Husqvarna 701 Super Moto and Enduro!
Discussion in 'Thumpers' started by Dozer720, Aug 13, 2015.
  1. ktmrandy
    ktmrandy Been here awhile
    Jun 9, 2014
    248
    Sacramento CA
    I'm at 36000 miles
  2. greasyfatman
    greasyfatman Long timer
    Oct 18, 2014
    3,961
    Nice what year is the bike? Any needs other than valve adj?
  3. Zepphead
    Zepphead Ride,explore,camp Supporter
    Sep 13, 2015
    466
    S.E. Adirondacks, NY
    Here’s a reference of the TM Designworks Factory Edition 2 on my ‘17 701E w/ 15-46 sprockets and oem length chain. Note the chain to guide pad relationship and axle blocks almost all the way forward in the swing arm.
    blalor likes this.
  4. Tyestick
    Tyestick Hooligan at heart
    Jun 23, 2020
    282
    SoCal
    Has anyone with a 2020 Supermoto experienced a slave cylinder failure?
  5. greasyfatman
    Oct 18, 2014
    3,961
    2020 enduro in reach. I didn’t think one that new would pop up. Any issues or things I should know about a 2020?
  6. dirtystevedirt
    dirtystevedirt Long timer
    Oct 25, 2015
    1,036
    Cheney,Wa
    28,500 miles on my 2016
    About 100 sets of tires (sarcasm) $$$$ it has used a lot of tires!!
    1 failed fuel pump $75 Quantum replacement
    1 wonky starter relay $15 KTM part
  7. dirtystevedirt
    Oct 25, 2015
    1,036
    Cheney,Wa
    Supermoto and Enduro share the same slave cylinder.
    I believe the world record holder was a 2019 or 2020 that only made it 40 miles before failure.
    JoeMongo likes this.
  8. NoelJ
    NoelJ Long timer
    Apr 7, 2016
    1,639
    USA
    Pretty sure I saw on FB a guy who made it a few hundred yards from the dealership. I don't remember the model year but I'm sure it doesn't matter! KTM isn't interested in fixing the issue.
    Woundflatout and Carmmond like this.
  9. JoeMongo
    JoeMongo ¿Por dónde? Supporter
    Dec 9, 2004
    1,024
    SF Bay Area, not exactly dirt moto heaven
    Fucking Awesome. Were you looking for some other more specific response? :thumbup
    j.
    KiwiPewe, seckinjo and greasyfatman like this.
  10. Tyestick
    Jun 23, 2020
    282
    SoCal
    Received my warranty replacement Cycra bars today...
    Check out the difference:
    2 SPOT and Todd157k like this.
  11. ktmrandy
    Jun 9, 2014
    248
    Sacramento CA
    2017 worst bike I ever had for reliability. two cams due to partly clogged oil jets. first set of valves wore out at 24000, Head developed crack at 28000, replaced head, valves etc. new valves are shot at 38000. Transmission bearing on clutch side blew at 32000 had to replace transmission bearings main shaft and a couple gears. I have been towed twice.
    When it runs it is the best bike for me so I put up with the rest. Still talking to my head service shop for possible solutions to the valves. I run at 80 mph on the freeway a lot to get to dirt so maybe I ride it too hard.
    Pooz likes this.
  12. Foo Bar
    Foo Bar Semper Fi Supporter
    Nov 19, 2017
    115
    Somewhere Between Space and Time
    With two oil filters and two oil screens, you still have oil jets clogging? Are you running any kind of aftermarket air filter or airbox?
  13. sjh
    sjh Adventurer
    Jan 31, 2016
    76
    uk
    I quite like the discoloured ones :D
    Tyestick likes this.
  14. Carmmond
    Carmmond S.E. WI
    Mar 29, 2014
    65
    Yep popped mine at 213 miles... put a Rekluse on.
  15. Carmmond
    Carmmond S.E. WI
    Mar 29, 2014
    65
    Got my SMC-R 2020 a couple of months ago and the first three upgrades for me will be...
    Clutch slave (done)
    Fisher Seat (over the winter)
    Exhaust (before next spring)
  16. Tyestick
    Jun 23, 2020
    282
    SoCal
    One of my buddies said the same thing. He’s like, just keep the discolored ones. :lol3
    Wow, that sucks.
    Carmmond likes this.
  17. Colorad0
    Colorad0 Long timer
    Aug 21, 2014
    1,165
    My clutch is sticking. When I let it out quickly, it moves slower than my finger. Anyone else have this problem?
    The clutch was bled 2-3 months ago when I replaced the salve with a oberon.
  18. ktmrandy
    Jun 9, 2014
    248
    Sacramento CA
    The oil jets for the cam lobes were partially clogged from the factory. Using electrical wire I was able to clean them out then I ran the bike without the cam cover so I could see the oil being squirted on The cam lobes before I considered the job done. Stock air box, K&N filter with grease on the mounting surface and twin air foam pre filter.
    Foo Bar likes this.
  19. satur9
    satur9 angry black guy
    Mar 7, 2009
    866
    hfil
    2020
    Slave went first ride 11 miles.
  20. tomasv
    tomasv Check the Czech!
    Jun 14, 2006
    1,376
    Seattle area
    I was looking at the same options, ended up with a Kouba + a stiffer spring. Full write up: http://www.husky701.com/koubalink-lowered-husqvarna-701-experience/
    jonz likes this.
