Husqvarna 701 Super Moto and Enduro!
Discussion in 'Thumpers' started by Dozer720, Aug 13, 2015.
  1. ThuleSwe
    ThuleSwe Adventurer
    Feb 3, 2012
    85
    Sweden
    Wonder what price is going to be for Husky kit. Also noticed looks like no fiddling around with the fuel pump.
  2. Thomas-G
    Thomas-G Adventurer
    Aug 29, 2016
    85
    Zuerich Swizzerland
    Wow! a 1000 Euros would be a killeroffer! Homologation of the 701 LR confirmed by my dealer today, has no price idea and doesen't know if a kit for other models will be avaliable. But he and i think so.
  3. dragos
    dragos Master of disaster.
    Jul 27, 2004
    2,769
    Romania
    I got the number from here:
    https://advrider.com/f/threads/husqvarna-701-lr-long-range.1415380/page-2#post-38755849
    and is mentioned as the premium on the LR model, not as the price for the separate kit (which should be higher). Still, even double that would be competitive.
    Thomas-G likes this.
  4. ShawnKTM530EXC
    ShawnKTM530EXC Long timer
    Nov 22, 2008
    1,127
    Ventura County, CA
    Is it possible to strip the graphics off the plastic, without damaging them or losing the gloss? Or another option, how difficult would it be to achive a matte or satin finish? I'm thinking I'd like to do something like this, with a black and white seat.
  5. Motoriley
    Motoriley Still riding like crap after all these years.
    Feb 14, 2003
    3,002
    Deepest darkest burbs of Montreal
    Need to remove the axle from the adjuster to install bling. Anyone have any experience before I get creative? image-2019-11-09-11:51:01-763.jpg
  6. ShawnKTM530EXC
    Nov 22, 2008
    1,127
    Ventura County, CA
    It's threaded on. Maybe get some penetrating lube in the treads and go from there.
  7. PYG RYDR
    PYG RYDR Adventure-Dual Sport
    Sep 26, 2010
    675
    Southern VA
  8. KiwiPewe
    KiwiPewe Coddiwomple Supporter
    Oct 10, 2016
    7,831
    New Zealand
    I do that all the time when changing from enduro to SM.
    Go to your local hardware or plumbing shop and get two narrow nuts, small enough so both fit on the exposed thread.
    If you can't get one narrow enough, someone with a lathe can cut a big one in half.
    Install both nuts on the thread and counter (tighten against each other) them.
    Now by turning the bottom nut you should be able to undo the axle.
    Use medium strength loctite when fitting the axle to its new home, loosen and remove those nuts when you're finished, é voilá!
    PYG RYDR likes this.
  9. wipe-out
    wipe-out Been here awhile
    Jan 9, 2012
    519
    Germany
    New owner. Only got the bike early October. This is how she sits right now. New exhaust, AXP bashplate, Aurora Lite kit mostly installed. Still thinking about the BRP Scott's mount... hmmmm... HDB handguards and Perun rack at home. Lower, larger foot pegs on order. Thinking about a tablet for navigation. Oh and carbon covers for the engine & clutch covers. Or HDPE covers? Aaaargh. Choices. :D Screenshot_20191109-233726_WhatsApp.jpg Screenshot_20191109-233821_WhatsApp.jpg Screenshot_20191109-233803_WhatsApp.jpg
  10. mtntrails
    mtntrails Life is Short... Supporter
    Jan 26, 2006
    1,034
    Mount Airy, MD
    Just picked up a leftover 2019 Enduro and getting prepared to do my build.
    Quick questions for the collective...
    Is the OEM clutch slave still an issue with the 2019s?
    Debating whether I should pull the trigger on the Oberon.
    For those of you utilizing the Rade tank and running the fuel line direct to the main tank vent, which fuel cap assembly are you utilizing for the main tank? I’m looking at the Vanasche unit.
    Should I do the SAS removal? Who’s is making a good kit for that?
    Thanks in advance.
  11. CroatianHusky
    CroatianHusky Adventurer
    Oct 9, 2019
    16
    Croatia
    You don't like the grey-yellow 2020 decals either huh? :D
    Honestly I was thinking buying a second set of plastics, getting them sprayed black and going for a crazy decal set like this:
    https://www.motoproworks.com/collec...usqvarna-graphic-kit-factor-marpatcamo-yellow
  12. NoelJ
    NoelJ Long timer
    Apr 7, 2016
    1,496
    USA
    I did the siphon method on my Rade tank - used the stock filler cap and worked fine. I also retained the canister and SAS. As far as I can tell, the only reason to remove it is saving a little weight [or you hate clean air].
    Chickened out on the clutch slave and bought an Oberon, but lots of stories out there that a simple O-ring swap is just as good.
  13. dirty_sanchez
    dirty_sanchez Dirty_Sanchez
    May 8, 2006
    4,006
    Louisiana, Baton Rouge
    Same setup plumbing the Rade tank.
    I opted for the Vanasche on the main tank filler only because I don't want to hassle with removing the key with each fuel stop-then there's the risk of the key breaking off in the key lock fuel filler cap.
    I like simple.
  14. Motoriley
    Feb 14, 2003
    3,002
    Thanks guys. Watched the video and it worked a charm.
    QUOTE="KiwiPewe, post: 38759758, member: 376433"]I do that all the time when changing from enduro to SM.
    Use medium strength loctite when fitting the axle to its new home, loosen and remove those nuts when you're finished, é voilá![/QUOTE]
    KiwiPewe likes this.
  15. ShawnKTM530EXC
    Nov 22, 2008
    1,127
    Ventura County, CA
  16. NSFW
    NSFW basecamp4adv Super Supporter
    Feb 20, 2007
    25,278
    Burbank CA
    time to install the Oxford Grip Heaters. the bracket mount that came with it has no place to install it on the clutch lever perch. i've seen people have the controller on and near the ignition switch or on the top bar clamp. i prefer on the left side of the handlebar.
    thinking of using the ram mount which i did on my X Country. i can take off the controller when it's not needed.
    how did you install yours?
    some install here
    https://www.street-triple.co.uk/index.php?topic=33299.0
  17. rjnutt
    rjnutt Desert tortoise
    Feb 27, 2008
    1,300
    Washoe Valley, NV
    I just mounted mine to the FlexBars with 3m dual locks. You could do it to the top of the Clutch reservoir or anywhere else you want it. Rock solid and hasn’t ever moved, even with all my dirt naps....
  18. mtntrails
    Jan 26, 2006
    1,034
    Mount Airy, MD
    Much appreciated.
    You too @dirty_sanchez
    I’m sure I’ll have more questions as the build progresses.
  19. NSFW
    Feb 20, 2007
    25,278
    Burbank CA
    Oxfords installed on my 2018.
    Have to destroy the left grip. Right easily came off using compressed air.
    Hooked directly to battery until I find the Ignition On terminal.
    PYG RYDR and dstutz like this.
  20. Tijuana_Taxi
    Tijuana_Taxi Been here awhile Supporter
    Jun 20, 2009
    911
    Boise,Idaho
    There is a switched and un-switched connection behind the headlight
    NSFW likes this.
