Husqvarna 701 Super Moto and Enduro!
Discussion in 'Thumpers' started by Dozer720, Aug 13, 2015.
  1. MaZ-
    MaZ- Been here awhile
    Mar 16, 2017
    138
    Barcelona / London / Europe
    Thanks guys - I ended up taking it into a shop here in France (on the road, so was a little wary of trying too much myself and ending up stranded on a camp site ). It looked to me like it had enough fluid in the reservoir but the shop couldn't bleed it properly (from what I could tell they were using a vacuum on the Oberon bleed nipple).
    They ended up taking the entire reservoir / MC off the bike and putting it in an ultrasonic cleaner. Suspect the opening between the reservoir and the MC itself was somehow blocked.
    Unsure where the fluid that should have been in the circuit was but maybe it did indeed leave via the bleed port, which I didn't check before getting to the shop...
    NoelJ likes this.
  2. dirtystevedirt
    dirtystevedirt Long timer
    Oct 25, 2015
    1,144
    Cheney,Wa
    Bought my 2016 in the crate new. Have 28,xxx miles now.
    Fuel pump went out at 21,xxx miles.
    Put an Oberon slave cylinder around 18,000 miles, not because the oem failed, but to shut up the failure voices in my head.
    LOTS and LOTS of tires.
    Oil changes every 3000ish miles.
    Valve checks every 5-6k.
    Tons of fun and lots of great memories.
    4CS forks aren't terrible. They can be made to your liking by almost any suspension shop or Dal Saggio kit on your dime.
    Notchy shifting? Not really, but 5th to 6th needs to be deliberate. You get that for free on newer ones too! LOL
    Engine vibes? I raced CR500's for many years. Now those things are paint shakers. 2016 701, not so much.
    Steve.......
    KiwiPewe, Blakebird, sharpie1 and 7 others like this.
  3. Chip Stevens
    Chip Stevens Been here awhile Supporter
    Feb 18, 2005
    482
    Yucaipa, Ca and Portal, Az
    Talking about shifting a 701. Just shift it like a BMW and like me you will never miss a shift.
    Kiwirich and cookieGB like this.
  4. Dryslick
    Dryslick Been here awhile
    Feb 11, 2011
    336
    Lake Berkely, Montana
    Thanks, Steve. I pulled the trigger, added a vanilla milkshake to my orange koolaid. The bike was as clean in person as it was in pictures. Looking forward to putting some miles on it.
    Funny story. I normally assume I’m dealing with a guy on Craigslist. This bike was owned by a gal, and a very interesting one at that. Spends a lot of time on bikes and her and her partner had garage full of them. Good folk.
    Jthewood, KiwiPewe, Riel and 5 others like this.
  5. NoelJ
    NoelJ Long timer
    Apr 7, 2016
    2,456
    USA
    I've got two of these bikes and in both cases the shifting got much better a couple thousand miles in. Probably a bit me learning what it should feel like, but definitely a mechanical improvement as well.
    And yeah...the tires. Holy hell they eat tires. Worth it.
    The 16 definitely vibrates more - mine's an SM. The Enduro is an 18. They're very similar, but the Enduro runs full knobby tires to erase the balance-shaft advantage!
    Dryslick likes this.
  6. Tyestick
    Tyestick Hooligan at heart
    Jun 23, 2020
    224
    SoCal
    To clean up the shifting ‘issues’ on my bike I made two changes:
    1. Factory Pro shift kit w/ ceramic bearings.
    This, by itself eliminated any false neutrals I was experiencing.
    2. Shift Star.
    This is a beefed up, updated piece that eliminated any sloppiness and made shifting feel more solid and direct.
    EXTREMELY happy with the outcome.
    JHof44 likes this.
  7. smackyface
    smackyface Boldly going wherever Supporter
    Nov 3, 2020
    301
    Albuquerque, NM
    I’ve been thinking of the shift kit but keep convincing myself that my technique is the problem. Good to see a positive review. Cost is reasonable so maybe I’ll finally do it.
    Who makes the shift star?
