Husqvarna 701 Super Moto and Enduro!
Discussion in 'Thumpers' started by Dozer720, Aug 13, 2015.
  1. CoMike1190
    CoMike1190 I never drive faster than I can see. BTiLC
    Sep 27, 2015
    180
    Castle Rock, Colorado
    Appreciate the info. I'm gonna head down to Slavens in the next couple weeks and grab everything. Thankfully his shop is only about 45min away.
  2. wass
    wass Been here awhile
    Jun 19, 2016
    152
    Wellington
    Very nice! It's the Toys2Go crashbars, had to dremel a little about 1cm
    RonSJC likes this.
  3. FlyingFish
    FlyingFish The older I get, the faster I was
    Jun 29, 2015
    595
    Flathead Lake, Montana
    Thanks for the info on repairing the clutch slave! It's a known problem for Husky and KTM. For many it's worth replacing and not playing "russian roulette" and getting stranded in the middle of nowhere.
    Sure hope you didn't have to push too far when yours blew.
  4. Lord Dogmeat
    Lord Dogmeat Long timer
    Aug 20, 2011
    1,165
    Parker, CO
    It sits right in its happy spot at around 70 .... Which, conviently, is what the speed limits are around here. Not that I pay that close of attention, it will cruise along at ~82 just fine a little bit revved up :)
    My bike is a '16 too, I imagine the 17's and newer would be perfect with this setup and much better off-road to boot.
    FlyingFish likes this.
  5. K_T_M
    K_T_M Adventurer
    Jan 22, 2012
    30
    Sonora CA
    You are welcome. I was fortunate to be able to ride out of the mountains solo without the clutch but was definitely challenged with starts, intersections, and tight spots. Kinda hard on the bike and ruined what began as a good day.
    KTM/Husky/Magura need to address this well known issue with a reliable solution - so far, no joy. I am out $ for parts, an oil change (clutch oil in engine/gearbox), labor, and ability to ride because KTM/Husky evidently doesn't care about reliability, safety, holding themselves accountable, or customer satisfaction (my 3rd 690). And yes, I talked at length with their peeps at US HQ and a dealer in Sacramento.
  6. JDouglas
    JDouglas Adventurer
    Aug 16, 2013
    43
    Here and There
    Due to a sudden attack by the ground, I need a new turn signal. There are two different part numbers on the fiche. Can anyone tell me the difference between 60114026000 and 60114025000? They appear to be the same thing. Thanks
    CoMike1190 likes this.
  7. Foo Bar
    Foo Bar Semper Fi Supporter
    Nov 19, 2017
    124
    Somewhere Between Space and Time
    Check out these images. You can read on the OEM box which corner each part number fits.
    JerseyJeeper likes this.
  8. Magile
    Magile Long timer Supporter
    Apr 11, 2005
    1,163
    HVL, NC
    Mosko Moto recently posted Reckless R80 & Perun Rack news on their blog. These guys don't stand still :clap - M
    "Reckless 80 Fitment: KTM 690 & Husky 701"
    "I was having some fit issues with the R80 on my KTM 690 on the last few trips. Sometimes the bag would move around a bit while riding or contact the tire when the suspension compressed. The main issue is that the R80 is designed to mount on a bike where the rear of the bike is wider than the seat, whereas many of the rear racks for the 690 are actually narrower than the seat. Also the 690 has a pretty aggressive forward lean to it, more like a dirt bike than a touring bike."
    "The answer is this rack extension I ordered from Perun Moto, who also makes the best rear rack for this bike that I’ve found so far. I also put the passenger peg mounts back on the bike, minus the pegs themselves, as a connection point for the R80 leg straps. Problem solved. The fuel hole lines up with the filler cap, the connection to the bike is rock solid, there’s no ‘bulge’ in the harness over the seat. Posting pics here in case anyone else has experienced this issue on the 690 or 701."​
    Dukehunt, Michhub and Bhart89 like this.
  9. Shawnee Bill
    Shawnee Bill Long timer Supporter
    Feb 25, 2006
    5,636
    Oklahoma
    Yep, I'm a sucker, read that and it took me just a little while to order my Perun rack extension. But I did go out to the garage and check to see if I could make my own rack extension but decided to just buy one.
