Husqvarna 701 Super Moto and Enduro!
Discussion in 'Thumpers' started by Dozer720, Aug 13, 2015.
  1. Tyestick
    Tyestick Hooligan at heart
    Jun 23, 2020
    204
    SoCal
    Just a heads up in case you didn’t already know, the ABS dongle will cause your ‘check engine light’ to flash.
    CaptnSlo likes this.
  2. Tyestick
    Jun 23, 2020
    204
    SoCal
    I’m at 24,xxx miles on my 2020 and have had two valve checks. Both checks passed with flying colors. No adjustments needed.
    I’ve been told that these motors are pretty solid when it comes to valve checks.
    Night Falcon likes this.
  3. dstutz
    dstutz Long timer
    Mar 23, 2008
    1,368
    Aberdeen, MD
    I think you mean ABS light.
  4. Pooz
    Pooz Been here awhile
    Mar 16, 2017
    416
    Savoie - FR
    The answer is : 840 km.
    Amazing bike...:pep
  5. BrittC
    BrittC Been here awhile Supporter
    Apr 10, 2009
    768
    Westmont, IL
    How's the windshield holding up with the cables rubbing against it? I just got the same windshield and it's annoying to think it'll be damaged by rubbing the first time out...
  6. DIYPSCM
    DIYPSCM Been here awhile Supporter
    Jan 3, 2020
    282
    NorCal
    It has the expected rub marks, but can't really be seen with the cables in place.... the rub marks are straight up & down.
    WARNING!!! The shield is SOFT plastic. Just casual cleaning has already scratched mine. :baldy
    BrittC likes this.
  7. KiwiPewe
    KiwiPewe Coddiwomple Supporter
    Oct 10, 2016
    9,168
    New Zealand
    First 10k service you gotta get done at the stealership anyway, after that just do it yourself, once a year, it's not that difficult
    (Compared to a 9fiddy...:baldy)
    Do you plan on coming to Murchison in November? I could give you a quick rundown on how to do them.
  8. zipdoa
    zipdoa Green friendly giant
    Apr 20, 2016
    46
    Calgary
    Heads up - on my previous 701 I paid big money for the OEM turn signals from KTM-Versand.de. One stopped working and another leaked a bit of water into the housing. Wasn't impressed.
    I like the OEM look, but this time found these for $45CDN on amazon. They look identical to the KTM OEM units but 1/3 the price. I chopped the connectors off my stock lights and crimped them - they work great and fitment was bang on.
    New 4Pcs 12V Motorcycle LED Turn Signal Light Smoked Lens for Yamaha YZF R1 R6 R6S FZ6 FZ1, Turn Signal Assemblies & Lenses - Amazon Canada
    DeLewis, WSobchak and willh like this.
  9. Night Falcon
    Night Falcon Structural Failure
    Dec 25, 2008
    9,601
    New Zealand
    Cheers for the offer, bikeless atm and November - December is a bad time of year for my leisure activities :( There are loads of how to videos on it so I'd likely just have to give it a go...what's the worst that could happen :fpalm It's basically a valve check every service which seems a bit over the top for a modern bike....then again it is a 74hp single :yikes
  10. BrittC
    Apr 10, 2009
    768
    Westmont, IL
    I put the same ones on my Aprilia RXV a few years ago and really liked them. Bright, durable, and good looking (hey, aren't those the same requirements for a wife?)
    Yukon Ho! and Doc Sarvis like this.
  11. Doc Sarvis
    Doc Sarvis Advent-ia before dementia Supporter
    Dec 11, 2015
    539
    Carp Ca
    Pick two.
    zipdoa, Foo Bar, Bhart89 and 4 others like this.
  12. Morgan2021
    Morgan2021 n00b
    Apr 13, 2021
    9
    Fort Collins, CO
    Hope this is the proper place to put info about my 701 Husqvarna key.
    Huge hassle finding a replacement, lots of dealerships did not have them in stock (and they were expensive), and most locksmiths couldn't help me...
    Finally found someone who identified key #TMC1 would work. I think it was $12.
    Hope this helps save someone else some money and time!
    jonz, Racerx43, Yukon Ho! and 5 others like this.
  13. Tyestick
    Jun 23, 2020
    204
    SoCal
    Out with the old:
    In with the new:
    CaptnSlo, hezv4, el_heinzo and 2 others like this.
  14. DIYPSCM
    Jan 3, 2020
    282
    NorCal
    v
    Following up on this...
    Yes, the bulb was installed correctly. I ended up having to shim out the top of the reflector 5mm to get adjustment right, and that's with all of the regular adjustment used up. Folks complain about the 701's poor lighting.... I wonder if their's are just aimed too high?
    It was asked above about my weight, suspension sag etc... I have the rear sag set at about 4" and the forks slid up an inch into the trees.... the bike sits pretty level.
    On a side note..... I bought a Cyclops 10.0 ultra LED unit, only to find that of course the 701 needs a special model... more on that once I get the right one.
    I will say that now the stocker is adjusted correctly I question the need for the LED. Getting rid of the heat will be nice tho.
  15. Tyestick
    Jun 23, 2020
    204
    SoCal
    The stock 701 light is terrible. No matter how you try to adjust it. I attempted to cut corners and bit the bullet for the Cyclops Ultra 10.0 bulb.
    While the Cyclops bulb was obviously brighter, it was a scattered beam with some areas lit more than others.
    The stock 701 headlight reflector housing just isn’t meant to handle that much light.
    I stepped my game up, and went with the BajaDesigns XL80. Yes, it was expensive. Was it worth the cost? Absolutely. I wish I had went with the XL80 in the first place. Would have saved me the money I spent on Cyclops.
    smackyface and JoeMongo like this.
  16. Tyestick
    Jun 23, 2020
    204
    SoCal
    The master cylinder that feeds that caliper: Brembo RCS 15.
  17. Tyestick
    Jun 23, 2020
    204
    SoCal
    This being a somewhat older post, but yes… You’ll need to trim your carbon fiber ignition cover:
  18. Jan from Finland
    Jan from Finland Been here awhile
    May 2, 2005
    977
    A Silca ZD23RCP key blank works also.
    Dealerships do not have them in stock because they have to order a replacement using the VIN and your key code card.
    Image credit to @Webon.
    Yukon Ho! likes this.
  19. Jan from Finland
    May 2, 2005
    977
    I noticed the same. Not sure if the rack is wearing down but the paint is definitely gone.
    Motoriley likes this.
  20. greasyfatman
    greasyfatman Long timer
    Oct 18, 2014
    4,907
    This pebble managed to completely disable my front brake. It was very surprising coming into a turn having a completely stiff lever.