  8. NoelJ
    NoelJ Long timer
    Apr 7, 2016
    2,456
    USA
    That shift star may already be in your bike - they switched over to a metal injection molded [MIM] part in I think 2017, but a high failure rate from the pins breaking off caused them to revert back sometime later; perhaps 2019 mid-year? It's the OEM part they've used in 99% of 690/701's since early on.
  9. greasyfatman
    greasyfatman Long timer
    Oct 18, 2014
    5,139
    What year is your bike again?
  10. Tyestick
    Jun 23, 2020
    224
    SoCal
    KTM. Item number:
    76834215000
    2020.
    XLEnduroMan likes this.
  11. greasyfatman
    Oct 18, 2014
    5,139
    Just for size comp and lack of space in my getmo. A kdx 220 and a 2020 701 close 99104CCC-97C7-4A0C-8A80-6AD431528D7E.jpeg
    Yeti2ride and JHof44 like this.
  12. wrk2surf
    wrk2surf on the gas or brakes
    Dec 16, 2007
    9,223
    THE exact center of California/Bass lake/Yosemite
    I would like to poll the collective on their thoughts on the Fly by wire throttle system, I am thinking of getting a 701 to race the Africa Eco Race and question the reliability.
  13. Tyestick
    Jun 23, 2020
    224
    SoCal
  14. NoelJ
    NoelJ Long timer
    Apr 7, 2016
    2,456
    USA
    I don't recall hearing of a single failure.
    wrk2surf and Motoriley like this.
  15. zoink
    zoink Been here awhile
    Mar 8, 2012
    410
    SW VA
    KTM rally replicas still use a cable...so I guess KTM doesn't think it's ready for the big time. Cables are definitely easier to work on in that environment. Though they're typically much slower to adapt newer tech to those bikes, didn't switch to using EFI until 2015 so it's hard to say what's holding them back. Probably a lot of if it ain't broke don't fix it when you're squeezing the life out of a bike day after day in the desert.
    Definitely not something I've personally seen anyone have an issue with, outside of the one guy who never clearly defined the issue outside of maybe the TPS and swapped a carb on his bike here:
    https://advrider.com/f/threads/701-build-notes.1437561/page-3#post-41024532
    That said not a lot of people ride their bikes in that kind of environment.
    If you're super worried about it, lots of info on carb swap in that thread and he posts in here every so often so could probably help you out.
    Also you could try and get in touch with some of the guys/teams that run these bikes and see what they have to say about it.
    From what I could find on the 2020 list there's 2 701s listed. None in 2018/2019. There's one guy who ran a 690 but I can't find any info on him/his team.
    Rally team ees
    https://www.facebook.com/energiaesorrisi/
    Roger Hawkins
    Rode for desert rose
    http://www.desertroseracing.com/
    https://www.facebook.com/adventureridingacademy/
    here's also a thread I found by his brother
    https://www.ukgser.com/forums/showthread.php/522281-Africa-eco-race
    Rally is awesome, I'll never be fast/rich/brave enough to race a big one, so I just follow what I can. If you pursue using the 701 curious to see what you find out and how it goes. Though I'm curious if you're going for 450+ class, why the 701 over a ~500cc sized bike?
    wrk2surf likes this.
  16. willh
    willh Been here awhile
    Feb 23, 2005
    488
    Shefford, Quebec
    Bikes been dongled for O2 and abs. 15 tooth going on today. Who is the go to for spacers for the throttle slop on a 2021?
  17. willh
    Feb 23, 2005
    488
    Shefford, Quebec
    Countershaft seal is leaking…
    This is starting to remind me of my old 640.
  18. DIYPSCM
    DIYPSCM Been here awhile Supporter
    Jan 3, 2020
    320
    NorCal
    Got mine from a guy in the UK... cheap & work great. Link is in this thread... somewhere.
    willh likes this.
  19. greasyfatman
    Oct 18, 2014
    5,139
    You sure? Or did you over lube the chain?
  20. willh
    Feb 23, 2005
    488
    Shefford, Quebec
