Husqvarna 701 Super Moto and Enduro!
Discussion in 'Thumpers' started by Dozer720, Aug 13, 2015.
  1. Panders
    Panders Been here awhile
    Feb 5, 2015
    132
    Santa Cruz, California, USA
    Definitely could just look that way.
    Last year I was checking my bike over before leaving on a multi-day trip and saw the fluid looked black in the sight glass on the reservoir. Bled it out... and it came out looking basically brand new. The reservoir color and design definitely fakes darker than it is.
    buzzword and Chillis like this.
  2. Chillis
    Chillis Long timer Supporter
    Aug 25, 2005
    14,990
    Las Vegas
    That isn't making a good case on my hypothesis as to why they go out.
    I'll order up an aftermarket one too.
  3. Panders
    Feb 5, 2015
    132
    FYI - You can also just change the seal on the stock slave and fix the problem perfectly for a couple bucks. The details on the right o-ring specs are somewhere in this thread.
    That said, I did the Oberon because I wanted something plug-and-play easy to get my bike going again ASAP. There is also a Rekluse slave option that has some additional adjustment capability.
    Chillis likes this.
  4. Folxam
    Folxam Been here awhile
    Jun 25, 2018
    194
    Sweden
    Would that work with tube type tires though?
    Chillis likes this.
  5. NoelJ
    NoelJ Long timer
    Apr 7, 2016
    1,397
    USA
    The gasket/bladder thingy that goes down into the master cylinder makes the fluid look black - pop it open and it'll probably be fine.
    As far as the slave goes - the number of failures is so high that I can't believe there's any adjustment or operator input contributing to the failures. They suck, plain and simple. My SM has the original since I rarely go far from home. The E got an Oberon before the first long ride. I bought a few o-rings to have "in stock" for the SM if it fails.
  6. 2 SPOT
    2 SPOT bring the rape whistle
    Dec 14, 2005
    6,935
    Payson AZ
    I carry an o ring and a tiny lottle bottle of fluid, 25x22.5.
    A tube type tire works fine on a tubeless rim, but it will slowly leak air. tubeless tires made just a bit diferently to hold air.
  7. Colorad0
    Colorad0 Long timer
    Aug 21, 2014
    1,017
    Tyestick likes this.
  8. Colorad0
    Colorad0 Long timer
    Aug 21, 2014
    1,017
    My clutch slave seal went out at 7,000 miles on my 16'. Luckily it happened in the garage. Unluckily it lead to a series of events that caused an injury that has me grounded for a month.
  9. Colorad0
    Colorad0 Long timer
    Aug 21, 2014
    1,017
    Wow, glad I caught this post. I didn't even think about the brake fluid getting into the engine oil. I'll have to do an oil change before I ride. Did you do filters as well?
    Panders and 2aRover like this.
  10. tomasv
    tomasv Check the Czech!
    Jun 14, 2006
    1,312
    Seattle area
    You don't miss anything with Rade in terms of customer service or quality. I encourage you to look at one in person if you have an inmate close by
    Pic from this Saturday - riding some single tracks around Cle Elum 2020-07-04 12.55.48.jpg
    Hkon89 and PYG RYDR like this.
  11. 640 Armageddon
    640 Armageddon Xplorer Supporter
    Mar 4, 2009
    4,411
    Greece
    Neatly done @Lord Explorer :pynd
  12. BraboBert
    BraboBert n00b
    Jul 7, 2020
    1
    Virginia Beach
    Hey everyone! Trying to figure out how screwed I am.
    I have a new 2020 and went through the process of replacing the Clutch Slave with an oberon unit, but surprisingly, it was leaking oil. I had snugged the bolts down by hand and then did it based on feel, but it still leaked motor oil even after replacing the gaskets!
    Unfortunately, I got the wise idea that I should use a torque wrench and tighten it down to spec. The threads on the casing are now stripped out... Something about torqueing down a steel bolt into an aluminum casing doesn't work out too well.
    Am I screwed? It's a brand new bike and I'm beside myself right now. I could use a longer bolt...
  13. tomasv
    Jun 14, 2006
    1,312
    Seattle area
    What do you do? it needs to be my next job!
  14. Panders
    Feb 5, 2015
    132
    Yes, but only because I waited until my next scheduled oil and filter change. There was foam residue in the crevices of the filter housings that I had to clean out, so it was good I did it. If you catch it right away and don't ride it at all after the seal fails, you could definitely get away with just changing the oil.
    Colorad0 likes this.
  15. 2aRover
    2aRover Been here awhile Supporter
    Mar 22, 2005
    462
    Boise
    My slave went at around 2,000 miles, very close to home, but I was on my way to a dirt bike school. Rats. I insisted the dealer make Husky pay for the oil change.
  16. ktmrandy
    ktmrandy Been here awhile
    Jun 9, 2014
    217
    Sacramento CA
    Helicoils will fix you right up
    Motoriley, Kiwirich, KiwiPewe and 2 others like this.
  17. mootsuno
    mootsuno Long timer Supporter
    Nov 29, 2005
    1,046
    Cotati, CA
    And use a longer bolt.
  18. Panders
    Feb 5, 2015
    132
    Yep, I definitely get that. I just love the look of Aurora's redesigned radiator shrouds.
    Your side stand doesn't look stock for a 2017. What is that?
  19. tokig
    tokig 20 Husqvarna FE501s Supporter
    Apr 5, 2016
    435
    east coast
    I am not having good service from Tubliss 18" used in my rear wheel 2017 FE701e.
    Rear rim listed i the 2017 701e parts diagram as a WM2 , but in reality it is a WM3 -2.50"
    Tried a couple 18" Tubliss for 11k, now going back to tubes and rim locks.
    Tire at low pressure (10-15)will tear stem off tubliss tube.
    So found a rim lock and documenting the weight.
    Installing a ChenShin 3.75/4.00-18 tube as it was in my inventory.
    Tire will be TKC80 140/80 - 18 twinduro
  20. renogeorge
    renogeorge Let's ride!!
    Apr 7, 2007
    6,394
    Reno
    Interesting. I ran Tubliss front and rear for 20k or so miles, often airing down to 10-12 psi off road. Never had a single problem. The Tubliss insert at 110 psi is a very effective 360 rim lock by itself. And Tubliss includes a very beefy bolted rim lock. I just dont see how a tire could spin on the rim with this setup properly installed. Don’t know if this happened. But valve stem on high pressure liner must be aligned perpendicular. If off much the 110 psi is hard on valve stems pulling at an angle through the rim hole. FWIW
    Kiwirich, KiwiPewe and NoelJ like this.
