Husqvarna 701 Super Moto and Enduro!
Discussion in 'Thumpers' started by Dozer720, Aug 13, 2015.
  1. Tyestick
    Tyestick Been here awhile
    Jun 23, 2020
    172
    SoCal
    Gotcha.
  2. Chillis
    Chillis Long timer Supporter
    Aug 25, 2005
    16,057
    Las Vegas
    Have you been using the quick shifter at all?
    After using it some the transmission seems better as well.
    Make sure your chain is adjusted and lubed and be deliberate with that 5-6, 6-5 shift and it breaks in and you stop having to think about it. The false neutral goes away.
    HBSURFDAD and NoelJ like this.
  3. wipe-out
    wipe-out Been here awhile
    Jan 9, 2012
    519
    Germany
    I have an electrical issue with my bike. Bike is pretty much brand new, installed the Aurora kit and a couple of extras. Headlights and turn signals connected via OEM connectors. USB charger via ACC1 (always on). It has an on/off switch and lights up when on. Positive it has always been off when the bike was sitting. Next I installed a powered holder for my Tablet, extra lights, heated grips. All powered via a PDM60. PDM60 starts with ignition after a set delay, so no power should be going to those devices when the bike is off.
    The battery keeps going flat when the bike is sitting for some weeks. I have exchanged the battery for a new Lithium one to rule out the battery and save a couple of grams. I had measured twice for creeping currents but came up with nothing.
    How would you go about identifying the issue?
  4. wipe-out
    Jan 9, 2012
    519
    Germany
    PS: Not letting the bike sit a couple of weeks unfortunately isn't an option right now
    Bayner likes this.
  5. teebag
    teebag Adventurer
    Sep 1, 2015
    44
    Cape Town
    usb charger is draining battery
    JoeMongo likes this.
  6. NoelJ
    NoelJ Long timer
    Apr 7, 2016
    1,496
    USA
    His USB charger is the switched kind. I have several - likely a product from the same Chinese factory that supplies the globe - and it's never given me a discharge problem. But it could be bad. Mostly they fail by not working anymore; never heard of them not turning off.
    The number of things you touched with the rally kit and PDM installation is actually kind of high. Start looking for a possible ground through a skived always-powered wire. It may be tiny if it takes weeks to drain the battery. The likely spot is in the crowded mess behind the headlights.
    Or resign yourself to disconnecting the battery before storing the bike.
  7. teebag
    teebag Adventurer
    Sep 1, 2015
    44
    Cape Town
    one way to find out, disconnect it and see
  8. NoelJ
    NoelJ Long timer
    Apr 7, 2016
    1,496
    USA
    Yup, and if possible do a daily voltage check - after a few days the battery voltage would drop if it isn't the root cause. And lithium batteries hold voltage very, very well with no draw.
  9. duggram
    duggram Sunrise Bahia de LA Supporter
    Sep 24, 2009
    1,273
    Truth or Consequences, NM
    Would a trickle charger be a mistake? I have two huskies and I keep both on a trickle charger.
    chilejack likes this.
  10. Yukon Ho!
    Yukon Ho! We can go ANYWHERE! Supporter
    Oct 2, 2011
    327
    Seattle/Mazama
    I have minimal electrical farkles (GPS cradle, upgraded fairing w/headlight) and I have to trickle-charge after 2 weeks.
    CTek chargers work great.
  11. tomasv
    tomasv Check the Czech!
    Jun 14, 2006
    1,346
    Seattle area
    +1
    Similar setup, except RADE/GARAGE tower - the USB will drain the battery in a few weeks when connected to always on. Changed it to the ACC2 (only on with a key as much as I don't like that because it does not allow me to charge phone when stopped) and the issue went away.
  12. Foo Bar
    Foo Bar Semper Fi Supporter
    Nov 19, 2017
    108
    Somewhere Between Space and Time
    Proper way to do it using the SWITCHED power supply. If using the always-on power supply, you’ll certainly forget to switch off or unplug devices at the worst possible place and time.
    Barry likes this.
  13. Panders
    Panders Been here awhile
    Feb 5, 2015
    159
    Santa Cruz, California, USA
    Solution: ride more often!
    :hide
    Chillis likes this.
  14. Oetker
    Oetker Been here awhile
    Nov 1, 2016
    186
    2017 used the top 'enclosed' design, later years the bottom design, of which I've read the pins can break off. The 2020 SMC uses a new enclosed design, which seems to be the best if you're going to upgrade. In 2018 the roller arm/spring were also changed.
    I switched from the 2017 star/roller/spring to the 2018 parts and shifting was improved a bit, however it feels like adding another couple thousand miles changed things (for the better) more.
    Tyestick likes this.
  15. Oetker
    Nov 1, 2016
    186
    Reason my 701 broke down is a broken valve spring. 2017 model, 16K miles. Seems to be a rare issue, which is surprising given the amount of endemic issues this engine suffers from.
  16. deapsquatter
    deapsquatter Adventurer
    Jun 4, 2018
    37
    South Africa
    Riel, Hkon89, erey and 16 others like this.
  17. Chillis
    Aug 25, 2005
    16,057
    Las Vegas
    Sucks to hear.
    One of those fluke happenings.
  18. 2 SPOT
    2 SPOT bring the rape whistle
    Dec 14, 2005
    6,978
    Payson AZ
    when you say creeping currents do you mean parasitic drain? it sounds like that what is going on
  19. Nw_adventure
    Nw_adventure Been here awhile
    Oct 16, 2012
    669
    Salt Lake City, St George, UT & Seattle -
    Looks like a sauna-
  20. Tyestick
    Jun 23, 2020
    172
    SoCal
    I wasn’t aware the 2020 701 supermoto had a quick shifter.
    The false neutral’s that I’ve been experiencing, have been from 2nd to neutral, or 1st to neutral.
