Husqvarna 701 Super Moto and Enduro!
Discussion in 'Thumpers' started by Dozer720, Aug 13, 2015.
  1. Yaay
    Yaay Been here awhile
    Dec 10, 2016
    108
    Hm, thats a little strange. I've googled a little more and found that part number 76912955544 is specifically for the 2020 Husky 701.
    I've also finally found the lowering distance in a third party dealers shop: its lowering by -40mm
    Chillis likes this.
  2. Tyestick
    Tyestick Hooligan at heart
    Jun 23, 2020
    283
    SoCal
    @Chillis
    Is this the interference that you’re referring to?
    It clears, but just barely. No hindrance in the movement.
    I won’t be able to get you a video until later today.
    Chillis likes this.
  3. Chillis
    Chillis Long timer Supporter
    Aug 25, 2005
    17,332
    Las Vegas
    I believe so. Lever has to be pulled inboard for clearance.
  4. Brmax
    Brmax Adventurer
    Oct 19, 2020
    33
    Missouri
    Im not saying I shouldn't lose about 25 lbs, rather I have an age problem because I only gained 25 after turning fifty.
    With that out there, Im not so sure them power part springs are for anyone above 180, or just The same as the regular length springs.
    I think there are several ways one can approach this situation. I will speak up easily and say for me I like to have a bit more foot on the ground any and all the time at a stop
    have a good day
    Chillis likes this.
  5. Chillis
    Aug 25, 2005
    17,332
    Las Vegas
    I wanted mine lowered too. For technical work I want to catch in the event of a fall.
    Last year I had one of those instances on my CRF450L where I started to fall over and I'm too stubborn to drop the bike and had my first muscle pull in my calf. That felt nice.
    Kiwirich likes this.
  6. Chillis
    Aug 25, 2005
    17,332
    Las Vegas
    Clears without issue?
  7. Tyestick
    Jun 23, 2020
    283
    SoCal
    Yes, but I’m still not a fan of it being so close.
    I sent a email to ASV with the picture showing the clearance, and this was their response:
    It looks like your Magura clutch master cylinder is positioned a bit to far outward toward the end of the handlebar. The 701 does have a large cluster between the clutch master cylinder and grip. You want the master cylinder and lever positioned so that when your index finger is reaching out from the grip, your index finger is touching the hook of the lever.
    Here is a video we have about lever positioning that should help-
    Thanks,
    -Bob
    Bob Morales
    Inventor
    Brmax likes this.
  8. SaugeenADV
    SaugeenADV Been here awhile
    Jun 13, 2018
    111
    Southampton, ON Canada
    Are those the short levers or long?
  9. Tyestick
    Jun 23, 2020
    283
    SoCal
    Short.
    SaugeenADV likes this.
  10. Brmax
    Brmax Adventurer
    Oct 19, 2020
    33
    Missouri
    That looks very similar to the 2020 and they touch also, maybe more so if you like the adjust for a bit of standing. Yours looks to have a covering or mine doesn't over a star adjuster at the contact point.
    This is tougher issue than the brake side Im trying to figure out. In short I thought a shim to move the master cyl away. Here in the photo ( big thanks), I see its as mine the clamp setup is not parallel with the reservoir but more angled on top
    For sure like them levers though.
  11. dirtystevedirt
    dirtystevedirt Long timer
    Oct 25, 2015
    1,037
    Cheney,Wa
    Woundflatout likes this.
  12. Tyestick
    Jun 23, 2020
    283
    SoCal
    A few more adjustments...
    Chillis likes this.
  13. Tyestick
    Jun 23, 2020
    283
    SoCal
    Chillis,
    When you originally had your shorty levers, can you remember offhand if the clutch lever came with any hardware out the box?
    My brake lever came with some small hardware pieces, but my clutch lever did not.
    There was a cutout in the foam packaging in the clutch lever box, for what I think may have been some hardware?
    I’m going to call and ask tomorrow, but I figure I’d ask you first.
  14. sati8d
    sati8d REALLY?? Eh! Oh! ca va pas non??? Supporter
    Mar 19, 2011
    1,366
    New Bern, NC
    Ditto.
    My '17 came with it installed with petcock. I love it. Sometimes I ride down the back tank to check my mileage then open petcock for another 75miles, sometimes i do the proscribed 50 miles then open the valve and get around 180miles....I do too many wheelie starts...screws the mileage.
    Either way it's super practical. I did buy a longer overflow tube to route it back down below the shock. The original is in front of the engine by the exhaust pipe and I just didn't like gas on the engine at temp.
    Question i have is my back tank has the aftermarket fill neck and the cal is not vented - why not?
  15. Tijuana_Taxi
    Tijuana_Taxi Been here awhile Supporter
    Jun 20, 2009
    949
    Boise,Idaho
    If the rear tank vent tube is connected to the aftermarket fill neck like it comes stock the cap doesn't need to be vented.
  16. simon crewe
    simon crewe Been here awhile
    Sep 27, 2007
    307
    Haslemere, UK
    The kit you show in your post is common to a number of KTM models, it is comprehensive in its content, but expensive to execute as you have to fully disassemble the forks & rear shock to fit the kit of springs & spacers. The height reduction in the rear is achieved by fitting a spacer, which limits the travel of the shock. The advantage of doing this, in this way is that the geometry of the machine is kept correct. I have done this on my EXC as I only have a 31 inch inseam & it has made technical riding / confidence a whole lot better.
    Due to the costs involved with labour & parts, I would personally go the route of a lower rear link & dropping the front forks in the tripples a small amount. You can easily do this yourself & if you ever sell the machine, it is easier & cheaper to convert it back to stock.
  17. yeayeaatou
    yeayeaatou Adventurer
    Dec 17, 2017
    36
    ohio
    Better to carry a magnet or buy a kick stand dongle?
  18. dstutz
    dstutz Long timer
    Mar 23, 2008
    1,299
    Aberdeen, MD
    Yes
    KiwiPewe likes this.
  19. Chillis
    Aug 25, 2005
    17,332
    Las Vegas
    I had the long levers. I can't remember any extra hardware.
    That isn't saying anything though.
    Tyestick likes this.
  20. greasyfatman
    greasyfatman Long timer
    Oct 18, 2014
    3,964
    Whats high miles on a 17 or newer? Anyone over 20k miles?