  10. DirtJack
    DirtJack Adventurer Supporter
    Aug 12, 2007
    3,328
    395 miles South East of Orla, Texas
  11. MxFan69
    MxFan69 Im so happy
    May 4, 2014
    1,672
    Looking for some place cool
    Can yall help keep me from reading 1000 pages here, and help with a question on buying the Enduro vs Supermoto please.
    I was set this week to start looking for a clean used 701 enduro, and then thought about the extra set of TE300 Husky 21”/18” wheels I have. All of a sudden it seems like it would be smarter to look for a supermoto, and have both on and off road since I already own the 21/18 wheels, and get the 17”x2 wheel set up in the purchase.
    My dilima is that while reading about the 2 models, I see the supermoto has 50 mm less front and 15 mm less rear travel than the enduro suspension. In addition obviously the supermoto will have different fork and shock valving.
    SO, MY QUESTION; has anyone here bought and successfully used the supermoto for double duties without major complaints from the suspension department, while riding dirt/trails/fire roads with an 21”/18” wheel set up. I would likely use this bike as about 50/50 between blacktop and dirt, and do the wheel swap for each terrain.
    Thoughts ?
  12. MotoMattNYC
    MotoMattNYC Been here awhile
    Oct 29, 2017
    268
    NYC
    It’s been done both ways and answered numerous times. With that being said get whatever you plan on riding more. I have an enduro with sm wheels and I mainly ride the street go figure. IMO I’d rather have the extra suspension travel for speed jumps and curbs.
    wsmc99 and KiwiPewe like this.
  13. Chip Stevens
    Chip Stevens Been here awhile Supporter
    Feb 18, 2005
    464
    Yucaipa, Ca and Portal, Az
    Does anybody know the details of the 2018 701 recall concerning the automatic decompressor.
  14. MxFan69
    MxFan69 Im so happy
    May 4, 2014
    1,672
    Yeah, figured its a dead horse thats been beat to mush, but hard to sift thru 1000 pages.
    I agree with wanting the longer travel suspension of the enduro. Just thinking about the fact I would be getting the supermoto wheels and dual discs with the bike purchase vs having to spend 1200 to 1500 on a 17”x2 SM setup if I went with the enduro as my bases.
    I should limit my question to those with a newer supermoto that have put 21”/18” with dirt treads on their SM, and ask HOW BAD was it off road? Did you BADLY miss the lacking 2” of travel, or was it not that big of deal?
    I need to review the fork length spec of the SM, as I have an extra set of KTM 2013 CC forks from a XC dirt bike. I wonder how different they are in both length and trail.
  15. Greubin
    Greubin Adventurer Supporter
    Sep 17, 2016
    33
    Central Oregon
    FWIW my friend had the same clutch issue on his FE501. The local dealer was willing to replace it with a factory replacement (magura) knowing full well it would eventually fail again. A call to KTM/Husky USA to file a complaint was made and requesting a brembo replacement, Husky agreed to replace the defective parts and worked with our local Husky dealer to replace the magura parts. Worth a shot YMMV.
    Sent from my Nexus 6P using Tapatalk
    K_T_M likes this.
  16. K_T_M
    K_T_M Adventurer
    Jan 22, 2012
    30
    Sonora CA
    Dealers here in N. California will only use Magura parts even though multiple warranty (2 or 3) replacement failures have been documented. The FE bikes seem to have the most failures. Brembo's are solid.. No problems on my 690's.
  17. Dlyttle
    Dlyttle Been here awhile
    Jun 10, 2013
    109
    Nelson NZ
    Thanks. The spacer is so thin it is quite damafed
  18. HeavyRotation
    HeavyRotation Been here awhile
    Jun 6, 2018
    310
    Eugene Oregon
    So your friend did the gold valve OC conversion and didn't like it? With or without the additional mid valve? I bought this 701 to use as a big dirt bike, the high speed compression damping in the fork is awful.
  19. HeavyRotation
    Jun 6, 2018
    310
    Eugene Oregon
    My 17 701 has a fairly significant speedometer error of 5%. 60mph indicated is actual 57. It also has the 5th and 6th false neutral but i just adapted and ride around it, seems to be getting less frequent. I also mainly ride in SG12 motocross boots with a huge boxy toe which makes upshifts easier.
  20. HeavyRotation
    Jun 6, 2018
    310
    Eugene Oregon
    I would say it doesn't matter much because the Enduro suspension blows, you'll need to fix it anyway. Get the SM.
    MxFan69 likes this.
