1. ** Enter to win a $250 gift card! We want to hear from you, please take this survey **
    Take this survey which covers a range of questions about improving the community, the things that interest you and anything else you want to share with us. All responses will remain anonymous.
    Click here to take the survey
    Dismiss Notice
Husaberg 70 Degree Owners Thread!
Discussion in 'Thumpers' started by KayaKTM, Nov 22, 2010.
  1. Baggi'tard
    Baggi'tard If I don't answer I'm ridin' or shootin' Supporter
    Sep 20, 2006
    3,562
    Farmhouse Inn, Tellico Plains, TN
    Hey Mike,
    on the 2010 FX450 throttle body diagram..(same part on all the other models too)
    #5 , Part No. 81241077044, TPS KPL. 09 | 09 $126.59
    funny thing is.. order it as a KTM part and it's about $30 CHEAPER! (on same website AOMC). it cross references to all the 250/350/450/500 bikes through 2016.
    mikejana likes this.
  2. jdubb75
    jdubb75 Vicarious Adventurer
    Jan 11, 2008
    2,401
    Deep South(ern) Indiana
    Have you gone through the electrical connections leading up to the TPS and verified it is getting voltage?
    I know it isn't directly TPS related, but did you pull the plug and make sure it is firing while cranking the bike?
    And, if ordering from AOMC make sure to use code "betariders" for an additional 10% off. At least I assume the code still works. I haven't tried it several months, but it has worked for years.
    TavisB and mikejana like this.
  3. mikejana
    mikejana Been here awhile
    Apr 13, 2018
    345
    Florida's Space Coast
    Thanks Kyle,
    I would have definitely bought the $126.59 81241077044 instead of the $95.36 81241077044.
    Thanks Joey, First thing I did was pulled the plug and checked for spark. Then the tank, cleaned all the connectors and made sure fuel pump was working. I put it all back together and nothing so, I'm sad to admit, gave it a shot of ether and it fired immediately. Then went back to reset TPS. So strange to me how you can get no ignition at all with a mis-set TPS.
    I use betariders every time there, it still works.
  4. jdubb75
    Jan 11, 2008
    2,401
    Very curious.
    I wish the repair manual contained info on testing the TPS itself and not just info on setting it. I once had a carb'd YZ250F that had a TPS on the carb and the repair manual contained info on setting the TPS as well as testing it for faults.
    Please let us know if the new TPS is the fix.
  5. jdubb75
    Jan 11, 2008
    2,401
    @mikejana - Out of curiosity, when you had the TPS hooked to the multimeter, did you twist the throttle to see if the voltage increased smoothly until full throttle?
  6. mikejana
    Apr 13, 2018
    345
    I did.
    I even hooked the tank up and tried get it to start while holding the TPS near the .61 volt mark, but it did not work for me.
  7. fritzcoinc
    fritzcoinc Enjoying my last V8 Supporter
    Apr 30, 2008
    10,236
    Hockley, Tx
    Did you check the tank vent in the cap?
  8. mikejana
    Apr 13, 2018
    345
    I did not. But I was a short push to a gas station and topped her off with no change.
  9. jdubb75
    Jan 11, 2008
    2,401
    In case you weren’t aware, there was/were/are issues with the check ball in the oem cap causing venting issues resulting in vapor lock or pressure building inside the tank. It seems to be a fairly common practice to remove the check ball. Just be aware it could spill gas out of the vent with the bike on its side.
    I removed the ball and replaced the vent hose with a clear fuel hose so I could see if the gas was boiling out or spilling.
  10. NoClassic
    NoClassic Been here awhile
    Apr 29, 2017
    243
    The TPS sensor housing is known to allow moisture in which could cause problems. Some people will run silicone along the seam between the two sides of its housing.
    Are you measuring the TPS voltage at the sensor itself or the primary ECU connector? ECU is usually your best bet as it is easier to access and get a good reading from. Check your primary battery ground before you go ahead with purchasing another sensor.
  11. mikejana
    Apr 13, 2018
    345
    So, the new TPS sensor does the same. I actually noticed that both sensors are registering negative voltage; yes negative lead to black, good continuity to ground and positive lead to yellow. Tried it with 2 different batteries with no great change. I'm measuring at the ECU connector.
    Suggestions appreciated.
    I have a new battery to be delivered here tomorrow.
  12. NoClassic
    Apr 29, 2017
    243
    Are you powering the control system by bridging the two diagnostic pins when testing the TPS? All of that sounds really strange/the test is not being performed properly.
  13. mikejana
    Apr 13, 2018
    345
    Yes, bridging black/white and brown wires on the diagnostic port, pins 5 & 6.
    I'm fallible, but I've done it before successfully.
    This bike has had some gremlins that I've been exorcising.
    It was well sorted in it's early life, but I bought it from a teenager about to trade it in at a Yamaha Shop.
    He didn't know what he had, his brother got it from an estate sale.
  14. NoClassic
    Apr 29, 2017
    243
    So weird
    May be time to have a look at the complete wiring harness.
  15. mikejana
    Apr 13, 2018
    345
    Mine actually came with a spare wiring harness, I've already swapped with much improvement until now.
    I was kinda thinking the same thing until I priced a new one - $419.03.
    I'd go for the 2011 FS570 harness and get all the goodies for $447.19, or part out my bike.
  16. Baggi'tard
    Sep 20, 2006
    3,562
    I've put in a help desk request to my EE buddy, he's crazy smart and has walked me through more than a couple electrical issues. He's not just nerdy EE smart, he's also a motorcyclist and has done things like built his own bluetooth capable quick shifters for track day bikes.
  17. mikejana
    Apr 13, 2018
    345
    Thanks, Kyle.
  18. Dao1
    Dao1 Long timer
    Mar 17, 2014
    2,006
    Austin TX
    so how does bluetooth + quickshifter work?
  19. fritzcoinc
    Apr 30, 2008
    10,236
    Hockley, Tx
    +1
    I Phone only?
  20. TegRacer324
    TegRacer324 Adventurer
    Feb 29, 2012
    66
    CT
    Button on the handlebars linked to a Bluetooth rotary actuator? I'm assuming drag bike? I suppose it would help on road courses but haven't seen many quick shift kits there.
