Husqvarna 701 Super Moto and Enduro!
Discussion in 'Thumpers' started by Dozer720, Aug 13, 2015.
  1. sati8d
    sati8d REALLY?? Eh! Oh! ca va pas non??? Supporter
    Mar 19, 2011
    1,371
    New Bern, NC
    Went from K&N cone filter to RG Twin Air, night and day better feel, wheelies easy no clutch in 2and a wee bit in 3rd
  2. Oetker
    Oetker Been here awhile
    Nov 1, 2016
    186
    Seems you have it figured out but I was dealing with a similar noise a while back, the issue was that the chain had eaten through the top slider enough that it was also eating into the screw that attaches the chain guard.
    felixblack1 likes this.
  3. satur9
    satur9 angry black guy
    Mar 7, 2009
    928
    hfil
    My brand new 11 miles old bike Slave went. I told the dealer I'm going with rekluse instead of waiting for factory junk. They agreed. It's a shame 2020 bikes still have this problem. Plus getting parts gonna be hard for a while. I did by a ten pack of Orings but then decided on a more permanent solution.
  4. felixblack1
    felixblack1 Been here awhile
    Jun 8, 2010
    327
    Australia, Sunshine Coast
    Hmm thanks will check that as a precaution. May explain why chain needs to be slightly tighter then spec
  5. NSFW
    NSFW basecamp4adv Super Supporter
    Feb 20, 2007
    26,384
    Burbank CA
    my 2018 has less than a 1k miles when the clutch slave leaked. even though it was still on factory warranty, i replaced it with oberon myself. sadly, here i dont trust the dealer to do the repair. i almost crashed after i bought the bike. paid $$$ set up fee and still they forgot to tighten the screw above the brake pedal. the screw that limits the pedal play. next thing i know, it jammed the rear and went sideways. glad i saved myself and the bike.
  6. Barry
    Barry Just Beastly
    Oct 4, 2002
    10,147
    Fredericksburg, Va.
    OK - first, let me apologize... I’m asking a question that I know has been answered, but I can’t find the answer and DO NOT want to do damage.
    2017 Husky 701 SM. I have a 16t OEM front sprocket, many people are suggesting going to 15t for better pull in all gears. I do not need the top-end of the OEM gearing. I read that with 15t 120mph is max speed. I don’t think I’ll be doing that anytime soon.
    That said, I read a lot about the need for the sprocket to be EXACTLY the OEM thickness, or it will wear out the seal on the inside of the sprocket. I really do NOT want to do that.
    Can someone please post (again) a link where I can obtain one? I have searched on this thread, and run it throught the googles... no joy.
    Again, apologies and thanks.
    Barry
  7. jams229
    jams229 Been here awhile
    May 27, 2007
    237
    What dos the RG stand for?
  8. HBSURFDAD
    HBSURFDAD Let's go see what's over there Supporter
    May 15, 2016
    1,029
    Huntington Beach. CA, USA
    Rade Garage, Great aftermarket parts.
  9. renogeorge
    renogeorge Let's ride!!
    Apr 7, 2007
    6,681
    Reno
    any place that sells OEM KTM/Husky I use Rocky Mountain ATV
    Barry likes this.
  10. Barry
    Barry Just Beastly
    Oct 4, 2002
    10,147
    Fredericksburg, Va.
    Thanks. The Rocky Mountain page shows the various CS sprockets as “damped”, which I believe is what is required for the Husky....
  11. renogeorge
    Apr 7, 2007
    6,681
    Reno
    The dampening is just rubber glued to the sprocket for noise reduction. I believe all the OEM ones have that. Not that big a deal. I've had the rubber come off the sprocket
  12. Barry
    Barry Just Beastly
    Oct 4, 2002
    10,147
    Fredericksburg, Va.
    The flange thickness is key, from what I read. Too thin (non-OEM spec) and it will wear the seals. Long as it is OEM I’m comfy. I wanna’ go down 1 tooth.
  13. Todd157k
    Todd157k Long timer Supporter
    Aug 14, 2012
    3,576
    Ventura, CA
    Hooked up the Trail Tech Voyager pro on the 701 today (my ktm 300 will wait til tomorrow). Went smooth. I didn't want the beast on a ram mount so I made a plate for it and fastened it to the handlebar mount. Once I ride and see how the glare is, I can bend the plate down a little if needed.
    Everything went smooth and TT supplied to correct parts HOWEVER, the temp sensor wire is about 6" too short. It does reach ok but really needs more wire so you can route it behind the plastic panels. As it is now, it's singin in the breeze above the radiator. w/e.
    Wire wrapped as directions said.. hint: a little soapy water makes the rubber much easier to work with.
    While I had the side cover off, I smashed a spare fuel pump in the useless tool cady.
    This is where the temp sensor gets screwed in.
    I put my "friend tracker" antenna behind the light shroud.
    HBSURFDAD, PYG RYDR and NSFW like this.
  14. Todd157k
    Aug 14, 2012
    3,576
    Ventura, CA
    This is what my dash looks like..
    Panders, PYG RYDR and SonoraDave like this.
  15. Todd157k
    Aug 14, 2012
    3,576
    Ventura, CA
    I didn't purchase the wheel sensor. GPS speedo is fine with me. Downside is the fuel gauge estimator won't work. bfd.
  16. NoelJ
    NoelJ Long timer
    Apr 7, 2016
    2,006
    USA
    Tach work OK? I've heard a lot of negatives about twin plugs and sensor tachometers.
  17. Todd157k
    Aug 14, 2012
    3,576
    Ventura, CA
    Seems to work fine. I don't know how accurate it is, but idle was a little over 600 rpm, revved up and tracked ok.
    NoelJ likes this.
  18. dhally
    dhally Hammerhead Supporter
    Feb 18, 2006
    6,341
    Kennewick, WA
    Covid-45 update s?
    I have street tires still mounted from my CSM Peace Party ride in Sept.,so I've been out riding the new subdivisions on tops of hills. Hooning.
    Today I took all my gas cans down for a sterile fuel transfer. That way I can fuel up at home and don't need to carry nitrile gloves on my rides..
    Damn it's hard to represent responsible motorcyclists with this bike!
  19. JPA
    JPA Been here awhile
    Jul 11, 2016
    299
    Finland
    Shouldn't it be around 1600...1700 rpm?
    dstutz likes this.
  20. ShawnKTM530EXC
    ShawnKTM530EXC Long timer
    Nov 22, 2008
    1,139
    Ventura County, CA
    It’s not that it wears it out. To thin and the sprocket doesn’t put enough pressure up against the seal. And, some seem to leak and it seems, some don’t.
    Barry likes this.
