Husaberg 70 Degree Owners Thread!
Discussion in 'Thumpers' started by KayaKTM, Nov 22, 2010.
  1. Baggi'tard
    Baggi'tard If I don't answer I'm ridin' or shootin' Supporter
    Sep 20, 2006
    3,168
    Farmhouse Inn, Tellico Plains, TN
    The kit comes with a new bolt and washer. And I think that's why the new spacer is designed with a groove that accepts the seal lips, has a flange that covers part of the seal (should help keep dirt out), and also comes with slightly bigger diameter o-ring. All that together should help make a better seal than the plain sleeve spacer and o-ring combo as originally designed.
    And no oil will come out when you pull the seal.
    totensiebush likes this.
  2. Baggi'tard
    Sep 20, 2006
    3,168
    Here’s the stuff in the kit, new flange and o-ring versus original style on top
    NoClassic, Dao1 and totensiebush like this.
  3. totensiebush
    totensiebush re-tarded
    Feb 17, 2006
    336
    Alameda, CA
    I mean a new bolt and washer whenever I change it in the future :)
    good to know that no oil will come out.
  4. Dao1
    Dao1 Long timer
    Mar 17, 2014
    1,820
    Austin TX
    anyone using this $25 temp rad cap?
    It looks taller than stock cap, so
    does it interfere w/ the side of gas tank when turning it open/closed?
    can i view the temp while seated or standing up?
  5. mikejana
    mikejana Been here awhile
    Apr 13, 2018
    270
    Florida's Space Coast
    Works great on my 2010 FX450,
  6. Baggi'tard
    Sep 20, 2006
    3,168
    Trail Tech Stealth has water temp readout.. :D
  7. Hertz13
    Hertz13 Been here awhile Supporter
    Aug 19, 2018
    186
    Central PA
    I put one of these on my WR250R and it leaked at first but then seemed to stop. I put the bike away for the winter then sold it so I didn’t put a lot of time on with the cap to know if the leaking definitely cleared up. I’ve read a lot of reports online of them leaking as well. Seems like a hit or miss product.
  8. jdubb75
    jdubb75 Vicarious Adventurer
    Jan 11, 2008
    1,958
    Deep South(ern) Indiana
    Went out for a little exploring this afternoon/evening. I found an old cemetery with most of the headstones (that were legible) dating back to the early 1800's and saw some cool cliffs along a river.
  9. Dualsport4ever
    Dualsport4ever Been here awhile
    Dec 2, 2012
    849
    Red Sector A
    Often times it is surprising what cool things are right in your own backyard - one only needs to look. Nice pics.
  10. jdubb75
    Jan 11, 2008
    1,958
    So true. The roads less traveled often lead to some nice surprises.
  11. Huskyfatman
    Huskyfatman Stinky Wizzleteats
    Oct 23, 2007
    2,809
    Destroying skid plates
    +1 & 2, running them on the 570 and the GF’s KTM. They work great!
  12. Huskyfatman
    Oct 23, 2007
    2,809
    Dao1 likes this.
  13. Dao1
    Dao1 Long timer
    Mar 17, 2014
    1,820
    Austin TX
    My BD XL-PRO LED headlight producing 4,900 lumens @ 40 watts.......
    .....fully lit up in the woods ...
    ....is barely adequate for a fun dusk ride through the trees.
    Once night turns pitch black, I need to add some serious helmet lights if I want to stay upright :D
    Anyone night riding in the woods? what's a good helmet light setup?
    twotyred likes this.
  14. jdubb75
    Jan 11, 2008
    1,958
    That's a little surprising to hear. I have the Squadron Pro (4,900 lumens also) and it has been more than bright enough for me at night on county roads and highways. I have not used it in trails at night, but it seems crazy bright. I have the spot lens on mine though. I thought about getting a combo lens to try, but haven't yet.
  15. totensiebush
    Feb 17, 2006
    336
    Alameda, CA
    I also have an XL Pro and need to figure out how to aim it. Right now it's way too high.
    I rode through the Donner Summit train tunnels so it was pretty much pitch black.
  16. jdubb75
    Jan 11, 2008
    1,958
    My Squadron was aimed way too high when I first installed it...even with the extensions for the upper mounts out all the way. In the pic below you can see where I removed just enough plastic to let the bottom of the light be adjusted all the way in. Before I removed the plastic, the nut on the bracket was hitting and not allowing for full adjustment.
  17. totensiebush
    Feb 17, 2006
    336
    Alameda, CA
    I haven't touched mine yet, just surprised that someone drops that sorta money and doesn't aim it decently
  18. Dao1
    Dao1 Long timer
    Mar 17, 2014
    1,820
    Austin TX
    yea, on roads & straighaways, there's plenty of lighting.
    but in the woods, going up, down and around trees at slow speed, I need extra wide spread distribution vs. its narrow focus distribution. That's why I'm leaning towards adding some helmet lighting to my xl pro. Also, the xl pro used around my city & - especially at night time - I'm getting my share of pissed off on coming cagers being annoyed & blinded by its harsh glare, despite mine being aimed down low for the woods, and at 20% of full power on low beam. This isn't a dig against BD b/c I knew prior to buying their light that it's marketed as non-DOT, no "cutoff" designed into the optics, but I rolled the dice on it anyways. Heck, I had no idea that I'd be having so much fun trail riding well past dark. But for now, I'll put up with this negative since it's a small % of total run hrs.
    Good point about that nut restricting the last few mm's of travel down low. I cheated & just flipped the bolt around so that the nut is facing out.
    That added about another 1/4" clearance...every bit helps...
    This is the extension brackets that jdubb's talking about in case you didn't catch that....
    ...this extension bracket is the main reason why I bought their headlight and mask all packaged together.
    And one last tidbit....I tried running the brake hose in the default front of the mask, but I didn't like how the brake hose was severely rubbing up against the mask w/ the brkt extensions in place.
    I rerouted it like this to have it sliding up / down more vertical & w/o alot of rubbing
    The $2 cable guide & $4 wire wrap are both from Home depot
  19. jdubb75
    Jan 11, 2008
    1,958
    Well, these showed up today. I saw someone mention they had some Berg parts for sale and they were among them. I don't currently need them, but maybe they'll come in handy if/when I add a 570 to the mix.
  20. woods wizard
    woods wizard Trail Hound
    Mar 15, 2008
    1,236
    Welcome to No.Va...expect delays
    Last weekends camp and ride. This is Western Maryland / West Virginia. 20191003_183153.jpg 20191004_092520.jpg 20191005_132544.jpg 20191004_092357.jpg
