Husqvarna 701 Super Moto and Enduro!
Discussion in 'Thumpers' started by Dozer720, Aug 13, 2015.
  1. BigDogAdventures
    BigDogAdventures Fart Letter Supporter
    Sep 13, 2003
    7,361
    Mt. Vernon, Illinois
    I've got a 2020-----------does the rekluse gell (work good) with the quick shifter ?????
    Critic said the 2 kind of fought each other.
    BD
  2. Carmmond
    Carmmond S.E. WI
    Mar 29, 2014
    66
    Not sure what the Rekluse Gel is I put on the Rekluse manual slave cylinder.... Works great.
    https://rekluse.com/product/slave-cylinder-assembly/
  3. Carmmond
    Carmmond S.E. WI
    Mar 29, 2014
    66
    I think the record is a guy that picked up his new bike pulled in his clutch put it in gear and it blew:muutt
  4. BigDogAdventures
    Sep 13, 2003
    7,361
    No----what I meant was----does the quick shifter and rekluse work good together---one poster said no.
    Said they kind of fought each other.
    I'm wondering this because--------my quick shifter kind of sucks---------I've tried all combinations of timing for a few thousand miles and it's No Bueno. No use to tell me to try a different combo-------I've tried it all.
    I could shift it much smoother without it-------like to disable it.
    My old 690 was awesome shifting with a rekluse.----------before it blew up:D
    And then it shifted awful:imaposer:imaposer
    BD
    PYG RYDR likes this.
  5. NoelJ
    NoelJ Long timer
    Apr 7, 2016
    1,639
    USA
    Quickshifters are clutchless shifting...meaning the clutch isn't involved in the process in any way. As a result the slave won't matter. And I know what you mean about the QS. I have about 2200 miles on my 790 Duke, and while it works fine, it isn't...fine. I get on another bike and I'm immediately happier with the set-up. The 790's have a cable clutch, so aren't as nice when shifting manually. And the QS finds a way to intrude occasionally if you try.
    Have you had a dealer look at it? I'm told there's a calibration/adjustment process for the sensor that essentially times the ECU actions, and it requires plugging into the bike rather than a physical move.
  6. Carmmond
    Carmmond S.E. WI
    Mar 29, 2014
    66
    NoelJ has good info for you.... I didn't feel any fighting between them and like NoelJ said I don't see why they would. All I can say is with all the problems with the OEM clutch slave I don't want it on the bike and went with the Rekluse.... good enough for the KTM race team good enough for me.
  7. Guyote
    Guyote Adventurer
    Sep 14, 2020
    26
    Las Vegas
    Maybe I hadn’t noticed this before but does it look like the front drive sprocket has made contact with the front of the swing arm and worn a black groove out of it? Looking at it from the side I can’t see any clearance between the teeth and that portion that’s black. Does anyone see anything similar on their bikes? It’s the stock front sprocket.
  8. a2zworks
    a2zworks Trust me, I'm Pablo
    Mar 11, 2013
    2,623
    West Hobart
    That is the chain guide, it’s perfectly fine, here is mine
    cal08 likes this.
  9. Pooz
    Pooz Been here awhile
    Mar 16, 2017
    311
    Savoie - FR
    35000 km, something like 21700 miles
    3x motor (1 crank 10.000km, 1 cylindre head sealant 15.000km, 1 valve guide 20.000km), 1x shock absorber 24.000km.
    But no clutch (not "master") slave failure.
    Amazing bike :D
    raschaa, KiwiPewe and HBSURFDAD like this.
  10. greasyfatman
    greasyfatman Long timer
    Oct 18, 2014
    3,964
    How much time do you spend at the rev limit?
    sumo or enduro what year?
    Chillis likes this.
  11. greasyfatman
    Oct 18, 2014
    3,964
  12. SaugeenADV
    SaugeenADV Been here awhile
    Jun 13, 2018
    111
    Southampton, ON Canada
    This question isn't 701 specific but what are others using to lift their husky? I want to do basic maintenance, lube chain, change rear tire etc. I do have a standard style MX stand but even getting my KLX250S onto it was a bit of a chore. I haven't tried getting the husky on it. The "lift" style ones and even the Tusk scissor lift that I liked all seem to have a 300lb weight limit.
  13. Carmmond
    Carmmond S.E. WI
    Mar 29, 2014
    66
    I use this one from HF and it works good for me....
    https://www.harborfreight.com/1500-lb-steel-atvmotorcycle-lift-60536.html
    2aRover and dstutz like this.
  14. Brmax
    Brmax Adventurer
    Oct 19, 2020
    35
    Missouri
    I picked up a similar lift as that and Im glad I did. It was on amazon and an otc model. Its pretty dam stable for the 701, all while strapped and easily pulling it in circles around shop or work area. Theres always a benefit for the tried n tru axle area mount and cam over lift stands.
  15. stephlal
    stephlal Adventurer
    Aug 21, 2020
    40
    Oh Canada Eh
    I use the same one for my 300.
    I replicated it with a 1100 lbs scissor lift and built a platform on casters for it.
    I have a single car garage, being able to move them around on a lift was key for me.
    https://www.princessauto.com/en/detail/1-100-lb-motorcycle-atv-lift/A-p8667818e
    SaugeenADV and Todd157k like this.
  16. Norty01
    Norty01 Occupant
    Jan 30, 2014
    2,789
    CARLSBAD, CA, USA
  17. greasyfatman
    Oct 18, 2014
    3,964
    Well I need to crash proof this thing a little. Anyone have highway dirt bikes hand guards set up? Also some double wall bars or at least different Bars.
    Second step will be exhaust. I am thinking complete header back and an intake. Emissions delete and some dyno time. Whats out there for the 2020? Does the PC5 work for fuel and ignition changes?
    third will be bags. Soft bages of some kind.
    so recommendations on bars and hand guards?
    recommendations for uncorking this thing?
    and bags?
  18. HBSURFDAD
    HBSURFDAD Oops, Sorry Supporter
    May 15, 2016
    902
    Huntington Beach. CA, USA
    There is a thread on here that goes over options for the 701.
  19. a2zworks
    Mar 11, 2013
    2,623
    West Hobart
  20. Colorad0
    Colorad0 Long timer
    Aug 21, 2014
    1,169
    I don't think he approves of your rusty chain.
