Husaberg 70 Degree Owners Thread!
Discussion in 'Thumpers' started by KayaKTM, Nov 22, 2010.
  1. spudp
    spudp Been here awhile
    Jul 16, 2013
    152
    Cumming, GA
    I just recreated the issue on my bike. There’s a middle set of tabs on the subframe bracket that your seat doesn’t appear to be slid under. This will create the gap.
    now let’s see a picture of the rest of the bike. I’m curious to see that graphic and frame combo. :)
    SuzukiDoctor650 likes this.
  2. Indy Unlimited
    Indy Unlimited Long timer
    Jan 21, 2007
    1,991
    Parker, CO
    Yes under the seat there are 2 holes that have to slide forward along the frame rails and hit the hooks in order to sit flush.
  3. NorseCycles
    NorseCycles n00b since 2008 Supporter
    Aug 1, 2008
    384
    SW CO DRO
    As an FYI, it’s a pain in the a** on my ‘Berg to catch those two rails just right. Always a fight…
  4. Dualsport4ever
    Dualsport4ever Long timer Supporter
    Dec 2, 2012
    1,084
    Canada - East Coast
    Replacing the oem lead acid battery with a LiFePO4 battery makes fitting seat much easier, in my experience, as you gain a bit of space under there.
  5. Gasman_ADV
    Gasman_ADV Long timer
    May 1, 2012
    1,085
    Just put a couple of pk screws into the ends of the plastic hooks, to extend the lenght of the hook
    Not pretty but holds the seat to the bike better
  6. webmonstro
    webmonstro A Aventura Continua....
    Jul 21, 2008
    1,256
    Portugal
    Don't forget the two fins that fit on the inside of the frame rails just next to the battery
    If they are allowed to sit on the rails they will bend and push the seat up and not allow it to go all the way down
  7. Francesco2
    Francesco2 Adventurer
    Jun 1, 2010
    28
    Holland
    Could also be that your seat cover is too tight and pull the seat in a more curved (smaller radius) shape?
    Seen it with me repolstered seat few years ago.
  8. 400psi
    400psi Cropdusting
    Jan 16, 2009
    888
    Weaverville NC
    A little jaunt last weekend. First time to ever experience the bike flame out? Only did it once though. I had fallen off and the bike slightly inverted off the trail till i could right it. The bike had spilled a bit of gas during this episode so I figured it might have dislodged something somewhere? It ran well the remainder of the day.
    Good times!
  9. Dao1
    Dao1 Long timer
    Mar 17, 2014
    2,219
    Austin TX
    that's my kind of single track woods trails right there!
    trees, trees, trees everywhere!
    400psi likes this.
  10. 400psi
    400psi Cropdusting
    Jan 16, 2009
    888
    Weaverville NC
    Good times for sure! It was humid that day! It had rained previously just enough to make the soil conditions perfect, the roots slick as hell, and the air like riding in a greenhouse...
  11. imxman
    imxman Been here awhile
    Jul 27, 2013
    271
    OKC, OK
    Was not a flame-out. There's a tip-over sensor located under the battery compartment and it will shut off bike after a couple of seconds of laying on it's side.
    400psi and jdubb75 like this.
  12. jdubb75
    jdubb75 Vicarious Adventurer
    Jan 11, 2008
    2,477
    Deep South(ern) Indiana
    Was just about to say this. You sure it wasn't just the tip sensor, @400psi ?
    mikejana and 400psi like this.
  13. 400psi
    400psi Cropdusting
    Jan 16, 2009
    888
    Weaverville NC
    Sorry I wasn't clear at all in my post. The flame out occurred about ten minutes later after I had fallen. I was on some two track and moving at a decent clip and then it was like I ran out of gas. Coasted to a stop but then it fired right up. It didn't have any further problems so I had thought maybe the fall had dislodged some gunk and briefly blocked fuel somewhere?
    woods wizard, Dao1 and Rot Box like this.
  14. SuzukiDoctor650
    SuzukiDoctor650 Adventurer
    Jul 16, 2018
    34
    Upstate NY
  15. SuzukiDoctor650
    Jul 16, 2018
    34
    Upstate NY
    It does have an upgraded battery that's a bit smaller
    Dualsport4ever likes this.
  16. spudp
    Jul 16, 2013
    152
    Cumming, GA
    Nice graphics and coil spring to match.
    Is that a ‘12 model or has the frame been painted?
  17. SuzukiDoctor650
    Jul 16, 2018
    34
    Upstate NY
  18. woods wizard
    woods wizard Trail Hound
    Mar 15, 2008
    1,388
    Welcome to No.Va...expect delays
    Are the 2 front claws engaged in the seat ? It appears they are not. I had to space mine out a little w some washers to make it fit tight and not pop out on hard hits.
  19. 2ndGen
    2ndGen Been here awhile
    Nov 9, 2011
    157
    San Rafael, CA
    The Berg rides again. The radiator leak was a broken clamp I thought was tight. Thing runs great. So happy with all that work I did. Now a week of mostly dirt around Humboldt and Mendocino counties is in order. Leaving tomorrow.
  20. 400psi
    400psi Cropdusting
    Jan 16, 2009
    888
    Weaverville NC
    Looks fantastic!
    2ndGen likes this.
