Husqvarna 701 Super Moto and Enduro!
Discussion in 'Thumpers' started by Dozer720, Aug 13, 2015.
  1. sjh
    sjh Adventurer
    Jan 31, 2016
    58
    uk
    I'm still new to my 701, at ~450 miles in a week or so. I'm a little over the intended rider weight (by "little" i mean ~15kg ) so I'm going to swap the rear spring to get the ride height right & planning on softening the front a bit for a less harshness, but other than that it feels ace to my novice hands :) Certainly a hell of a lot better than the DRZ i had!
    If the sidestand has been shortened however i don't think the previous one could have stood up on flat ground!
  2. Bonnie & Clyde
    Bonnie & Clyde Wishing I was riding RTW
    Jan 10, 2006
    4,054
    Gardnerville NV
    @rjnutt Rob has flex bars and hand guards
    GalacticGS likes this.
  3. Todd157k
    Todd157k Long timer Supporter
    Aug 14, 2012
    3,001
    Ventura, CA
    fixed that for you. :deal
    rjnutt likes this.
  4. Oetker
    Oetker Been here awhile
    Nov 1, 2016
    186
    For the enduro the part number has changed but the length isn't part of the description, for the SM it is: 306 vs 275mm.
  5. Requiem84
    Requiem84 Riding around the world @gravelforbreakfast.com
    Oct 17, 2016
    350
    If I like softly sprung bikes, and if I like to ride on mostly on not relatively easy gravel tracks (with a lot of washboard shit :(), I'd guess the Explorer forks would fit me better out of the box?
  6. bemiiten
    bemiiten League of Adventures
    Jul 10, 2003
    5,681
    Hamilton NJ.
    If the speedo on the 701 fails due to moisture, is a OEM replacement plug and play or, aside from resetting the odometer, do I need to take it to a dealer to get it to work? Also, does the bike still run if it fails? Any fixes to keep moisture out in the first place?
  7. Folxam
    Folxam Been here awhile
    Jun 25, 2018
    193
    Sweden
    OEM speedo is the plug and also the play.
    Bike runs fine, does not care the slightest.
    Disassemble, put some sort of goop around the edges, reassemble, profit.
    bemiiten likes this.
  8. justlookin
    justlookin Been here awhile Supporter
    Dec 16, 2007
    683
    Ohio
    If you are proactive and can keep unit from leaking you will have an accurate odometer. When mine failed the dealer told me the odometer would be set at 0000 and could not be adjusted.
  9. Kiwirich
    Kiwirich Been here awhile Supporter
    Dec 26, 2007
    915
    Toowoomba Australia
    Hey GalacticGS
    I went with the Adventure bend and a GPR submount.
    I wentvwith HDB Handguards mainly for the mirrors.
    41mm of rise.
    Absolutely awesome
    Kiwirich
  10. MarkV
    MarkV Been here awhile
    Jan 27, 2003
    150
    Hartford, CT
    Seems it was '16's & early '17's that were impacted before husky caught on. Rode the bike for four weeks waiting on a replacement after the original failed. Very easy to swap; to access only 3 screws hold the fairing in place & two screws hold the unit in place. I took my soggy unit to the dealer and swapped it out for fresh one. Just keep track of the mileage, my dealer already does. You'll have to reset the front tire diameter in cm & the clock but that's it.
  11. Tired Oil
    Tired Oil Been here awhile
    Dec 6, 2016
    268
    Hi guys! I'm back!
    This morning when I was trying to start my 701 in the driveway, the clutch slave cylinder literally exploded and I almost did an involuntary wheelie as the clutch slammed shut.
    I am well aware that the stock slave is the achilles heel of the bike, that there are lots of failures. Mine was already replaced under warranty last year. I was going to swap it for an aftermarket part later, but I put it off. Bad decision. Fortunately I still have warranty until April so they get to pay for it again. I wonder how much money this is costing them across all bikes in the field.
    I called Husqvarna Mobility to get the bike towed to a service station. The friendly lady in the call center asked if it was correct that I own a "701 Eduardo". Clearly they have highly trained and experienced staff.
    Oh and Husqvarna Mobility is estimating over two hours to come and pick up my bike from a suburban drive way on a weekday morning. I wonder how long I'd have to wait if I was out on a trail somewhere on Sunday. But this is a detail.
    KiwiPewe and Yukon Ho! like this.
  12. Salzig
    Salzig Long timer
    Oct 17, 2008
    1,626
    Cremona, Italy
    Only wanted to show off my new bike lift :D
  13. mtntrails
    mtntrails Life is Short... Supporter
    Jan 26, 2006
    1,024
    Mount Airy, MD
    Nice lift - who makes it?
  14. Salzig
    Salzig Long timer
    Oct 17, 2008
    1,626
    Cremona, Italy
    Italian branded (Fervi) but made in PRC.
  15. ThuleSwe
    ThuleSwe Adventurer
    Feb 3, 2012
    78
    Sweden
    Does anyone know if Husqvarna has a fix for this problem, heard something about new o-rings etc ??
  16. new2adv
    new2adv Converting gas into wheelies since 1974
    Nov 5, 2018
    945
    Great White North
    From reading the various postings on the topic, it seems their “fix” consists of replacing it with another cylinder of the exact same design, leading to another failure a few months down the road.
    What was it Einstein said? Something like “Insanity is doing the same thing over and over, and expecting different results”...
    Tired Oil and GlennR like this.
  17. tft
    tft Spends to much time on advrider. Supporter
    Nov 30, 2012
    1,169
    Austin, Texas
    Is there and aftermarket fix?
  18. SATEX
    SATEX Long timer
    Nov 1, 2002
    4,745
    San Antonio, TX USA
    I'm keeping my 2016. I really like it, but it already has more technology on it than I want .... for the way I use it. To each his own.
    jacinto likes this.
  19. SuzyMoto
    SuzyMoto Flying up to Sky
    Sep 9, 2014
    130
    Emerald city
    Which year is your 701? I've heard from 2018 owners a lot, but I haven't seen posts from 2017 owners yet...same to Husqvarna 500s.
  20. GlennR
    GlennR Chasin' my tail
    Nov 4, 2010
    3,924
    Sugar Grove or Denver, NC
    Has anybody been injured by the faulty clutches?
