the " John Wayne" method.
Nah. Just rather get a new bike than replace old bolts. These stolen credit cards #s are a gold mine.
Meh, back in the day when I first started riding big bikes, we pretty much all had mx bikes-no kickstands, radiators, disc breaks-‘lectric starters and kickstands were fer street bikes!
For those interested: this is the inside of a an exhaust with 3000 km and 90 hours. I had expected worse - or rather hoped, as replacing this stuff with new fillers will probably not reduce noise emissions very much.
This thingy came with my 2011 FE 570. Looks like some fuel filtering device to me. Is it indeed, should I install it and if yes: where?
That's harsh ;-) I'm not totally pro emissions so now I'm even more interested to know what this is...
Awful; just this post alone gave the endangered Spotted Tree Squirrels here headaches/nausea/and blurred vision. Our dung beetle population will never recover.
Thanks, very helpful! Is that US specific? I might actually install it next time I have to remove the radiator since I have the stock exhaust and the weight is negligible, however I wonder if it works well with my EU mapping. And that impressive "evap" (if I understood that correctly) system: is it meant to prevent that slight but still unpleasant gasoline smell in my living room when I take the Berg inside? That would be something... but I would probably not want to invest a few hundred bucks into the required subframe. But nice how they managed to stuff it all in there. The wasted space in my subframe annoyes me a little. I am pondering the idea of opening it on the top and use it for spares etc.
Hello, I'd appreciate some advice. Just getting time to pay attention to the 'Berg. 2101 FX450, 180ish hours. Less than 5 hours of usage ago, everything in the fuel system was perfected; tank cleaned, new filters, zip-ty, new injector, new fuel pump, TPS adjusted ........ So I went on a quick ride; ran perfect for about 10 minutes and stopped for about 10 minutes to do something. Started up perfectly, accelerated fine at first, then bogged and shut off. Only went about 30 meters and would not fire, cranked freely with no response from throttle. I checked everything and got to the TPS adjustment. Max counter clockwise adjustment only produces .30 volts. Have to remove the torx screw and turn it about 30 more degrees to get .61 volts and obviously no way to secure it in this position. What is the solution here? Can I get the TPS separately or is it the whole Throttle body thing? Is it something I can rebuild? (slightly rhetorical here, I have the TPS removed for cleaning, but I would like input) Thanks in advance.
